How does a vacuum pump push gas out of a container?
A vacuum pump operates by using a piston to increase the volume of the pump barrel, allowing gas, such as air, to rush from the container into the barrel, thus reducing the gas amount in the container. It cannot completely evacuate the gas, only asymptotically approaching a vacuum. At very low vacuum levels, additional methods like the Getter system and Diffusion Pump are employed to push remaining gas molecules out. The effectiveness of these systems depends on the gas flow characteristics, which include Viscous Flow, Transition Flow, and Molecular Flow.
  • Understanding of vacuum pump mechanics
  • Knowledge of gas flow characteristics: Viscous Flow, Transition Flow, Molecular Flow
  • Familiarity with Getter systems and Diffusion Pumps
  • Basic principles of pressure and vacuum technology
  • Research the operational principles of the Getter system in vacuum applications
  • Learn about the mechanics and applications of Diffusion Pumps
  • Study the differences between Viscous Flow, Transition Flow, and Molecular Flow in vacuum technology
  • Explore advanced vacuum generation techniques and their industrial applications
Engineers, physicists, and technicians involved in vacuum technology, as well as anyone interested in the principles of gas evacuation and vacuum systems.
Intle
Precisely how does a vacuum pump take the gas, let's just assume air, out of a container?
It can't take all the gas out. What it does is reduce the amount of gas in there. It does it by using a piston to enlarge the combined volume of the container plus the pump barrel without admitting any extra gas. The pressure equalises by gas rushing out of the container into the barrel. As the piston returns to the closed position, a valve between the container and the piston barrel prevents air in the piston barrel from re-entering the container, and a valve in the piston barrel then makes the gas in the barrel go out to the atmosphere.
If the open barrel has the same volume as the container, then every time the piston is pulled out, the amount of gas in the container is halved.
So it is never possible to remove all the gas from the container. It can only asymptotically approach vacuum, and physical constraints set a limit on how closely it can approach.
When you get down to very low vacuum, the methods of reducing pressure further are a bit more like ' pushing'. The 'Getter' system, used in old CRTs uses a reactive metal pellet that's vaporised by RF heating. The vapour passes through the (already low) vacuum, at speed and sweeps (pushes) the few remaining molecules across the tube and they get stuck permanently on the inside of the glass envelope. A Diffusion Pump does a similar thing by passing a fine stream of Oil particles through the vacuum, which sweeps away most of -what's left from the conventional pump (again, pushing remaining rubbish away). None of the low pressure systems will work until a conventional pump (suction style) has reduced the pressure to a pretty low value
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 30 ·
16K
