How Do You Solve a Fourth Order Differential Equation with Sinusoidal Forcing?
hils0005
[SOLVED] Variation of Parameters
y^(4)-6y^(3)=-5sinx
I factored this at x^3(x-6)=0
so my r values are 0,6
also using for y(p) Dcosx + Esinx
y=Ae^0 + Be^6x + Dcosx + Esinx ?
y' =6Be^6x -Dsinx + Ecosx
y'' =36Be^6x-Dcosx - Esinx
y''' =216Be^6x + Dsinx - Ecosx
y'''' =1296Be^6x +Dcosx + Esinx
(1296Be^6x +Dcosx + Esinx) - 6(216Be^6x + Dsinx - Ecosx)=-5sinx
is this the correct way to set up this problem?
hils0005 said:
y^(4)-6y^(3)=-5sinx
This is a fourth order equation. The solution space of the homogeneous equation is a four[\b] dimensional vector space. You need 4 independent solutions to it and you only have 2. What do you do when you have a double or triple root to your characteristic equation?
Obviously the "1295Be6x" and -6(216Be6x)" terms will cancel out. When solving for a "particular solution", there is no need to carry the solutions to the homogeneous equation along. Just use y= A sin(x)+ B cos(x) and then, after you have found a particular solution, add it to the homogeneous solution.
you put in a faxtor of x and x^2 ?
y(c)= Ae^0 + Be^6x + Dxe^0 + Ex^2e^0
I used 0 because that would be consitent with the x^3 term-
y(c)=A + Be^6x + Dx + Ex^2
y(p)=Asin(x) + Bcos(x)
y'(p)=Acosx - Bsinx
y"(p)=-Asinx - Bcosx
y'''(p)=-Acosx + Bsinx
y""(p)=Asinx + Bcosx
(Asinx + Bcosx) - 6(-Acosx + Bsinx) = -5sinx
how can you solve this??
A(sinx + 6cosx) + B(cosx-6sinx)=-5sinx
Yes, that is correct for the homogeous equation.
y'(p)=Acosx - Bsinx
Better is to "combine like functions": (A- 6B)sinx+ (6A+ B)cos x= -5sin x
Now, since sin x and cos x are "independent" functions, The coefficients of like functions, on opposite sides of the equation, must be equal. That gives you two equations to solve for A and B.
two equations would then be:
1.(A-6B)sinx=-5sinx
2.(6A+B)cosx=0
1.(A-6B)sinx=sinx
A-6B=-5
-B/6 - 6B=-5
B=-30/37
6Acosx+Bcosx=0
6Acosx=-Bcosx
A=-B/6
A=-(-37/30)/6= 5/37
So general solution:
y=A + Be^6x + Dx + Ex^2 + 5/37sinx -30/37cosx
There seems like there is a different way to solve this??
