How do you solve integrals with e to a power?
  • Thread starter Thread starter opeth_35
    Integral Mystery
37 replies · 5K views
opeth_35
actually, there ıs a something I don't understand about the e value
I could not figure it out this integral while solving for quantum physics, you will see the equation in figure. The problem is how We can make a solution about the e number while solving in integral.. Such as e power any number.. you wıll see in figure as well. I just wonder only how to solve problem which contain e number. I knew before about that, W
Excuse me, but I don't understand your question.
Please rephrase it, or write it mathematically and mark what you need to solve.
good luck.
hi opeth_35! :smile:
i too don't understand what you're asking :confused:
if you're asking how to solve ∫-∞ ue-λu2 du and ∫-∞ e-λu2 du, the first one is by substitution and the second one is a well-known definite integral which you have to learn :wink:
I could not complete my question sorry about that I think there is a problem about web. anyway.
If I tell my questıon to you again.. I don't understand how to calculate contain e number ( 2.7 )
this kind of integral questions. You wıll see in mpeg the sample of any question relevant that.
Is there anyone know about how i m going to solve this ?
i'm sorry, i still don't understand what you're asking :confused:
e is just like any other constant, the only difference is that d/dx (ef(x)) = f'(x)ef(x), while if we use a different number, A, instead of e, then d/dx (Af(x)) = (ln(A))f'(x)Af(x), which is more messy :smile:
( and ∫ f'(x)ef(x) dx = ef(x), while ∫ f'(x)Af(x) dx = Af(x)/ln(A) )
@opeth_35 I advise you to write your question in the language of mathematics.
:) :) I thınk I could not explain problem clearly.. I understand that added solve of questıon in mpeg but
when we take integral, then We need to put boundaries from minus infinite to plus infinite. Am I right? Actually, This point confused me.. I am putting minus infinite and plus infinite to solve but The answer is not like I found. I think I forgot something relevant e number how to solve this kind of boundries. Am I clear? :)
the important values are e0 = 1, and e-∞ = 0
in this case you have both ∞ and -∞, but it doesn't matter because they're both squared, so at both boundaries it's e-(∞)2, or e-(-∞)2, which are both e-∞ = 0 :wink:
like tiny-tim said :
e-(-∞)2 = e-(∞)2= e-∞ = 1/e = 1/∞ = 0
yes all of you are right that you showed me, the best way, I think It is going to be show you my solution..:)
Could you check a photo I added here?
I hope This will be clear. Please help
i'm sorry, opeth_35, this is completely wrong :redface:
∫ e-2ax2 dx is not e-2ax2/(-4ax) …
(differentiate the RHS, and you'll se you can't possibly get the LHS)
there is no elementary integral of e-2ax2 (though of course there is the "non-elementary" error function, erf(x), see http://en.wikipedia.org/wiki/Error_function" :wink:)
to integrate ∫0 e-2ax2 dx, you need to learn a standard trick:
multiply it by ∫0 e-2ay2 dy to get an ∫∫ dxdy, then convert to polar coordinates …
what do you get? :smile:
thank you for your propose :) I did not know before this kind of questions that was solved like that..
I will try to solve like you said :)
I multiplied dy function as you said but I can not move in progress. I see again similar wrong in process.. I am confused:(
show us your full calculations, and then we'll see what went wrong! :smile:
(btw, I'm afraid I'm going out in a few minutes, and i'll be out for the rest of the evening)
Your 1st image shows:
[tex]\left\langle x\right\rangle=A\int_{-\infty}^\infty xe^{-\lambda(x-a)^2}\,dx=\dots=A\left(0+a\sqrt{\frac{\pi}{\lambda}}\right)=a[/tex]
It's hard to figure what your question is even after reading all the posts in this thread.
I take it that A is a normalization constant.
Indeed, [tex]A\int_{-\infty}^\infty xe^{-\lambda(x-a)^2}\,dx=A\,\sqrt{\frac{\pi}{\lambda}}\quad\to\quad A=\sqrt{\frac{\lambda}{\pi}}\,,[/tex] which explains: [tex]A\left(0+a\sqrt{\frac{\pi}{\lambda}}\right)=a\ .[/tex]
If on the other hand you wonder how [tex]\int_{-\infty}^\infty e^{-x^2}\, dx=\sqrt{\pi}\,,[/tex] that's more involved.
SammyS, whatever are you doing?
You've just given him the complete answer. :redface:
Sorry Tim.
I was just trying to figure out the question. Let's see if it's not too late to edit.
FIXED it !
Tim, Thanks!
okey, I understand to solve but I have forgotten something in math.. I need to make a reputation about coordinate system..
thank you all:)
opeth_35 said:
hey
I think My problem is about coordinate systems, I still don't understand to turn -infinite to the number of pi..
Do u have any suggestıon about that:(
once again I'm not understanding you :redface:
show us the particular equation you're having difficulty with :smile:
You ll see in mpeg..
(jpeg, actually! :wink:)
ok, now put e-2ax2e-2ay2
= e-2a(x2+y2)
= e-2ar2
finally convert "dxdy" to polar coordinates :smile:
here we go, My problem is this.. polar koordinates.. I can not turn to each other. I have looked to book but, It ıs not clear.. It explains roughly..:(
you have to replace dxdy by rdrdθ …
see for example http://www.ltcconline.net/greenl/courses/202/multipleIntegration/doublePolarIntegration.htm" :wink:
... and then figure out the limits of integration in polar coordinates --- so that you integrate over the whole coordinate plane.
hey.. I stucked again in polar coordinates, any help?
-∞-∞ dxdy
is over all of x and y,
so in polar coordinates, that's all of r and θ, ie the limits will be 0≤r≤∞, 0≤θ≤2π :wink:
how do u know, the boundries for teta between 0 and 2pi , haven't figure it out?
and why is going from 0 to -ınfınıte for r, It could be from -infinite to +infinite ?
no, in polar coordinates, r cannot be negative, it is defined as being 0≤r<∞ …
likewise, θ is defined as being 0≤θ<2π :smile:
:) finally I found one value for solve , but the book shows different value, Could u check my calculate?
