How does -9.2*m/s + 3.6 Kg become 2.6m/s?
  • Thread starter Thread starter superjoebob
The problem involves understanding the relationship between mass and velocity in the context of an elastic collision. Participants are discussing how to manipulate equations that include both mass and velocity to isolate a variable representing the new speed after a collision.
  • Mathematical reasoning, Problem interpretation, Assumption checking
  • Participants explore how to rearrange equations involving mass and velocity, questioning the interpretation of units like m/s and how they relate to algebraic manipulation.
The discussion is active, with participants providing algebraic insights and clarifications on the steps taken to isolate the variable. Some participants express confusion about the signs and units involved, while others attempt to clarify the algebraic process.
There is mention of a specific textbook example involving an elastic collision, and participants are navigating the implications of the equations presented, including the significance of the negative sign in the context of the problem.
superjoebob
The problem is that there are a bunch of physics equations were they end up with a number like 9.2 (then the dot that means times i think) and then m/s. How do I convert a number with both mass and speed attached to it to just a single number?
none that I know of
Ive got nothing
I also forgot to mention that m/s isn't a variable, its an empty thing that just seems to be attached to my numbers
Can you post an example..?
a child rolls a superball of mass of 0.025kg at a speed of 2.3m/s and it collides head on with a ball of 0.020kg. What are the new speeds of the 2 balls after collision?
m1=0.025
m2=0.020
v1=2.3m/s
newv1=?
newv2=?
There is no friction or any other force acting, its completely 1 dimensional. The collision is elastic.
Its a textbook example.
near the end it says
"0=-9.2kg*m/s + 3.6 kg*newv2, or newv2=0
Since newv2=0 corresponds to no collision, we must have:
0=-9.2kg*m/s + 3.6kg*newv2
newv2=+2.6m/s"
how do they get that!?
They took the 9.2 to the left hand side and divided by 3.6 to get "newv2". It's algebra.
but that comes out with negative 2.6, how does it become posotive?
It doesn't come out negative.
0 = -9.2 + 3.6x
When solving for x, you get a positive number.
because x moves left of the = sign?
Yes. You should refresh on your algebra skills before you attempt to do physics questions.
ok it all makes sense now :) thanks Snazzy. Its not that I don't know algebra its just that that random m/s threw me off
Doesn't matter which one moves. In the end after the algebra is done, you have two positive numbers.
Dividing by two positive numbers will yield to another positive number.
It changes sign because in order to solve for 'x', you need to isolate that term so you can perform multiplication by 1/3.6 .
Therefore:
0 = -9.2 + 3.6x
9.2 + 0 = 9.2 + (-9.2) + 3.6x
9.2 = 9.2 + (-9.2) + 3.6x ------ additive identity a + 0 = a
9.2 = 0 + 3.6x ----- additive inverse a + (-a) = 0
9.2 = 3.6x ---- additive identity
(1/3.6)*9.2 = (1/3.6)*3.6x
2.55 ~= (1/3.6)*3.6x
2.55 ~= 1*x -------- multiplicative inverse a/a = 1
2.55 ~= x ------- multiplicative identity 1*a = a
That's pretty much the algebra behind it. I mean I'm not sure that you were clear with that based off your replies though.
  • · Replies 26 ·
10K
