How Do You Simplify (i-3)^4 to a+bi Form?
  • Thread starter Thread starter Wasper
The expression (i-3)^4 simplifies to 28-96i. The calculation involves breaking down (i-3) into two groups of (i-3)(i-3), resulting in i^2-6i+9. This expression is squared to yield (i^2-6i+9)(i^2-6i+9), which expands to i^4-12i^3+54i^2-108i+81. By applying the properties of imaginary numbers, specifically the cyclical nature of powers of i, the final result is derived accurately.
  • Understanding of complex numbers and imaginary units
  • Familiarity with polynomial multiplication
  • Knowledge of the properties of powers of i
  • Basic algebraic manipulation skills
  • Study the properties of complex numbers in detail
  • Learn polynomial expansion techniques, such as the Binomial Theorem
  • Explore the application of De Moivre's Theorem in complex number calculations
  • Practice simplifying higher powers of complex numbers
Students studying algebra, particularly those focusing on complex numbers, as well as educators looking for effective methods to teach polynomial expansion and simplification techniques.
Wasper
Express (i-3) to the 4th power in simplest a+bi form.
I know the answer , but cannot get my answer to be correct. Can someone help me solve this?
Thanks
Howdy Wasper,
Ok, I'd break it down like this;
(i-3)(i-3) = i^2-6i+9
Now, because the original is to the fourth power you would have two groups like this;
Multiply all the above out properly and after combining like terms you have;
= i^4-12i^3+54i^2-108i+81
Now, using what you know about 'i' raised to a power (how it repeats, and so forth) you will be able to transform some i's into numbers. The numbers will then combine and reduce to;
28-96i
Well, at least I think that's about right, haha, because I think I goofed on one of the signs but I'm too lazy to go back over it again and check my work. I think you can take it from here. It's actually quite a fun thing to do when you start getting the hang of it and have your mind free to concentrate.
[edit]
Ooops, I just noticed this was homework help :frown:
Anyway, since I've gone this far already and because I don't know your level of understanding I'll rehash what I did above a little;
(i-3)^4 = (i-3)(i-3)(i-3)(i-3)
I broke it down into two groups of;
[(i-3)(i-3)]x[(i-3)(i-3)] = [i^2-6i+9]x[i^2-6i+9]
Do you follow?
You could have just kept grunting them out by only multiplying the quantity (i-3) over and over, but the way I did it seemed more of a shortcut (but it is probably easier to confuse yourself doing it that way too). Lastly, the imaginary part might seem confusing at first but is actually rather easy if you beat it into your brain that because i = squareroot of negative one you get the following repeating patern;
i^1 = sqrt -1
i^2 = (sqrt -1)(sqrt -1) = -1
i^3 = (-1)(sqrt -1) = (-1)(i) = -i
i^4 = (-1)(-1) = 1
Looking at the results from above you can see that i^5 is just going to be (sqrt -1)(1) = sqrt -1 = i^1, so i^5 ends up being i^1 (pattern repeats all over again). Do you suppose the odds are high that i^6 will end up being equivalent to i^2 ?? Yes, because it would be the equivalent of (i^2)(i^4) = (-1)(1) = -1 = i^2.
On i^4, an easy way to determine the answer is is by recalling what i^2 was equal to). You could grunt it out, however, by using the value of i^3 multiplied by sqrt -1 and getting in lots of good practice manipulating things;
= (-i)(sqrt -1)
= (-i)(i)
= -i^2
= (-i)(-i)
= (-sqrt -1)(-sqrt -1)
= -[(sqrt -1)(sqrt -1)]
= -[-1]
= 1
There, I hope that makes up for my having blabbed to much.
Just to point out that you don't really NEED to multiply
(i^2- 6i+ 9)(i^2- 6i+ 9) in that form.
i^2- 6i+ 9 is, of course, -1- 6i+ 9= 8- 6i so it is simpler
to multiply (8- 6i)(8- 6i)= 64- 2(8)(6)i+ 36i^2= 64- 96i- 36
= 28- 96i just as BoulderHead said.
my mistake was trying to do the (i-3) square it to the 4th power all at the same time. I think I got it now.. thanks for the help guys.
  • · Replies 17 ·
  • · Replies 20 ·
  • · Replies 88 ·
