How does ||a + t(a/||a||)|| = (||a|| - t)?
3 replies · 2K views
Math Amateur
MHB
I am reading the book: Multivariable Mathematics by Theodore Shifrin ... and am focused on Section 3.1 Partial Derivatives and Directional Derivatives ...
I need some help with Example 3 in Chapter 3, Section 1 ...
Example 3 in Chapter 3, Section 1 reads as follows:View attachment 8587In the above text we read the following:" ... ... $$\lim_{ t \to 0 } \frac{ \| a + t \frac{a}{ \| a \| } \| - \| a \| }{ t } = \lim_{ t \to 0 } \frac{ ( \| a \| - t ) - \| a \| }{ t } $$ ... ... "
Can someone please explain exactly how $$\lim_{ t \to 0 } \frac{ \| a + t \frac{a}{ \| a \| } \| - \| a \| }{ t } = \lim_{ t \to 0 } \frac{ ( \| a \| - t ) - \| a \| }{ t } $$ ... ... ... indeed, specifically how $$\| a + t \frac{a}{ \| a \| } \| = ( \| a \| - t )$$ ... ...
Help will be appreciated ...
Peter
Hi Peter,
This is a nice question.
Example 3 in Chapter 3, Section 1 reads as follows:In the above text we read the following:" ... ... $$\lim_{ t \to 0 } \frac{ \| a + t \frac{a}{ \| a \| } \| - \| a \| }{ t } = \lim_{ t \to 0 } \frac{ ( \| a \| - t ) - \| a \| }{ t } $$ ... ... "
Peter
The short answer is that $\left\| a+t\dfrac{a}{\|a\|}\right\|=\|a\| +t\dfrac{\|a\|}{\|a\|}=\|a\| +t$ because $a$ and $\dfrac{a}{\|a\|}$ point in the same direction and $a$ is a unit vector. There is no need to think about vectors in the plane or some higher dimensional space to justify this. Think about two positive numbers--say $x$ and $y$--on the real line added together. As vectors both positive numbers point to the right, so $|x+y|=|x|+|y|.$ In other words, two vectors sitting on a line are two vectors sitting on line, regardless of whether that line is in 1, 2, 20, or $n$ dimensions.
If that explanation doesn't cut the mustard, so to speak, then it can be rigorously shown by calculating the norm via the dot product: $$\left\|a+t\dfrac{a}{\|a\|}\right\|=\left[\left(a+t\dfrac{a}{\|a\|}\right)\cdot \left(a+t\dfrac{a}{\|a\|}\right)\right]^{1/2}.$$
Alternatively, $\left\| a+t\dfrac{a}{\|a\|}\right\|= \left\|\left(1+\dfrac t{\|a\|}\right)a\right\| = \left|1+\dfrac t{\|a\|}\right|\|a\| = \left(1+\dfrac t{\|a\|}\right)\|a\| = \|a\|+ t$, provided that $t>-\|a\|$ (so that $1+\dfrac t{\|a\|} > 0$).
GJA, Opalg ... thanks for the help ...
But ... just a clarification ...
Why is it critical/necessary that $1+\dfrac t{\|a\|} > 0$ in order for $$\left\| a+t\dfrac{a}{\|a\|}\right\| = \|a\|+ t$$ ... ... ?EDIT: OK .. sorry... it's obvious... no problem ...
Peter
