Homework Helper
- 1,779
AdamCFC said:I got really confused on my last post, which is annoying as I am starting to look like an idiot.
You're starting to look like someone trying to learn something.
Heres what i meant to say:
I now know electrons travel from the - terminal to the + terminal, electricty travels from negative to positive.
The concentration of cations reduces, because the cations are reduced. They are attracted to the cathode where they "take "electrons to become neutrally charged atoms which get plated/stuck to the cathode. The anions are attracted to the anode because they have more electrons than protons so have a overall negative net charge, the anions "deposit" electrons onto the anode, then becoming neutrally charged atoms and are released into Chlorine gas, or Nitrous Oxide.(in the silver nitrate case, are the gasses released Nitrogen + Oxygen, or Nitrous Oxide?).
Is it right to say, the concentration of ions decrease as time goes on? Is that why the current reading should decrease, even know i didnt measure that?
Close enough for starters.
This brings me on to how both ions affect current flow. I don't understand why. I am imagining a loop, the electrons travel from - to +, anticlockwise. I imagine the loop is broken, i don't really see how relevant the cations are, they are not helping electrons get to the + on the battery, on the other hand, the anions are "giving" electrons to the anode, which allows a flow to continue to the + on the battery, is my idea making sense?
See? You're learning --- you're asking questions that I have to stop and think through very carefully.
Current flow through wiring, ordinary alectrical circuits --- charge carriers are electrons; get to doped junctions in semiconductors, we've got electrons and holes --- and, no, I've not got my own mind wrapped around the hole concept well enough to even try explaining it to someone else.
Electrolytic cells come in quite a few flavors to accomplish quite a few different purposes: 1) electrolytic refining (of Cu, for instance) is accomplished by dropping a copper anode and a copper cathode into a sulfuric acid or copper sulfate solution, the Cu in the anode giving up electrons to the circuit driving the cell, that circuit carrying electrons to the cathode while copper ions from the anode move through solution to the cathode where they combine/recombine yielding electrolytically refined copper (current through the cell is exclusively cationic); 2) electrolysis cells (of water for instance) break down compounds by reduction of an oxidized species at the cathode and oxidation at the anode, and current through the electrolyte is carried (hopefully in a well designed cell) by a stoichiometric ratio of the cations and anions being reduced and oxidized; 3) batteries (disposable) by a variety of chemistries both public domain and proprietary that I'm not comfortable enough with to go into a whole lot of detail; 4) rechargeable batteries and I can't remember how lead-acid batteries operate right now, let alone nicads, lithium ion, and whatever else has come out.
Now, I'm looking like the idiot --- I'm trying to coach you, and have just admitted how little I know
Electrode selection, electrolyte selection, solvent, voltage, and current determine the chemistries taking place at electrodes as far as oxidations and reductions go; these also determine how current is partitioned between charge carriers (cations and anions). Good place to give you an example of the anion charge carrier mechanism --- we'll say you're doing electrolysis of water with KOH (potassium hydroxide) as your electrolyte. Hydroxide ions, OH- are attracted to the anode, give up an electron to the anode forming hydroxide radicals, OH., and two radicals combine to form hydrogen peroxide which decomposes to water and oxygen. Where's the hydroxide come from to replace what I just destroyed at the anode? K+ is attracted to the cathode, and since it's hydrated (surrounded by water molecules attracted by charge-dipole interaction), the electron it picks up from the cathode reduces water rather than the potassium ion, forming a hydrogen radical, H. and a hydroxide ion.
That's probably enough to chew on and digest for the moment.
I think I am getting off track here, i have updated my coursework now, it has my graph I've scanned onto, which i think you will find interesting, my mass change results, my moles results, and some analysis. Shall i attach it to my next post?
Thanks again, Adam
Yeah, let's see what are you got.
