How Does Angular Momentum Conservation Affect Asteroid Collision Dynamics?
335 replies · 22K views
Hak said:
So, is this equation wrong? Do you confirm? Thank you.
Does it lead to the correct result? Anyhow it doesn't matter what I say, because you are just going to say, "ok, but lets wait for someone else to confirm".
erobz said:
You didn't look. Read though the 238 post prior this from the beginning. They are in there.
Is it in post #178?
Yes, but as you said, it is very likely that the angular momentum is conserved only with respect to the center of mass of the system. So how is it possible that the expression of ##\omega## is correct? I cannot explain how this is possible, while then my friend considers ##R## instead of ##d##. Thank you.
No, I did not explain myself. I don't mean that I would like to wait for someone else to confirm, I simply mean that I am waiting for confirmation from others as well. If many people will say that this option is correct, then it will be reasonable to think that it is. I agree with you, however. Only, I cannot explain these discordances. Sorry if you were offended, that was not my intention.
My advice... let your professor explain it to them... or you can show them the thread in which it was explained to you?
erobz said:
My advice, let your professor explain it to them... or you can show them the thread in which it was explained to you?
I can't understand what you mean. However, even the author of the problem (he is not really my professor) seems to have doubts. It was just to get a complete overview of the possibilities of this problem.
Why are they authoring problems they have doubts about?
Why bring up all your friends interpretations in every problem then? You can just tell them about PF forums, and they can see for themselves?
You are right, but they don't feel like it. They prefer me to report their interpretations. Sorry if I am annoying, that is not my intention. I just try to help others and always learn more from those who know more than me.
I have no idea. The author seems to me to be a very good professor, but he does not know all the possible solutions of his own problems. He works them out over time, making various observations and attempts.
Hak said:
Thank you, that's very comforting to me. Could I know what method you used to arrive at this result? How did you get there through the expansions?
$$\begin{align} & I_{cm}=\frac{2}{5}MR^2+\frac{Mm}{M+m}R^2 \nonumber \\
& I_{cm}=\frac{2}{5}MR^2\left(1+\frac{5}{2}\frac{m}{M+m}\right) \nonumber \\
\end{align}$$When ##m<<M~## you can approximate in the denominator ##M+m\approx M##. Hence $$I_{cm}\approx\frac{2}{5}MR^2\left(1+\frac{5}{2}\frac{m}{M}\right).$$
erobz said:
##\dots## but I believe it was also stated by @kuruman that angular momentum is only conserved about the systems center of mass.
I never stated or implied that. In post #178 I conserved angular momentum about the center of the planet, not about the CM, and showed that you end up with the same equation for ##\omega.##
Ah, this is a big problem. I agreed with @erobz, but at this point, I can't really understand why my friend is wrong, mistaking ##d## for ##R##. Why? Sorry to persist with this kind of soap opera....
I don't mean to misquote you...I could have sworn you said that talking about angular momentum not being conserved for a differential mass ##dm## away from the center of mass axis. Maybe I'm imaging it.
EDIT: ( yeah, scrolling though the saga, I don't see it ...very sorry for the misquote)
Ok, thank you, but...
Hak said:
Moreover, you had said that the same result as ##\omega## would be arrived at without preliminary simplifications. By using ##\omega = \frac{L}{I_{cm}}##, with ##I_{cm}## simplified moment of inertia, you arrive at the result ##\omega = \frac{5mMv}{(2M + 5m) R}##, which does not correspond to the correct one. Try redoing the calculations, most likely I am wrong, however, I would like to understand it more. Thank you very much.
What about it, @kuruman?
But where then is that to be applied? If that ##\omega ## was to be applied about ##O## then ##F = m \omega^2 R ## This is the crux of the issue with the @Hak friends solution to the problem.
This is exactly what I wanted to say... It's really a dilemma...
erobz said:
But where then is that to be applied? If that ##\omega ## was to be applied about ##O## then ##F = m \omega^2 R ## because this is the crux of the issue with the @Hak friends solution to the problem.
The algebra for finding ##\omega## in post #206 is quite correct and involves no approximation. But as you note, for finding the force, we must decide what radius to use.
Note that whatever force is exerted on m, an equal and opposite force is exerted on M. I think that makes it clear that the correct radius to use is the distance to the common mass centre.
Reply
Thank you, but what is the connection between Newton's Third Law and the choice of the most appropriate radius to use? Thank you if you would like to answer.
I don't know the details of Newtons Third Law argument, but for me it is clear that masses are orbiting their common center of mass, just like we expect of any other composite body freely rotating.
Yes, it is correct to me. However, I don't understand what this has to do with the Newton's Third Law argument...
I view this as a single rigid body rotating in space with angular velocity ##\vec {\omega}.## It follows that mass element ##dm## at any point P on the body at position vector ##\vec {r}'_p## relative to the CM will have velocity (also relative to the CM) ##\vec v'_p=\vec {\omega}\times \vec {r}'_p##. Now if the CM is moving relative to a point in an inertial frame with velocity ##\vec V_{cm}##, the velocity of P relative to the inertial frame will be $$\vec v_p=\vec V_{cm}+\vec v'_p=\vec V_{cm}+\vec {\omega}\times \vec {r}'_p.$$The centripetal force on mass ##m## is ##\vec F_c=-(dm) \omega^2 \vec{r}'_p.##
This would imply that since the minor asteroid is a homogeneous body, it has mass ##dm = m##? And also that ##r'_p = d##?
No, ##dm## is a very small mass at position ##\vec {r}'## relative to the center of the planet. Imagine chopping up the composite body into many little pieces. ##dm## is the mass of the little piece that you will find at position ##\vec {r}'##; it could be small piece of the asteroid or a small piece of the planet. The only thing you can say is that $$\int dm=M+m.$$
OK, so yours is just a general overview of the physical situation. The result of ##F## you wrote does not lead to the form we found earlier, right?
At this point, with 264 posts and counting, I have no clue what form you are referring to. Please post it here so that I can see what you mean.
##F = m \omega^2 d##
There's a symmetry here. Each body is pulling the other towards the common mass centre. If that is displaced d from M's centre then ##m(R-d)=Md##, hence##m(R-d)\omega^2=Md\omega^2##.
OK, thank you very much. I cannot understand, however, how it can be deduced from this symmetric equation that ##d## is the radius to be chosen for the rotation. Sorry if I don't fully understand...
Isn't it simpler to note that any point on the composite rigid object rotates about the CM with constant angular velocity ##\vec{\omega}##? Then that point has centripetal acceleration ##\vec a_c=-\omega^2 \vec {r}'## where ##\vec {r}'## is the position vector relative to the CM. Thus the net force on mass element ##dm## is ##\vec {F}_c=-(dm)\omega^2 \vec {r}'.##
Yes, I see now what you are asking. The general expression for the force at any point is ##\vec {F}_c=-(dm)\omega^2 \vec {r}'## where ##\vec {r}'## is the location of the point relative to the CM. The asteroid is at location ##\vec {r}'=\vec d## and has mass ##dm = m##. So the force on the asteroid is $$\vec {F}_c=-m\omega^2 \vec {d}.$$
