How does a current balance work?
A current balance measures the force exerted on a current-carrying wire in a magnetic field and is used to determine the mass needed for balance. To solve the practice problem, the equation F = BIL can be used, where B is the magnetic field strength in Teslas, I is the current in Amperes, and L is the length of the wire. The length of the wire is crucial for calculating the force, and without it, assumptions must be made, such as setting L to 1 meter for simplification. The weight of the mass (mg) must equal the magnetic force for the system to balance. Understanding units is essential for accurate calculations in physics problems.
Tangeton
< Mentor Note -- thread moved to HH from the technical physics forums, so no HH Template is shown >[/color]
I am looking for a very simplistic and understandable explanation for how it works as I don't seem to find any place that explains it well... I am just doing A Level which is equivalent to high school.
Also I've looked at a practice question in the book, and I've been given B (2.0x10^-3) and current (1.0A). I've been asked to find what the mass must be hanged on the other side in order for the system to be balanced, but I don't know how to since I haven't been given the length of the wire... I wanted to equate F = BIL (if I had the length) to the weight of the mass (mg) but I cannot do that unless I assume some sort of length. When I said l = 1 then I got 2.0 x 10^-4. There is no answer in the book... any ideas of how I'd approach this?
What's a current balance? Can you post a diagram or picture?
Also, it's best if you make a habit of carrying units along in your variables and calculations. When you say you are given "given B (2.0x10^-3)", what are the units?
Unit is the Tesla.
  • · Replies 39 ·
19K
