Johnny5454
- 31
- 1
When we touch something, will there always be a layer of air between us?
The discussion centers on the atomic interactions that occur when two surfaces, such as human skin and a solid object, come into contact. Initially, there is a thin layer of air between the surfaces, which is gradually squeezed out as contact is made. The interaction at the atomic level is primarily governed by electromagnetic forces, where the electron clouds of the atoms repel each other, preventing direct contact. The phenomenon is further complicated by factors such as surface cleanliness and the presence of moisture, which can affect the time it takes for air molecules to be expelled.
PREREQUISITESThis discussion is beneficial for physicists, materials scientists, and anyone interested in understanding atomic interactions and the principles governing contact forces at the microscopic level.
How long will it take before there is air left between my hand and the surface?sophiecentaur said:Hi and welcome to PF.
Good question. The answer is that it will depend on the time elapsed. Initially there will be partial contact, with gaps (bubbles even) with air in them. After time, the skin will come together and gradually squeeze most of the air molecules out. But there will always be some trace molecules in there, until they are absorbed by the skin and the moisture between the fingers.
This is a phenomenon with touching metal surfaces. In air, they have a very thin layer of air and associated 'grot' which keeps them separate, usually and if they are not scrupulously clean. Metals in a high vacuum, as in spacecraft can weld themselves together once all the surface impurities have evaporated. Hatches can weld shut - which is a potential problem. Scary.
Try this:Johnny5454 said:1) when a person’s fingers touch the surface, will the atoms of the fingers directly interact with the atoms of the surface, or is there a layer of air between them that will prevent contact? Since air atoms are everywhere. 2) How does contact with the surface occur? Does Pauli's principle of exclusion take effect immediately or do electrostatic forces first act?
Johnny5454 said:Does Pauli's principle of exclusion take effect immediately or do electrostatic forces first act?
I can't help thinking that, if that were the case, your fingers would actually stick together. But I guess we are talking about different time scales. I'd bet it would take many minutes before all traces of 'air' molecules went away and that would be due to absorption of the skin. Living tissue is a difficult substance to discuss. (Even the proteins in chopped meat will tend to recombine and the chunks can 'stick together'. )fresh_42 said:No layer of air. The atoms of finger and table interact directly, in the sense that the electron hulls repel each other. There is normally no exchange of electrons, hence Pauli doesn't apply.
Good questions. Consider just two atomsetotheipi said:How do these two different explanations mesh together? I apologise if I made a mistake, I don't really know anything about this.
The OP was asking "at the atomic level"sophiecentaur said:The answer is that it will depend on the time elapsed. Initially there will be partial contact, with gaps (bubbles even) with air in them. After time, the skin will come together and gradually squeeze most of the air molecules out. But there will always be some trace molecules in there, until they are absorbed by the skin and the moisture between the fingers.
hutchphd said:The repulsion which worries you is really quite subtle. Because these interactions are between electrically neutral atoms, the exact distribution of the charge becomes more important. The net effect of Pauli is to make electrons vacate the space between the nuclei. This makes the repulsive effect of the coulomb repulsion very much stronger at short interatomic distances than it would otherwise be. This is an "exchange mediated" effect.
etotheipi said:I hope someone can shed some light on it.
davenn said:Did you watch the video in post #9 ?
well their discussion and "arguments" pretty much tells you the issues being dealt with.etotheipi said:Yes, that was where I got the idea for the question from. Plus, it was sort of weird when they started bickering at the end. In any case, I would like to learn a bit more about the details.
etotheipi said:electron degeneracy pressure?
etotheipi said:As far as I know, this would also be an exchange mediated effect (and Wikipedia tells me Dyson showed its not because of electrostatic repulsion)
hutchphd said:fred
I guess I would call this a "direct exchange effect" but let us not quibble about semantics.
So I would simply say that both effects exist and their relative importance depends upon the circumstance.
I presume you understand the gist of Dyson's argument. I think it is essentially that
##\frac { \partial E_f } {\partial Volume } ## is a pressure ?
Johnny5454 said:When we touch something, will there always be a layer of air between us?
I thought so too. Maybe an Insights?ZapperZ said:Don't we have a FAQ on this question already?
when a person touches another person, do the atoms of his fingers really come into contact with the atoms of the skin of another person or will there always be an air layer between them, because air is everywhere. Some say that skin atoms can stick together, but if they come in contact directly?ZapperZ said:Don't we have a FAQ on this question already? If we don't, we should.
Zz.
You've gotten a lot of good replies in this thread already. Have you read them? In particular, did you watch the video posted by @A.T. in post #9?Johnny5454 said:when a person touches another person, do the atoms of his fingers really come into contact with the atoms of the skin of another person or will there always be an air layer between them, because air is everywhere. Some say that skin atoms can stick together, but if they come in contact directly?
I would like to clarify, when a person touches another person, do the atoms of the hand come into contact with the atoms of the skin of another person, or will there be a thin layer of air around all the objects that will impede the contact between the atoms of the hand and the atoms of the skin of another person? Or will almost all of the air be pushed out and there will be direct contact? thanksophiecentaur said:I can't help thinking that, if that were the case, your fingers would actually stick together. But I guess we are talking about different time scales. I'd bet it would take many minutes before all traces of 'air' molecules went away and that would be due to absorption of the skin. Living tissue is a difficult substance to discuss. (Even the proteins in chopped meat will tend to recombine and the chunks can 'stick together'. )
Johnny5454 said:I would like to clarify, when a person touches another person, do the atoms of the hand come into contact with the atoms of the skin of another person, or will there be a thin layer of air around all the objects that will impede the contact between the atoms of the hand and the atoms of the skin of another person? Or will almost all of the air be pushed out and there will be direct contact? thank
Hello, you are a very good physicist and I respect you and respect your answers.ZapperZ said:It's like talking to a wall.
Zz.
Can I clarify? That is, between the hand and the skin there will always be some molecules of air or water, but there will be places where the skin atoms will directly interact with the atoms of the hand without any air between them?sophiecentaur said:I can't help thinking that, if that were the case, your fingers would actually stick together. But I guess we are talking about different time scales. I'd bet it would take many minutes before all traces of 'air' molecules went away and that would be due to absorption of the skin. Living tissue is a difficult substance to discuss. (Even the proteins in chopped meat will tend to recombine and the chunks can 'stick together'. )
