How Does Ion Charge Affect Mass Deposition in Electrolysis?
66 replies · 18K views · last reply
AdamCFC said:
I got really confused on my last post, which is annoying as I am starting to look like an idiot.
You're starting to look like someone trying to learn something.
Heres what i meant to say:
I now know electrons travel from the - terminal to the + terminal, electricty travels from negative to positive.
The concentration of cations reduces, because the cations are reduced. They are attracted to the cathode where they "take "electrons to become neutrally charged atoms which get plated/stuck to the cathode. The anions are attracted to the anode because they have more electrons than protons so have a overall negative net charge, the anions "deposit" electrons onto the anode, then becoming neutrally charged atoms and are released into Chlorine gas, or Nitrous Oxide.(in the silver nitrate case, are the gasses released Nitrogen + Oxygen, or Nitrous Oxide?).
Is it right to say, the concentration of ions decrease as time goes on? Is that why the current reading should decrease, even know i didnt measure that?
Close enough for starters.
This brings me on to how both ions affect current flow. I don't understand why. I am imagining a loop, the electrons travel from - to +, anticlockwise. I imagine the loop is broken, i don't really see how relevant the cations are, they are not helping electrons get to the + on the battery, on the other hand, the anions are "giving" electrons to the anode, which allows a flow to continue to the + on the battery, is my idea making sense?
See? You're learning --- you're asking questions that I have to stop and think through very carefully.
Current flow through wiring, ordinary alectrical circuits --- charge carriers are electrons; get to doped junctions in semiconductors, we've got electrons and holes --- and, no, I've not got my own mind wrapped around the hole concept well enough to even try explaining it to someone else.
Electrolytic cells come in quite a few flavors to accomplish quite a few different purposes: 1) electrolytic refining (of Cu, for instance) is accomplished by dropping a copper anode and a copper cathode into a sulfuric acid or copper sulfate solution, the Cu in the anode giving up electrons to the circuit driving the cell, that circuit carrying electrons to the cathode while copper ions from the anode move through solution to the cathode where they combine/recombine yielding electrolytically refined copper (current through the cell is exclusively cationic); 2) electrolysis cells (of water for instance) break down compounds by reduction of an oxidized species at the cathode and oxidation at the anode, and current through the electrolyte is carried (hopefully in a well designed cell) by a stoichiometric ratio of the cations and anions being reduced and oxidized; 3) batteries (disposable) by a variety of chemistries both public domain and proprietary that I'm not comfortable enough with to go into a whole lot of detail; 4) rechargeable batteries and I can't remember how lead-acid batteries operate right now, let alone nicads, lithium ion, and whatever else has come out.
Now, I'm looking like the idiot --- I'm trying to coach you, and have just admitted how little I know:wink:
Electrode selection, electrolyte selection, solvent, voltage, and current determine the chemistries taking place at electrodes as far as oxidations and reductions go; these also determine how current is partitioned between charge carriers (cations and anions). Good place to give you an example of the anion charge carrier mechanism --- we'll say you're doing electrolysis of water with KOH (potassium hydroxide) as your electrolyte. Hydroxide ions, OH- are attracted to the anode, give up an electron to the anode forming hydroxide radicals, OH., and two radicals combine to form hydrogen peroxide which decomposes to water and oxygen. Where's the hydroxide come from to replace what I just destroyed at the anode? K+ is attracted to the cathode, and since it's hydrated (surrounded by water molecules attracted by charge-dipole interaction), the electron it picks up from the cathode reduces water rather than the potassium ion, forming a hydrogen radical, H. and a hydroxide ion.
That's probably enough to chew on and digest for the moment.
I think I am getting off track here, i have updated my coursework now, it has my graph I've scanned onto, which i think you will find interesting, my mass change results, my moles results, and some analysis. Shall i attach it to my next post?
Thanks again, Adam
Yeah, let's see what are you got.
Heres the Improved coursework, its still missing a detailed analysis, evaluation and conclusion.
You should be able to view straight away, if not i can email it to you, or upload the pictures like gokul did :)
Adam
Cover page of a 2010 GCSE Chemistry coursework on electrolysis, showing laboratory flasks, an atom diagram, a high voltage warning sign, and a circuit diagram of an electrolysis cell with Anode, Cathode, Battery, Na+ and Cl- labels.
Contents page of a lab report listing ten numbered sections, underlined: 1. Introduction, 2. Variables, 3. Method, 4. Preliminary Results, 5. Results, 6. Graph, 7. Analysis, 8. Evaluation, 9. Conclusion, 10. References.
Printed text page titled Introduction to Electrolysis, covering electrolysis, ions moving to electrodes, Faraday's law, electroplating, and industrial uses such as aluminium and chlor-alkali production.
Tinypic placeholder graphic with the text 'THIS IMAGE OR VIDEO HAS BEEN MOVED OR DELETED'.
Typed page headed Method with an Equipment List of chemicals, glassware, electrodes, wires, a power pack 1V to 13V, an ammeter and distilled water, followed by a Safety Precautions paragraph.
Circuit diagram labelled FIGURE 1 showing a 12V DC power supply, an ammeter, and a beaker of electrolyte with two carbon (graphite) electrodes dipped in the solution.
Typed page: preliminary tests table for 60ml 0.1mol copper chloride electrolysed at 8V, showing cathode and anode weights before and after, with cathode difference 0.035 and anode difference -0.007.
Typed paragraphs of a lab write-up on electrolysis, discussing raising the voltage to 12V, increasing electrolyte volume to 100ml, the equation I=nAve, and using graphite electrodes.
Typed table of electrolysis results titled Table of Results (Mass Changes), with three sections for silver nitrate AgNO3 (+1), copper chloride CuCl (+2) and iron chloride FeCl (+3). Each lists initial amps, cathode weight before and after in grams, and mass change in grams, with an asterisk marking one outlier.
Table of results titled Moles Deposited, listing mass change, atomic mass and moles deposited for silver nitrate, copper chloride and iron chloride over three tests, with averages at the bottom.
Hand-drawn graph on grid paper titled "Moles Deposited vs Ion Charge", with x-axis "Charge of Ions" marked 0, +1, +2, +3 and y-axis "Moles Deposited" from 0 to 0.0002 in steps. Three points at +1, +2 and +3 are plotted as crosses, with two circled points labelled "Outliers" and a smooth curve rising through the origin.
Typed Analysis page with two paragraphs on the ion charge and moles deposited graph, followed by a Gradient Analysis section listing dy/dx values for charges +1, +2 and +3 to 5 decimal places.
Have you got any more information on currents? At thirty seconds, minute, end of run?
i do but i dont, i have the initial currents for all three. i don't have the end current for the +3, and theyre all over the place anyway. What do you think of my graph, and the gradient analysis?
Without the current data, it is meaningless.
How much of the definitions given for "I = nAve" is from material given to you with the assignment, and how much is paraphrase? There are some misunderstandings that are killing you, and we've got to get them identified.
I only have initial current readings, that's all really. They were all 0.65A. But i didnt use currents to work out moles deposited. I am measuring moles deposited, and i found that out by dividing the mass change by atomic mass.
Let's look at something else a bit --- try a different tack.
Compare the sequence of mass changes for each series of three runs of Ag and Cu to that for Fe. Anything strike you as interesting?
In my view, the trend should be linear. Look at +2, if we took the average to be the top outlier, there would be a linear fit/trend. It wouldn't be prefect but my results arnt completely precise. This would also make the trend directly proportional, this is what i would have expected, but i can't explain why.
Hand-drawn graph on squared paper titled 'Moles Deposited vs Ion Charge', plotting moles deposited (0 to 0.0008) against charge of ions (+1, +2, +3), with a curve rising steeply and two circled points labelled outliers.
This begs the question, that maybe 0.001102 ( the outlier ) is infact the real answer, and 0.000670 and 0.000472 are outliers, its plausible and would make sense. I will include this in detail in my evaluation OR conclusion
Adz
AdamCFC said:
(snip) there would be a linear fit/trend. It wouldn't be prefect but my results arnt completely precise. This would also make the trend directly proportional, this is what i would have expected, but i can't explain why.(snip)
Ah-hah! Now, you take advantage of odd little observations made during the experiments. For instance, looking just at the three runs with Ag, what can you tell me about them? Did you use the same pair of electrodes for all three? Did you notice anything about the metal plated onto the electrode? (Coverage, bare spots, that sort of thing) And, just a general question, what can you tell me about the surface area of the rough side of a piece of sandpaper compared to the "smooth" side?
I can't remember much, this was 6 weeks ago. I remember that the we did use the same electrodes. But after the first run there's was a strong coverage, the other 2 runs wernt patch as such, but there was a difference. I can only think an error with the molarity, ditance, voltage, or change in the variable resistor caused this massive difference.
The rough side has a far greater surface area, just like the small instestine, the fingerlike bumps (villi) cause the surface area to greatly increase.
... , and, if you paint the rough side of the sandpaper with a gloss enamel?
wow that's a great point :) we did use a cloth which did get rid of a lot of deposited metal, and we then rinsed it in acetone.
Would you have expected the trend to be linear?
"Linear?" If I can control n, A, v, to be constants among the various e values, yes; I know I can't, so, the most I can expect is an approximation of linearity.
Let's review:
How are you controlling n, constant, and were you successful?
How A, and success?
How v, and success?
Number of Ions - Kept constant by using same amount of electroyte at same molarity (concentration). - Yes i believe it was successful
Surface area of electrodes - Kept constant by using same electrodes, and made sure the same depth was maintained in the solutions - 50% successful, the surface area decreased after each test. The plating process was "smoothing out" minute imperfections in the electrode, decreasing the surface area, thus decreasing the amount of electrode in contact with the solution
Velocity of Ions -Kept constant by using the same power-pack at 12V, and eliminating errors by using the same power-pack throughout my experiment, doing all 3 tests during a 3 day period, at room temperature. ? Keeping the Amps the same by using a variable resostor ? - Yes i think this was successul, it wasnt 100% precise, but i sucessfully did what i could with the resources i had.
Why should the trend be linear?
"n:" decreased through each run as material is plated on the cathode; changed from Ag to Cu to Fe as number of anions increased.
"A:" increases or decreases as material is added to the cathode (forming dendritic growths to increase, filling pores to decrease), but cannot remain constant. Compare the Ag and Cu results from 1 to 3.
"v:" no current measurements, no way of knowing much of anything about anion current; switching anions from nitrate to chloride; changing cation masses; changing cation radii (sizes); and none of this is even going to be on your radar until AFTER you've been through your first chem course.
"Why linear?" If n, A, v are constant, the expression I = k times e is linear in e.
Are you saying my analysis of n A and v are wrong? or are you adding to them?
Isnt this charge, not number, as i am changing ion charge?
Yes, by comparing my results from 1-3 on Gold and Copper, i see the mass changes decrease slightly over the 3 runs. Wouldnt the "growths" and "fill ins" roughly equal up? or do they have tendencies to do just one?
Velocity, didnt i control these well, both through temperature and input voltage?
Finally, I = k x e - what is k?
Ive heard k is "so many times" something? e.g k X 9 would be the 9 times table?
Thanks
"n" is the concentration of ions per unit volume; "e" is the charge of a particular ion. 0.1m AgNO3 ionizes when dissolved in water to give you 0.1m NO3-1 and 0.1m Ag+1 which is not the same value of "n" for 0.1m FeCl3, 0.1m Fe+3 and 0.3m Cl-1. The current carrying product of n and e for the two salts is different, 0.2 for Ag and 0.6 for Fe.
This is what is termed "throw," and is different for every metal and for every plating solution/recipe. Some metals cover the cathode more uniformly than others. You can get smooth plating films, rough blobs and gobs, metals that grow staghorns and trees. It's part of the "art" that is necessary to make a living running a plating shop.
Think of what impedes the motion of ions through solution, and what forces are at work to move the ions through solution. Voltage between the electrodes? Nope, and you ain't responsible for knowing any of this --- isn't even seen by ions in aqueous solution. What makes 'em move? The concentration gradient; when an ion is reduced at the cathode, the local concentration drops, and ions from more concentrated regions diffuse into the region of lowered concentration. The diffusion is a function of temperature, "good on you" for knowing to run all your experiments at as nearly the same temp as possible.
Don't sweat what you haven't learned yet.
"k" is a constant, or presumably a constant, the product of n, A, and v in your expression for current. Since you increased both n and e, you'll want to look at just k = Av as being held constant.
Thanks
:/ i don't understand much of this.
So, I = k x e ... = ... I = ( n x A x v ) x e
so because i just increased e in equal increments, that's why the line/trend should be linear. but my slight errors in keeping n constant have caused it to become a curve?
Can i include this, and that equation in my evaluation/conclusion?
and what did u think about the start of my analysis on the last page?
Just an extra thing to my last post. I would like to include a hypothesis, does this sound suitable and where would i put it?
If moles deposited is related to ion charge, then increasing the charge will increase the current and mass change, which in turn will increase the amount of metal deposited.
Do the bits in bold need to be re-arranged?
You have written "I" as the product of four terms. If you hold three constant and change 1, "I" is linear in that one term. If you hold two constant, and change the product of two others, "I" is linear in the product of those two terms. If you hold one constant, change the product of two others, and have no control over the third, you're in trouble.
"Mass" or "moles?" Both start with "m," but they are NOT interchangeable.
You can discuss crumple zones --- you can count charge carriers, the product of charge carrier concentration and charge --- you can distinguish between mass and mole.
Was what i said about crumple zones right, id feel terrible if i was giving someone false information.
Okay, i think that's fine now :) My intention was to control n A and v and just change e. That would have given me a linear trend. Due to errors and things i couldn't control precisely (temperature), i only controlled ...
wait, i havnt controlled/kept constant anything?
n - didnt 100% understand what you said about ion concentration per unit volume, but i understand that by using 100ml at each at 0.1mol, that was not enough to control ion concentration, and i did not control this well.
A - The surface area varied with each run
v - Volts - Kept constant
-- Temperature - Did vary day by day, not much, but there was a change
This is not a total diaster ... as far as schoolwork goes, because.
I have a trend that supports my prediction and hypothesis
I have a lot of errors i can talk about, and most importantly, describe how to minimise/eradicate in future experiments. e.g, do all tests at a controlled temperature.
Wasn't wrong. You gave a hint, pointed to a source --- abided by the "don't do their work for them, get them to do it themselves" spirit of the homework forum.
I was pointing out to you that you are NOT a babe in the woods --- that stuff's been covered for you and basic concepts relevant to this electrolysis problem haven't been. Punched the frustration button there for me.
So long as you learn, there are NO "total disasters." Good.
You predict a "linear trend." Let's work on that, because there is something in "I=nAve" that is still leading you off into the weeds.
Looking just at silver and iron, +1 and +3 charges, you expect to see the current triple; you are going to "measure" current by weighing the cathode of each cell before and after a timed electrolysis and calculating moles plated onto the cathode. What is your prediction for the number of moles of iron? Less than, greater than, or equal to the number of moles of silver?
er, I am not sure. I don't think i expect iron+3 to have three times more moles deposited than silver +1. I do expect a proportional relationship though. I expect more moles deposited on the cathode after using the iron electrolyte than the silver electrolyte. This is because iron ions have a higher charge.
Am i right in thinking, because silver has almost double the atomic mass of iron, that 10 iron ions would need to be plated to equal 5 silver ions?
If this is the case, because iron deposited a higher mass change than silver, many many more ions were deposited on the cathode than the amount of silver ions deposited.
Going on holiday wednesday morning, so won't be able to reply after that until the 1st sept.
Adam
Wrong. You have increased the current by increasing the charge on the ion. You have not increased the number of ions being deposited. Silver at +1 carries a current I; iron at +3 carries a current of 3I. A silver ion will be reduced by ONE electron to atomic (metallic) silver at the cathode; a ferric ion requires THREE electrons to be reduced to metallic iron. Recheck the definition of electric current.
You are determining mass only as a means to find the numbers of moles deposited; other than for that purpose, mass is meaningless in the context of this experiment.
Yes. But, please think in terms of moles rather than mass. You want to count charge, you want to count moles, you want to compare those numbers rather than masses.
Adam
Ok, so to your previous question, I predict there will be more moles of iron deposited than moles of silver.
Whats that?
Silver ion at +1, current is I; ferric ion at +3, current is 3I. WHAT is the definition of current? Same time for both cells, total charge transferred is what for silver? And what for iron? Reducing how many moles of silver? And how many moles of iron?
You've got two guesses left.
Current represents the flow of electrons through a conductive material.
Silver needs 1 electron to become an atom again, Iron needs 3.
Current is defined as CHARGE per unit time, be that charge carried by electrons, or ionized atoms or molecules.
Now, more moles of iron than silver? Same? Fewer?
