How does pipe diameter affect pressure in fluid flow?
The discussion revolves around how changes in pipe diameter affect pressure in fluid flow, specifically focusing on a scenario involving ethylene flowing from a 6" pipe into a 1" pipe at 400 psi. Participants explore the relationship between pressure and velocity, as well as the factors contributing to pressure changes, including friction losses and fittings.
  • Exploratory, Technical explanation, Debate/contested
  • One participant suggests that pressure decreases and velocity increases when fluid flows from a larger diameter pipe to a smaller one, but seeks clarification on how pressure decreases and whether this decrease is linear.
  • Another participant emphasizes that they are not interested in calculating pressure loss across the length of the pipe, indicating a focus on understanding the nature of pressure changes rather than numerical calculations.
  • A different participant notes that pressure change is influenced by both velocity change and friction losses, suggesting that if the initial velocity is low, the pressure change may be negligible.
  • Minor losses due to fittings, such as reducers, are mentioned as factors that can affect pressure change, with a reference provided for further exploration of minor loss coefficients.
Participants express differing views on the specifics of how pressure changes with diameter reduction, indicating that the discussion remains unresolved with multiple competing perspectives on the nature of pressure loss.
Participants acknowledge the complexity of pressure changes, including the roles of velocity and friction losses, but do not reach a consensus on the exact nature of these changes or their calculations.
DinjiP
How does change in pipe diameter affect pressure? For example, ethylene in a 6" pipe at 400 psi, enters a 1" pipe. How does the pressure change?
I am fairly sure that pressure decreases and velocity increases. However, I need to know how pressure decreases? At what rate? Is it linear?
I should point out, I do know how to calculate pressure loss across the length of a pipe. That is not what I am interested in.
Pipe friction is termed major losses, pressure drop due to fittings like valves, tees, or in your case a reducer (specifically a 6" to 1" reducer) are termed minor losses and are even easier to calculate. You can find an overview here:
http://www.engineeringtoolbox.com/minor-loss-coefficients-pipes-d_626.html
You'll have to do some more searching to find the minor loss coefficient for your specific fitting.
Pressure change, both due to velocity change and due to friction losses is a function of velocity. Since your starting pressure is high, if your velocity happens to be low, the pressure change may well be negligible.
  • · Replies 38 ·
  • · Replies 31 ·
