How do you solve ratio problems like these?
  • Thread starter Thread starter roger12
    Ratio
The discussion focuses on solving ratio problems involving three variables A, B, and C. The first problem is solved, yielding the ratio A:B:C as 10:3:2. The second problem requires splitting the remainder of 5/8 into a 1:2 ratio for B and C. The third problem involves combining the ratios A:B=2:5 and B:C=10:11, necessitating adjustments to ensure compatibility. Participants provide insights on how to manipulate fractions and ratios effectively.
  • Understanding of basic fractions and ratios
  • Ability to manipulate algebraic expressions
  • Familiarity with common denominators
  • Knowledge of ratio comparison techniques
  • Learn how to solve compound ratio problems
  • Study methods for finding common denominators in fractions
  • Explore techniques for combining and adjusting ratios
  • Practice with additional ratio problems for mastery
Students tackling ratio and fraction problems, educators teaching mathematical concepts, and anyone seeking to improve their problem-solving skills in mathematics.
roger12
In each of the following the properties of a compound are given. In each case find A:B:C
1. 1/5 of A, 2/3 of B and the remainder of C.
2. 3/8 of A with B and C in the ratio 1:2.
3. A, B and C are mixed according to the ratios A:B= 2:5 and B:C=10:11.
I could only solve the 1st one:
The common denominator is 15 so 15/3*2=10 and 15/5*1=3. That means A and B are in the ratio 3:10.
15/15-13/15=2/15 so A:B:C are in the ratio of 10:3:2
Couldn't solve the other two. Please, help. Thanks.
Ok in Q2 you know that the remainder (B and C) make up 5/8. Can you show how to split 5/8 in the ratio 1:2?
Regarding Question 1:
I think you got the answer right but in the wrong order.
A:B:C
\frac{1}{5}:\frac{2}{3}:\frac{x}{y}
(\frac{3}{15}:\frac{10}{15}:\frac{2}{15})*15
3:10:2 == A:B:C
Regarding Question 2:
You need the provided fraction to become large enough that it's remainder is evenly divisible into three parts.
Regarding Question 3:
A:B:C is what you're trying to build, so look at the ratios A:B and B:C as puzzle pieces.
A:B is too small to fit in with B:C, so you simply need to make A:B larger for it to be congruent with B:C
Thank you for the answers.
