Hexx
How Does Gravity Influence Ring Structures and Tidal Effects?
16 replies · 3K views
Discussion
Trickster_00
- 6
- 0
This is going to sound unintellectual, but how is this not possible?
Hexx
Staff Emeritus
- 9
Step three is impossible. Person one cannot exert a force on person two without experiencing an equal but opposite force themselves. In other words, if person one attempts to lift person two whilst in mid-air, person one will accelerate downwards whilst person two accelerates upwards - the two people would then lose contact making step four impossible.Hexx said:
Similar reasoning applies to the other two examples.
Hexx
Hootenanny said:Step three is impossible. Person one cannot exert a force on person two without experiencing an equal but opposite force themselves. In other words, if person one attempts to lift person two whilst in mid-air, person one will accelerate downwards whilst person two accelerates upwards - the two people would then lose contact making step four impossible.
have you tried?
dkotschessaa
- 1,063
- 763
Everyone whose read the bible (The Hitchiker's Guide to the Galaxy) knows that the secret to flying is to throw yourself at the ground, and miss.
Staff Emeritus
- 9
No. As I explained above, any attempt would be futile. This is not something that needs to verified experimentally - it cannot be done.Hexx said:have you tried?
Jimmy Snyder
- 1,137
- 22
I take it you are a mathematician. The way to fly is to have an magnet in one hand held high and a piece of iron in the other hand held low. The magnet will pull the iron up. As long as you keep your arms stiff, you will be pulled up with it.Hootenanny said:This is not something that needs to verified experimentally.
Staff Emeritus
- 9
I am indeed (an applied one at least) - what gave me away?Jimmy Snyder said:I take it you are a mathematician. The way to fly is to have an magnet in one hand held high and a piece of iron in the other hand held low. The magnet will pull the iron up. As long as you keep your arms stiff, you will be pulled up with it.
Just to clarify, this was posted in General Physics when I replied and not General Discussion. So if my response seemed pompous - that's why!
The legend
- 420
- 0
really, i know this sounds odd in a physics discussion here..
but those were freaking HILARIOUS!
leroyjenkens
- 621
- 49
I like the one where you build a monorail-like track all the way around the Earth, then take out all the support beams all at the same time, giving Earth a floating ring.
humanino
- 2,538
- 8
Those means of beating gravity will fail because Netwon ruined them long ago. Fortunately there are other means. One can exploit the law that a cat always lands on its feet and a buttered toast always land on the butter side
I am not a mathematician, but since I am stuck in the US, I am lost in endless negotiations with PETA to publish the results.
The legend
- 420
- 0
haha^^
jobyts
- 226
- 60
leroyjenkens said:I like the one where you build a monorail-like track all the way around the Earth, then take out all the support beams all at the same time, giving Earth a floating ring.
That is theoretically correct, right? (Serious question).
The ocean side of the Earth might have less gravitational pull due to less density of water), but that we could adjust in the beam mass.
humanino
- 2,538
- 8
How about tides ?jobyts said:we could adjust in the beam mass.
- 34
humanino said:How about tides ?
Make it hollow and fill it partly with water. Implement an advanced system which corrigates the amount of water in each part of the section needed to be in perfect balance.
jobyts
- 226
- 60
Even if the ring is not adjusted for the gravity, only one point of the ring would be touching the earth, correct?
We can have gravity sensors all over the ring, and do some floating mass to balance the ring.
Why Are These Ring Structures Considered Diastereomers?
- NY152
- · Replies 1 ·
- Biology and Chemistry Homework Help
- Replies
- 1
Graduate How Does the Sun's Tidal Effect Influence Earth's Rotation and Moon's Orbit?
- PeterDonis
- · Replies 9 ·
- Mechanics
- Replies
- 9
How Does Gravity Influence Spring Potential Energy in Physics?
- NickStar
- · Replies 2 ·
- Introductory Physics Homework Help
- Replies
- 2
Finding Chiral Centres in Ring Structures
- nil1996
- · Replies 1 ·
- Chemistry
- Replies
- 1
Graduate How Does Gravity Influence Entropy in the Formation of Proto-Stars?
- Islam Hassan
- · Replies 6 ·
- Thermodynamics
- Replies
- 6
Graduate How Does Gravity Influence the Momentum of Light?
- Phys_Boi
- · Replies 2 ·
- Optics
- Replies
- 2
Graduate Tidal effects as a test to distinguish gravity from acceleration
- Reuben Smith
- · Replies 1 ·
- Special and General Relativity
- Replies
- 1
High School How Does Gravity Influence the Movements of Planets and Moons?
- Redi
- · Replies 3 ·
- Astronomy, Astrophysics, Cosmology
- Replies
- 3
Graduate How Does Gravity Influence Light's Path in General Relativity?
- nemia
- · Replies 4 ·
- Replies
- 4
Graduate Tidal Effects in the Schwarzschild Metric
- Passionflower
- · Replies 12 ·
- Replies
- 12
