How Does Changing Slit Separation Affect Wavelength in a Two-Slit Experiment?
  • Thread starter Thread starter conniechiwa
    Interference Slit
11 replies · 3K views
conniechiwa
An optical two-slit experiment is setup with its slits separated by 40 X 10-3 cm and produces a second order maximum at an angle of 0.09 degrees. What would the wavelength of the light need to be if we kept the position of the second order maximum the same, but increased the slit separation of 63 X 10-3 cm?
wsinϑ=mλ
630000nm*sin0.09=2λ
λ=494.8nm
I'm almost positive that this is right, but the system won't accept my answer. Please help me!
It asks for the answer in nm. I tried adding the final slit separation to the original and it didn't work either.
Yeah it says 63 X 10-3 cm. I copied and pasted the question.
That highlighted word doesn't seem correct. Is it "to" or "by", by any chance?
It's online homework. Maybe it's glitched.
the equation you are looking for is;
sin[tex]\theta[/tex]=n[tex]\lambda[/tex]/2d
[tex]\lambda[/tex]=(2d)sin[tex]\theta[/tex]/n
"two-slit experiment is setup with its slits separated by 40 X 10-3 cm"
--this being two-slit means it is 2d
:confused: All you've done is taken the standard formula and renamed the slit separation 2d instead of the usual d.
