charan1
- Messages
- 40
- Reaction score
- 0
A 3.0-kg lamp is suspended by a wire from the ceiling of an elevator. What can you conclude about the
tension in the wire under each of the following circumstances? (Give a numerical result, or a range of possible
numerical results, or if you can’t conclude anything about the tension in the wire, say so explicitly. Justify your
response in each case.)
a. The elevator is moving downward with a constant speed of 6.0 m/s.
b. The elevator is moving upward with speed of 6.0 m/s, and slowing down at a rate of 2.0 m/s/s.
c. The elevator is moving downward with speed of 6.0 m/s, and slowing down at a rate of 2.0 m/s/s. (3 pts)
F=ma
a: ma=Tension-mg
(3kg)(0m/s2)=Tension-(3kg)g
Tension=29.4N
b: ma=Tension-mg
(3kg)(2m/s2)=Tension-(3kg)g
Tension=35.4N
c: ma=Tension-mg
(3kg)(-2m/s2)=Tension-(3kg)g
Tension=23.4N
I'm not sure if I even did this right please check it out!
