How does an atomic element jump the Quantum fence?
8 replies · 3K views · last reply
jusme
I am at loss to understand (from a layman's point of view...with some math-stuff, too) how an element's electron(s) can jump the quantum fence. An element, any element, as shown on the periodic table, has certain characteristics within its 'earthly' domain, the 3-D world we live in. What causes the electron(s) of this element to jump the fence...the area that lies in between the quantum domain and our everyday 3-D domain? Please excuse the way in which I am putting this question across, but for me, right now, it is the best I can muster up for the moment.
Is there a certain 'something' that pushes or pulls an electron(s) across the quantum barrier? Is there possibly a quantum periodic table of the elements?
I had asked this of someone versed in chemistry and was told to look into 'Cooper pairing', being naturals, Linked and twin-Linked pairs. For now I will gladly accept an asnwer to the question I just put up.
I would greatly appreciate a point in a good direction for more information to satisfy my own curiousity.
Thank you for reading this!
Regards,
Justme
There is no quantum fence/barrier that electrons jump to enter some new quantum world. Where did you get this idea ?
Some time ago I read a book by Deepak Chopra where he was discussing how the human body could (seemingly) produce what it needs to fullfill a need for a particular state of bodily health...from what appeared to be out of nowhere; neural transmitters/endomorphines, etc. seemd to magically materalize when needed! An endlss supply from what appeared to be a mystical horn-of-plenty. The author used simple graphices to illustrate his point by showing a line where the area above the line was the real physcial world, and that under the line represented the mysterous area from which the material(s) came from. Hence the so-called quantum leap of a material over a fence (the drawn line in his illustration).
The only thing with barriers with electrons that I know of is about electron tunnelling.
Signlalling hormones in the body don't just 'pop up', they are part of complex chemical reactions creating them.
I would strongly suggest that you do not use Deepak Chopra as a "source" to explain any physics. Metaphysical mysticism also is not physics, and does not belong in this part of PF.
Zz.
Your question here is a rather vague. From what I can gather, you are trying to figure out where is the boundary between quantum and classical world. If it is, then I'm highly confused why you only concentrate on "electrons", since these aren't the only particle, or even system, that are governed by QM description.
But then again, it could be interpreted as you wanting to know how electron tunnels, or how they jump from being in atomic orbitals to free particles, etc... etc. I'm not sure if any meaningful responses can come out of this till there's something clearer.
Zz.
Much thanks to ZapperZ and echoSwe for their time (and trouble) trying to give an answer to the original question I posted. It would be best for this thread to end right here...and for me to head on out to Physcis 101.
Thanks for your help.
Jusme
Since the OP question seems to relate to biochemistry, maybe this helps
In "normal" chemistry the formation of a molecule requires a specific activation energy.
In biological systems (and other setups - see catalyst) the same reaction occurs without supplying that activation energy.
Generally this is due to forced reactant alignment allowing quantum tunneling to occur.
I suppose you could call this something for nothing.
However
Quantum tunneling is not unique to biological systems, almost anything electronic requires tunneling for it to work.
Jusme
This is truly heartwarming to read. All the best !
