How does pipe diameter affect pressure in fluid flow?
3 replies · 2K views
DinjiP
How does change in pipe diameter affect pressure? For example, ethylene in a 6" pipe at 400 psi, enters a 1" pipe. How does the pressure change?
I am fairly sure that pressure decreases and velocity increases. However, I need to know how pressure decreases? At what rate? Is it linear?
I should point out, I do know how to calculate pressure loss across the length of a pipe. That is not what I am interested in.
Pipe friction is termed major losses, pressure drop due to fittings like valves, tees, or in your case a reducer (specifically a 6" to 1" reducer) are termed minor losses and are even easier to calculate. You can find an overview here:
http://www.engineeringtoolbox.com/minor-loss-coefficients-pipes-d_626.html
You'll have to do some more searching to find the minor loss coefficient for your specific fitting.
Pressure change, both due to velocity change and due to friction losses is a function of velocity. Since your starting pressure is high, if your velocity happens to be low, the pressure change may well be negligible.
