How Does Closing a Switch Affect Capacitor Charge Over Time?
  • Thread starter thunderhadron
    Charging
53 replies · 9K views · last reply
thunderhadron
The Problem is as follows :-
https://fbcdn-sphotos-a.akamaihd.net/hphotos-ak-snc6/250882_2277870163529_994629362_n.jpg
In the figure shown initially the switch is open for a long time. Now the switch is closed at t = 0. Find the charge on the rightmost capacitor as a function of time. Given that it was initially uncharged.
& The attempt at a solution[/B]
When the switch is open if we talk only about the first capacitor (Left one), it is connected to the battery for a very long time hence it is fully charged and the potential difference between its plates become the potential difference of the battery. When the switch is closed at t = 0, the resistance of the capacitor (right one) is zero hence the total charge will flow only in the outward circuit. Hence it is surely the charging of the right one capacitor and hence its equation will become as q= cV(1-e^(-t/RC) ) which is quite obvious. But there is big problem the left capacitor was charged for a very long time and we can assume that now it’ll behave like a battery. There’ll be discharging of left capacitor and charging of right capacitor. The net charge on the right capacitor will be due to both – the battery and the discharging current of the left capacitor. Now how to proceed for the charge from the left one capacitor. Or m I doing wrong in this method, Should I go for some another method I am pretty confusion in doing this.
Please friends help me in solving this issue.
The answer of the question is as follows:
q= cV/2 (1-1/2 e^(-t/RC) )
When the first capacitor is fully charged it will not be to the battery emf.
The 2 resistors form a potential divider across the battery. Do you see what I mean?
Thunderhadron,
In some of your equations you use a lower case "c", and in others, you use a upper case "C". What is the difference?
You need to discern what the voltage the two caps have immediately after the switch is closed. Until you know that, you won't be able to solve your problem. It is an initial condition.
Ratch
Ratch said:
Thunderhadron,
For the left capacitor it'll be discharging and for the right capacitor it'll be charging.
Hence the equations are as follows:
For the left capacitor:
V= v0 e-2t/RC
And for the right cap:
V = V0 e -t/RC
Now how to add these voltages after that.
Thunderhadron,
When the switch closes, and the left cap energizes the right cap, the path the charges take does not go through R. Therefore R should not be a consideration for the initial voltage after the switch closes.
Ratcfh
thunderhadron, look at the official answer …
q= cV/2 (1-1/2 e-t/RC )
from that, you can see that the charge on the right capacitor starts (t = 0) at CV/4, and ends (t = ∞) at CV/2
how could you find those two results if you weren't given them? :wink:
So what should I think, the given anwer of the problem is incorrect?
The given answer is correct. Upon switch closure, the two caps share their charge and thereafter act as one large capacitor.
Well, I m not getting one thing and that is before closing the switch the left capacitor is fully charged and charge on it is CV after closing the switch this charge will distribute on both as CV/2 & CV/2
But after closing the switch and long time after the right capacitor will also be fully charged and charge on it should be CV but as the answer indicates q= cV/2 (1-1/2 e-t/RC ), the maximum charge on the capacitor is CV/2.
How it is happening?
Can you explain how you arrived at CV?
hi thunderhadron! :wink:
thunderhadron said:
Well, I m not getting one thing and that is before closing the switch the left capacitor is fully charged and charge on it is CV …
no
as truesearch :smile: says …
… the circuit is the same as
Hand-drawn circuit schematic: a battery labelled Vin on the left, feeding a series path through resistor R2 at top and resistor R1 below it, with a voltmeter labelled Vout connected across R1.
so what will the voltage across the "second" resistor be? :wink:​
(this question seems to be from page 6 of http://www.scribd.com/doc/49913344/capacitor-sheet, #II Q.16)
no
Circuit schematic: a battery labeled Vin on the left branch, with resistor R2 in the top-right branch and resistor R1 below it in the right branch, and an output voltage Vout measured across R1.
Ok I got it so the voltage across left capacitor is V/2 so maximum charge on it before the switch closure is CV/2. and after closing the switch the right capacitor is also in parallel with the left capacitor hence its max voltage will be V/2 and max charge on it will be CV/2.
Thank you friend for making me understand this. But I still don't get the correct answer. as for the value of time constant somewhere I read just short circuit the battery and solve.
When I short circuit the battery the two resistors are in parallel hence R/2 and the cap. are in parallel hence 2C. Hence the time constant is RC.
But from where this 1/2 is appearing on the answer.
(1-1/2 e-t/RC )
thunderhadron said:
Ok I got it so the voltage across left capacitor is V/2 so maximum charge on it before the switch closure is CV/2 …
yes :smile:
nooo :confused:
that makes a total charge (on both capacitors) of CV …
where has the extra charge come from?? :redface:​
Hi tiny-tim!
Fiend I don't get this. Well Isn't the charge on right capacitor CV/2. Well the extra charge might come from the battery. After closing the switch the right cap is also connected with battery.
Isn't it so?
Please don't mind my foolish questions.
thunderhadron said:
… the extra charge might come from the battery. After closing the switch …
no, i don't mind at all …
you're now stating your understanding clearly, and that makes it easy to help you :smile:
(your original post, unfortunately, did not reveal how you got there :redface:)​
no, the charge can't come from "outside", it would have to pass through the resistors in an "infinitely" short time, which makes it an "infinitely" large current and power
impulsive currents can't go through resistors
when the switch is suddenly closed, the total charge on the capacitors is (temporarily) stuck there :wink:
Yes I get this after a very long time as the question states the left cap is fully charged hence no charge will flow through it. hence after the switch closing all the charge will flow through the right cap. and the ckt will look like as you posted in post #11.
The same situation will happen for solving the potential through it with the right cap. But at this instant what is the role of left cap.?
ahh! that's where you're going wrong …
no charge will flow into it
but charge can flow out of it! :wink:​
Yes and out of it there is right cap which is totally uncharged before the closing the switch. so the circuit will look like the same ckt as you showed me.
And the P.D. across the right capacitor will become V/2 due to battery. M I going wrong?
yes the voltage across the two capacitors will be the same so long as the switch is closed (and will be the same as across the "second" resistor)
so what are the charges on each capacitor when the switch is first closed?
As the voltage across the two capacitors and the second resistor is same as V/2 then the charges on both the capacitors according the relation Q = CV are CV/2 & CV/2
no, if the charge on the left capacitor was CV/2 immediately before closing the switch (and 0 on the right capacitor), how can it be CV/2 on both capacitors (total of CV) immediately after?
the total charge has to be the same … impulsive current cannot flow through resistors
(the maximum possible charge, ie the relation Q = CV, is irrelevant)
Do u mean to say that the charge on both will become CV/4 ?
yes … it's the same total charge, and the capacitances are the same, so it will be equally distributed :smile:
does that make the rest of the problem clear?​
OK.. I am getting this. But please tell me one thing: At the time of closing the the switch the right cap is connected with left capacitor hence the charge distribute equally on both. Bit the right cap is also connected to the battery at this instance so what is the role of battery at the moment?
thunderhadron said:
… Bit the right cap is also connected to the battery at this instance so what is the role of battery at the moment?
at that moment (between "immediately before" and "immediately after" the switch closes), the battery and the resistors have no role …
the battery and the resistors need time to do anything, but the charge rearranges itself "instantaneously" …
comparing it with mechanics: the switch gives an impulsive force, and non-impulsive forces (such as gravity, or the battery) have no role​
But some times when I solve some problems of charging- discharging, take the example of a simple circuit when a cap and a resistor are connected in parallel and a battery is connected with this circuit in parallel.
Many times the problem says at the instance of closing the switch : Current will have two ways on the junction of resistance and cap. but the current will flow through capa at that time, it acts like zero resistance or superconducting wire at t = 0 but the time goes on the cap stores charge by leaps and bounce and resistance of it keeps on increasing.
And after a very long time when it gets fully charged it no charge flow through it, it acts like
R→∞.
Is this wrong, so please tell me what is the actual concept but mind one thing I've solved ample number of problem keeping this concept in my mind, If you want I can show you some examples.
That's correct. The capacitor offers very low impedance under those circumstances. But if there is a resistance in series with the capacitor. then that resistor limits the current and hampers the capacitor in doing what it might otherwise do. Only where the effective series resistance is very low can the capacitor branch act like a "short circuit". You have to examine the circuit very closely to see which resistances are in the relevant charge/discharge current paths and under which circumstances.
thunderhadron said:
… at the instance of closing the switch : Current will have two ways on the junction of resistance and cap.
i don't understand that :confused:
… but the current will flow through capa at that time, it acts like zero resistance or superconducting wire at t = 0
you do know that no current ever flows through a capacitor?
talking about the "resistance" of a capacitor is just an analogy
a capacitor does not have a resistance (R), it has a reactance
ie it is not Ohmic, with I proportional to V, it is reactive, with I proportional to dV/dt
(you mean "leaps and bounds"?)
no, the charge flows smoothly …
it starts fast, and ends slow, but the change is smooth
immediately after you close the switch, the charge on the capacitor is still zero, but the rate of charge is non-zero​
I am sending you an img. http://img3.orkut.com/images/milieu/1340682480/1340707691932/204964818/ln/Zt96paa.jpg?ver=1340707704
Well I mean to say that at the instance of closing the ckt the current has two ways at point c, one from capacitor link and another from resistor through wire cd. So the resistance sorry capacitive reactance of the topmost capacitor is very less at this time hence the charge will flow form capacitor.
Friend please make me understand some according to this fig. Is this fig is correct. Will the ckt look like this?
