How Do You Solve a Limit as x Approaches Negative Infinity?
  • Thread starter Thread starter newguy_13
    Infinity Limit
15 replies · 4K views · last reply
newguy_13
Limit problem
There are none
I don't know what do do from here other than i can make the 3/e^x a 0 due to the fact its divided by such a large number. What do i do with the e^-3x? Thanks for the help
Handwritten limit work on lined paper: lim as x approaches negative infinity of (4e^(2x) - e^(-x)) / (3e^x - e^(2x)), then divided through by e^(2x), then lim as x approaches infinity of (4 - e^(-3x)) / (3/e^x - 1).
newguy_13 said:
Homework Statement: Limit problem
Homework Equations: There are none
The same. What happens to ##e^{-3x}## if ##x## gets larger and larger? What does ##e^{-sth.}## mean?
newguy_13 said:
So the answer is just -4?
You're looking for the limit as ##x## tends to ##-\infty##.
You must be careful if you cancel factors, as they can tend to zero and then you lose information which one is faster. It is always better to avoid divisions as long as possible. That means: Simplify the initial quotient by considering ##x \to -\infty##, then you get one single term ##e^{...x}## which tells you the result.
Ok so can you let me know what the answer is? That would help me to understand where i went wrong and what to do in the future problems. Thanks!
You took the limit ##x \rightarrow +\infty##.
Re helping you with the problem. The first thing I would do is look at each of the four terms and see what happens in the limit. The numerator should be clear, but you may need to take a closer look at the denominator.
I think that's what the OP has, but may have misread what he/she wrote in the 3rd line, where the limit part looks a bit like x -->-- ∞.
Yes, but the OP has calculated the terms based on ##x \rightarrow +\infty##.
Not finite. Look at the recipe in post #6, only two steps.
We have
[itex]lim_{x\rightarrow -\infty}\frac{4e^{2x}-e^{-x}}{3e^{x}-e^{2x}}=lim_{x\rightarrow -\infty}\frac{4e^{2x}-\frac{1}{e^{x}}}{e^{x}\left( 3-e^{x}\right) }=lim_{x\rightarrow -\infty}\frac{4e^{3x}-1}{e^{2x}\left( 3-e^{x}\right) }[/itex]
then [itex]\left( 4e^{3x}-1\right) \rightarrow -1[/itex] and [itex]\left( 3-e^{x}\right)\rightarrow 3[/itex] as [itex]x\rightarrow -\infty[/itex] but [itex]\frac{1}{e^{2x}}\rightarrow[/itex] ? as [itex]x\rightarrow -\infty[/itex]?
benorin said:
We have
##\frac {1}{e^{2x}}## will go to +##\ infty## as ## x \rightarrow \infty##. Denominator will become indefinitely small.
@WWGD I know this, I was attempting to walk the OP thru it. Sorry to highjack your thread, I just like to feel useful somehow. Cheers!
No problem @benorin
