How Does Gauss' Law Apply to Complex Cylindrical Charge Distributions?
The discussion revolves around applying Gauss' Law to a complex system of cylindrical charge distributions, including an infinite line charge and multiple conducting shells. Participants are exploring the electric field and induced surface charge in this context.
  • Mixed
  • Participants discuss the calculation of the electric field at a distance from the line charge, questioning the assumptions made about charge densities and the application of Gauss' Law. There is also exploration of the induced surface charge on the conducting shells and the implications of net charge on the system.
Some participants have provided calculations and reasoning regarding the electric field and induced charges, while others have offered confirmations and further questions about the assumptions made. Multiple interpretations of the charge distribution and its effects are being explored.
Participants are working under the constraints of a homework problem, which may limit the information available for fully resolving the questions posed. The discussion includes various assumptions about charge balance and the behavior of electric fields in the presence of conductors.
TwinGemini14
An infinite line charge lies on the z-axis with l = 2 µC/m. Coxaial with that line charge are: an infinite conducting shell (with no net charge) with thickness 1 cm and with inner radius 2 cm and outer radius 3 cm, an infinite shell with a radius of 4 cm and with a net charge of -5 µC/m, and another infinite conducting shell (with no net charge) with a thickness of 1 cm and with an inner radius of 5 cm and outer radius of 6 cm. A cross sectional view of this setup is shown below:
http://i662.photobucket.com/albums/uu347/TwinGemini14/elecshell.gif
4) Calculate the magnitude of the electric field at r = 10 cm from the z-axis.
A) 0 N/C
B) 1.15 x 10^5 N/C
C) 2.89 x 10^5 N/C
D) 4.22 x 10^5 N/C
E) 5.40 x 10^5 N/C
Since our cylinders have infinite length, I simply added the charge densities to get the charge enclosed by our cylinder.
So Q = (2 uC)*(-5 uC) = -3 uC.
Using Gauss' Law, EA = Q/(epsilon-not)
E = Q/(Epsilon-not * A)
E = (3*10^-6) / ((8.85*10^-12)*(2pi*0.1))
E = |-5.4*10^5| = 5.4*10^5 N/C
ANSWER = E
I believe I did this one correct, but could somebody double check please?
5) Calculate the induced surface charge per meter on the inner conductor's outer surface (at r = 3 cm).
A) -4 µC/m
B) -3 µC/m
C) 0 µC/m
D) +2 µC/m
E) +5 µC/m
So I assumed this logic. Since the inner conductor's inner shell (2cm) must be -2 uC/m to balance the infinite line of charge. So then at the outer shell (3m), it must be -3 uC/m since at 4cm, the net charge is -5 uC. ANSWER = B.
Can somebody please help me with these problems? I'm not entirely sure and would appreciate the assistence. Thanks in advance!
A) 0 N/C
B) 1.15 x 10^5 N/C
C) 2.89 x 10^5 N/C
D) 4.22 x 10^5 N/C
E) 5.40 x 10^5 N/C
ANSWER = E
Looks good.
A) -4 µC/m
B) -3 µC/m
C) 0 µC/m
D) +2 µC/m
E) +5 µC/m
Good! Since you know the net charge on the conducting shell is zero, what must be the induced charge on the outer surface?
Does a charge at r = 4 cm have any impact on anything going on at r = 3 cm?
So then if the charge at 2cm is -2 uC/m, then at 3cm, it must be +2 uC/m since the charge between 2cm and 3cm must be zero.
Right?
So the answer is D.
Right!
  • · Replies 26 ·
