How does a urinary catheter work?
  • Thread starter sameeralord
    Work
2 replies · 10K views · last reply
sameeralord
Hello everyone,
Labelled diagram of a urinary Foley catheter: a balloon port with a 10 ml marking, a size marking of 18 Fr / 6.0 mm, a urine drainage port, a balloon inflated near the tip, and the bladder opening at the far end.
1) Now in this catheter, how does passing saline through the balloon port inflate the ballon. Are there pores at the end of the tube, which allows fluid to go into the balloon and inflate it.
Two three-way urinary Foley catheters lying side by side on a blue background, each with two clear balloon inflation ports near the tip and a Y-shaped drainage end with two arms.
1) What is the purpose of a 3 way catheter. If you want to clear out an infection I can understand you can send saline through one of the ports, but can't we do the same thing with a 2 way catheter. If we send saline through the balloon port in a 2 way catheter, wouldn't it fill the bladder after inflating the balloon and clear it.
2) Why does a 3 way catheter have 2 ballons as shown in pic.
sameeralord said:
Hello everyone,
Labelled diagram of a Foley urinary catheter with a balloon near the tip, a balloon port marked 10 ml, a urine drainage port, a size marking of 18 Fr / 6.0 mm, and a bladder opening at the tip.
Two three-way Foley urinary catheters laid side by side on a blue surface, each with two inflated clear balloons near the tip and a forked end with three ports.
The saline would only enter the bladder with the two way catheter after the balloon has burst. :eek: At that point there is no inflated balloon to keep the catheter in place.
The two way catheters have a tube within a tube. The three way has two tubes within a tube. The are called channels or lumens in medical speak.
http://en.wikipedia.org/wiki/Foley_catheter
