How Do You Solve Equilibrium Problems in Physics?
  • Thread starter Thread starter jinman
8 replies · 4K views
jinman
I don't understand how to do equilibrium problems. I don't know how to set them up and where to start. here is an example. Can anyone please help?
A uniform thin rod of length 0.50m and mass 4.0 kg can rotate in a horizontal plane about a vertical axis through its center. The rod is at rest when a 3.0g bullet traveling in the rotation plane is fired into one end of the bullet's path makes angle = 60.0 degrees with the rod. If the bullet lodges into the and the angular velocity of the rod is 10 rad/s immediately after the collision, what is the bullet's speed just before impact.
1/2mv^2=1/2Iw^2
I=1/12ML^2
K-initial=K-final
1/2mv^2=1/2Iw^2
solve for v>>>>
v=sq. root[Iw^2/m]
v=sq. root[(1/12*ML^2)w^2/m]
v=sq.root.[(1/12*4.003*.50^2)*10^2/.003]
v=52.7m/s
The answer is 1.3*10^3m/s.
This is not an equilibrium problem (not sure what you mean by that, anyway).
I assume the bullet lodges itself in the rod, making this a perfectly inelastic collision. Kinetic energy is not conserved. But something else is. What?
I don't know why i put Equilibrium. It must be momentum.
P=P
mv=Iw??
P=P
mv=Iw??
Don't mix up linear momentum (p) with angular momentum (Iw). In this case, only one of them is conserved. Which one?
I would say linear.
m1v1=m2v2
v1=m2(wr)/m1
v1=4.003(10*.25)/ .003
v1*sin 60=2888.91m/s?
No, linear momentum is not conserved. I assume the rod is restrained by some fixed axis to only rotate about its center. That axis exerts a force on the rod, thus linear momentum is not conserved.
Ok.
I1w1=I2w2
w1=I2w2/I1
OK so I have to find the angular velocity of the bullet before the collision? How can i find the Inertia of the bullet?
http://hyperphysics.phy-astr.gsu.edu/Hbase/amom.html"
