SiennaTheGr8
- 525
- 229
I think @SiennaTheGr8 likewise had a good point in #26.
There is more than one "time". Each reference frame judges the time that events occur by its own set of clocks synchronized within its reference frame. But if two frames in relative motion try to synchronize between the two at one point, they are forced to be unsynchronized at other points in the direction of relative motion. So they can never agree on whether two events which are separated in the direction of relative motion are simultaneous. If one reference frame thinks that they are simultaneous, then the other can not agree.Andrew1955 said:You guys appear to be saying the A events happen at a different time.
I couldn't disagree more. It helps one understand how it all fits together. It helps one to understand how each reference frame can think that the other's clocks are running too slow. -- Because each reference frame is moving toward the other reference frame's trailing clocks, which people in the first frame thinks were synchronized incorrectly.If so the whole thought experiment seems to be a waste of time as no meaning can be found from it.
SiennaTheGr8 said:I think @SiennaTheGr8 likewise had a good point in #26.![]()
Mister T said:@pixel has a good point. The ball doesn't have the additional velocity of the train, either. There's nothing special about the light itself in this context, the thing that's special is the speed of the light. I realize that everybody knows this, but it might be worth making explicit because sometimes learners are confused by it.
Yeah, the special thing about light is its speed. Any object that has the speed of light in one inertial FoF moves at the speed of light in any other inertial FoF. The velocity of light (or any object moving at the speed of light), though, unlike speed, can change with the change of the FoF (inertial). And it does so according to the laws of SR (velocity addition formulas). E.g. if you shoot a photon perpendicular to the movement of the train (from your point of view), while you on the train, the photon will have the additional velocity of the train along the direction of its movement (from the ground point of view).A Lazy Shisno said:I thought the special thing about light is that its speed doesn't depend on the velocity of the thing it's being emitted from?
Dragon27 said:Yeah, the special thing about light is its speed. Any object that has the speed of light in one inertial FoF moves at the speed of light in any other inertial FoF. The velocity of light (or any object moving at the speed of light), though, unlike speed, can change with the change of the FoF (inertial). And it does so according to the laws of SR (velocity addition formulas). E.g. if you shoot a photon perpendicular to the movement of the train (from your point of view), while you on the train, the photon will have the additional velocity of the train along the direction of its movement (from the ground point of view).
For humans, time actually is a thing or rather, rotation event. Time is always, always a real rotation of "something". There is no other way to measure a periodic event but to count the clicks as the "merry-go-round" comes around again.craigns said:The question I would add to this discussion is what is time? I would stress that it is not a thing itself but rather a measurement or snapshot of the state of the relationship of things (atoms) at a particular moment. Personally I think Einstein treats time too much as a thing.
Define "plus". If you're saying that the speed of ball changes (in this case, increases), then yes, the speed of light is special (as Mister T has pointed out in his original post). Because it stays the same. But the amount by which the speed of ball changes is not the exactly the same as in classical non-relativistic mechanics.A Lazy Shisno said:No, I know what happens when you fire the light perpendicular, but what I'm talking about it that the speed doesn't depend on the speed of the source. When you (on a moving train) throw a ball in the direction of the train's motion, it has the speed of the train plus the speed you threw it at (from the perspective of an outside observer).
Dragon27 said:Define "plus". If you're saying that the speed of ball changes (in this case, increases), then yes, the speed of light is special (as Mister T has pointed out in his original post). Because it stays the same. But the amount by which the speed of ball changes is not the exactly the same as in classical non-relativistic mechanics.
But there's nothing special about the light (except for its speed). The relativity of simultaneity is realized, whether we're talking about the light, or the balls. Light is affected by the movement of its source. Only the speed of the light is absolute (not even velocity in general).A Lazy Shisno said:Yeah, that's what I was trying to get at in my original post. I'm aware that relativistic phenomena obviously apply to the ball, but I was trying to explain that the light doesn't act like a ball being thrown to either end of the traincar because it is independent of the speed of its source, hence why the relativity of simultaneity was realized.
Yes. The only complication for the thrown ball is that an outside stationary observer will not add the same velocity numbers. He would think that the person on the train is wrong about the ball's speed because of the distortion of distance and time.A Lazy Shisno said:Sorry, I'm still trying to learn some of the finer details of SR, but why doesn't the ball have the initial velocity of the train? If I'm on a train and I have a ball in my hand, it has the same velocity as the train. So when I throw it in the direction of the train's motion, it has the velocity of the train plus the velocity I imparted on it (from the perspective of an outside observer). I thought the special thing about light is that its speed doesn't depend on the velocity of the thing it's being emitted from?
Andrew1955 said:I understand a lazy shisnos example alright. I am still not clear why peculiarities about the speed of light must mean time and length must also change.
If light causes us to perceive weird stuff does this mean that weird stuff is really happening?
Andrew1955 said:If we see wave lengths of light as red is red really out there or is there just colourless energy which we interpret and imagine as being red? Do you think the sky is actually blue? The grass is green? These things are only illusions created by the human visual system.
Andrew1955 said:We use light to help us perceive reality. If light tells us time has changed, should we believe that just because 'light says its true'.?
If light causes us to perceive weird stuff does this mean that weird stuff is really happening? If we see wave lengths of light as red is red really out there or is there just colourless energy which we interpret and imagine as being red? Do you think the sky is actually blue? The grass is green? These things are only illusions created by the human visual system.
We use light to help us perceive reality. If light tells us time has changed, should be believe that just because 'light says its true'.?
Sorcerer said:Every timed measurement is pair of simultaneous events (the hand of your clock arriving at a certain tick mark coinciding with the event you are looking at, e.g., the simultaneous events of the hand of your clock moving to a point and, say, the racer you are timing arriving at a point).
If every timed measurement is at minimum a pair of simultaneous events, and simultaneity is not universal, then timed measurements cannot be universal either.
Thanks for the insight. But there would by necessity be a distance separating them, would there not? If you are timing when a train arrives, your clock is close to the train, but not on the train. That is, your measurement is comparing two events: the event of the second hand hitting a number, and the event of a train pulling into a certain location. Is that right?Mister T said:A long as the two occurrences are in the same location (co-located) when they occur then they are a single event.
If they occur at the same place and at the same time according to one observer, then that will be true for all observers. This is an event. This kind of simultaneity is absolute. But if the two events are separated along the line of relative motion, then simultaneity is relative.
Yes. But there are two caveats.Sorcerer said:Thanks for the insight. But there would by necessity be a distance separating them, would there not? If you are timing when a train arrives, your clock is close to the train, but not on the train. That is, your measurement is comparing two events: the event of the second hand hitting a number, and the event of a train pulling into a certain location. Is that right?
Ibix said:First, the Lorentz transforms only do "funny" things in the direction that the other frame is moving. We usually pick that to be the x direction. Two events with equal x coordinates will be simultaneous (or not) for all frames moving in the ±x direction, regardless of their y and z coordinates.
So it is the time of passenger - as evaluated by a platform observer - which slows down (and vice versa); not the time as evalued by the passenger himself.jartsa said:A passenger on the train does not notice that, so he must have a slow wristwatch or a slow atomic clock, as observed from the platform.
I want to propose a more symmetrical setting. A single event "Spark" is caused by friction in the same time and place: when M and M' are passing in front of each other and sratch two flints, causing a single spark. Both M and M' stand in the middle between two hyperbolic mirrors which reflect a converging light onto an electronic detector which reveals the reflecting light and causes a chime everytime light strikes the detector.Dragon27 said:Yes, that's from the point of view of the ground observer. From the point of view the train observer he's not moving at all, so the flashes of light ARE non-simultaneous.
Alfredo Tifi said:I want to propose a more symmetrical setting. A single event "Spark" is caused by friction in the same time and place: when M and M' are passing in front of each other and sratch two flints, causing a single spark. Both M and M' stand in the middle between two hyperbolic mirrors which reflect a converging light onto an electronic detector which reveals the reflecting light and causes a chime everytime light strikes the detector.
M's expects his detector will reveal two chime events simultaneously, as M' expects the same, two chime' events simultaneously emitted by his own detector. The chimes are events occurring in the same place. I believe (but maybe I'm wrong) that for the symmetry of the situation M and M' will actually register two simultaneous chimes from their device. There is no problem with simultaneity here. But I think we have another issue with "light" as a physical phenomenon: what is clear to me is that we can't describe light as something unique travelling.
If the light emitted in the spark were a unique propagation physical phenomena, we couldn't have double simultaneous chimes from both the observers.
Once light has been "emitted" in the single event spark, every frame owns its "copy" or "version" of light causing a total of four distinct chime events. We can't speak of light as one and the same thing during the propagation towards each couple of mirrors for both observers.
To speak of light as something (one thing) traveling works only from the POV of a single observer which experiments two separate (in time) events in the same place (1. spark; 2. chime). By dividing distance by time we always find c. But if we speak of light event phenomena as a propagation phenomena, each event as the same phenomenon for every observer, we are misunderstanding the true nature of light and the meaning of light type distances in our relativistic Universe.
This could be true only if referred to the evaluation of one's and other's detector: M and M' both say their own detector receive two light signals simultaneously, coming from their own mirrors, provided they hear two simultaneous chimes (and see two simultaneous LED blinkings into their own detector hold in their hand). But if B watches the detector of B' faraway (or if B' looks at the detector of B), he could even expect two LED blinks arriving at different times from there, because he imagines a light beam as traveling from a mirror moving forward and another beam traveling from an escaping mirror; thus he presumes those beams will reach the other observer's detector in different times. But this nice fable is only based on the assumption that light is travelling and that that light is "one and the same thing-ball" for everybody. The cruel reality is that we have never seen a beam of light travelling. We can see, at most, a light beam standing in between a distance, if we put some smoke there. So, everything can "travel" but light, is my tenet. The other reality is that the light of both detectors will blink simultaneously from the pov of each owner. And this simultaneous blinks will correspond to another event-signal which will be perceived by the other observer faraway. No matter of time lapse and distance, a double simultaneous blink event in the hands of B' is a fact, independently from the original scratch and spark. Whatever it will reach B, that event will conserve and vehicle the image of a far detector in which two LEDs are simultaneously blinking. So both observers will observe a double simultaneous chime and LED light blink in their own detector, and also a double simultaneous blink (obviously retarded) into the far observer's detector.Rap said:@Dragon27
M and M' will not experience simultaneous chimes.
This is manifestly wrong. No observer is motionless. In our Universe doesn't exist something like "rest". Everything is in relative motion respect to a myriad of other things. In this case M and M' are both in motion one respect to the other, because of the perfect symmetrical setting. The pitfall is even more evident because you are considering the spark and the spark-event place as standing there, somewhere, maybe in front of M. If you want imagine a spatial location for that spark-event with any short-time duration, then you'd better imagine that place is - at any time - exactly midway between M and M'. In this case M and M' are both in motion respect to the light source at same (opposite) speed. This will reestablish a clear image of the symmetry. And you maybe want to put there a third observer too: the one sitting at the spark-place, i.e. the POV of M°. Like M and M', M° has two mirrors and a chime-LED detector pointed towards the two mirrors equidistant in opposite directions. He will observe two chimes and LED light emissions from his detector in his hands, and, after a short time lapse, M° sees two double simultaneous LED blinks coming from M and M', from opposite directions, but simultaneously.Rap said:@Dragon27Lets say M is motionless with respect to the detectors, M' is not. Then M will experience simultaneous chimes, M' will not. M' will not, because to him, the detectors are moving. One detector is moving towards where the spark happened, the other is moving away, and so, to him, the distances the two light beams have to travel are different, and since the speed of light is constant, the chimes cannot be simultaneous.
Alfredo Tifi said:This could be true only if referred to the evaluation of one's and other's detector: M and M' both say their own detector receive two light signals simultaneously, coming from their own mirrors, provided they hear two simultaneous chimes (and see two simultaneous LED blinkings into their own detector hold in their hand). But if B watches the detector of B' faraway (or if B' looks at the detector of B), he could even expect two LED blinks arriving at different times from there, because he imagines a light beam as traveling from a mirror moving forward and another beam traveling from an escaping mirror; thus he presumes those beams will reach the other observer's detector in different times. But this nice fable is only based on the assumption that light is travelling and that that light is "one and the same thing-ball" for everybody. The cruel reality is that we have never seen a beam of light travelling. We can see, at most, a light beam standing in between a distance, if we put some smoke there. So, everything can "travel" but light, is my tenet. The other reality is that the light of both detectors will blink simultaneously from the pov of each owner. And this simultaneous blinks will correspond to another event-signal which will be perceived by the other observer faraway. No matter of time lapse and distance, a double simultaneous blink event in the hands of B' is a fact, independently from the original scratch and spark. Whatever it will reach B, that event will conserve and vehicle the image of a far detector in which two LEDs are simultaneously blinking. So both observers will observe a double simultaneous chime and LED light blink in their own detector, and also a double simultaneous blink (obviously retarded) into the far observer's detector.
If you think to light as something connecting events in different points of spacetime, instead of something "travelling in space", you could start re-thinking and re-writing all concepts. I am not able to do that at this moment, but I have no doubts on the results and implications of this thought experiment of mine.
I hope somebody more expert than me and open minded would take in account these analyses of the issue.
Many years ago I read PW Bridgman didn't like to think of light as something travelling. Now, I know why, or I presume to know why.
FactChecker said:If
1) each reference frame is using it's own synchronized clocks to record the times of events and
2) the clocks are at the positions where the events happen and
3) the events are separated in the direction of relative motion,
then they will not agree on whether events are simultaneous.
If all those conditions are satisfied, t1=t2 forces t1'≠t2'.
As long as the times recorded are identical to the multiple-clock setup.Rap said:1) Yes, but only one clock per observer is needed. The time of the detection event can be inferred if both observers know their relative velocities and the detector positions, by observing the light flash from the detector.
The simplest, most basic situation is that the times recorded in each frame are the times in that frame at the location of the events. Anything else is a complication. You must be careful that your method gives the same time as the multiple clocks or the results will not be the same.2) Yes, but not necessary (see above)
I was under the impression that the situation being discussed was fundamentally different.3) Yes
And yes, the conclusion follows. I just want to make sure that Dragon27 agrees with the setup or else it’s apples and oranges.
