How Does Special Relativity Affect Perceived Distances Between Planets?
The discussion revolves around the effects of special relativity on the perceived distances between two planets, A and B, which are 4 light years apart in Tom's rest frame. The scenario involves Mary traveling at 0.8c towards Tom and the implications of relativistic effects on distance measurements from different frames of reference.
  • Some participants assert that when Mary passes planet B, she perceives Tom to be 2.4 light years away, while Tom measures Mary to be 4 light years away in his rest frame.
  • Others argue that the concept of "now" differs between Tom and Mary due to the relativity of simultaneity, complicating their distance measurements.
  • A participant suggests that both Tom and Mary could consider themselves at rest and measure the distance to each other as 2.4 light years at certain times, depending on their relative motion.
  • Some participants emphasize that the definition of distance is not symmetric between the two frames, as it depends on the chosen reference frame.
  • One participant introduces a geometric analogy to illustrate the differences in perceived distances in spacetime, suggesting that the geometry of spacetime leads to different results than in Euclidean space.
  • There is a discussion about the implications of time dilation, with participants noting that both observers will perceive the other's clock as running slower.
Participants express disagreement regarding the interpretation of distance and simultaneity in different frames. There is no consensus on how to reconcile the differing perceptions of distance between Tom and Mary.
Participants highlight the importance of specifying the frame of reference when discussing distances and times, as well as the potential confusion arising from using planets as reference points. The discussion remains unresolved regarding the implications of simultaneity on distance measurements.
  • #61
dwspacetime said:
that is fine. I am trying to tell you they will meet after all kinds of speed. since somebody says they dont meet again assuming no one turning back. if that is true, Tom travels from A to B and wait for mary from A to B also. they do meet again without turning back. if we consider either one of them as a reference they other one will have a speed which will result a less number in time. so the other one is always younger
No, if they both travelled from A to B their frames were not always inertial and therefore could not be used* with the quoted formula.
* You can use noninertial frames as well, but it typically is more mathematically involved and gives the same result
  • #62
PeroK said:
It's not a paradox. There's only your failure to understand the basics of SR.
let us put it this way. I agree the "when" of Tom is red is not the same as the "when" Mary is red. but for the same original question I asked there must be a "when" Mary is red and all the charts you drew still apply which is why it is a paradox.
  • Sad
  • #63
dwspacetime said:
let us put it this way. I agree the "when" of Tom is red is not the same as the "when" Mary is red. but for the same original question I asked there must be a "when" Mary is red and all the chart you drew still apply which is why it is a paradox.
It is not a paradox. It is geometry. Try the Euclidean space equivalent!
  • #64
let's do this. just go back to your original charts. just switch Tom and Mary and forget about the planets. do those charts still apply? why not? I know when you switch them the "when" is not the same as the "when" you did them the first time.
  • #65
You messed up your quotes, but yes, you can do exactly the same statements from Mary’s frame. It is unclear why you think this is a paradox. Again I refer you to try the same in the Euclidean case. It is just a fact of geometry. Nothing strange is going on.
  • #66
let's make it very simple. let me modify my original question to this. Tom and Mary in spacetime. in Tom's frame Mary is moving towards him in 0.8C and in Mary's frame Tom is moving towards her in 0.8C. when Mary is 4 lys away from Tom in Tom's frame how far is Mary from Tom? why
  • #67
Define what you mean by ”when”. This is what seems to confuse you.
  • #68
dwspacetime said:
let's make it very simple. let me modify my original question to this. Tom and Mary in spacetime. in Tom's frame Mary is moving towards him in 0.8C and in Mary's frame Tom is moving towards her in 0.8C. when Mary is 4 lys away from Tom in Tom's frame how far is Mary from Tom? why?
  • #69
Also specify what distance you want to know and according to what convention.
  • #70
use whatever convention you want to use. then ask the same question with Tom and Mary switched. you should get the same answer for the two questions by using whatever convention if you are consistent or you are wrong.
  • #71
I let you define the "when" whatever way you want. once you answer the question. I will ask you the second question with all the wording the same as i used in the first except switch Tom with Mary. answer the 2nd question with the same definition of "when" you use for the first question then compare the two answers.
  • #72
No I won’t because it will just lead to you misunderstanding things as this thread has shown. You need to specify what you want to know.
No, you are wrong here. Switching Tom and Mary also switches the ”according to whom”.
Say for example:
M is 4 ly away from T in T’s rest frame, the same event for M is 2.4 ly away from T in M’s rest frame.
The switching is:
T is 4 ly away from M in M’s rest frame, the same event for T is 2.4 ly away from M in T’s rest frame.
Both are true and there is no paradox. Although the statements are the same, the events involved are not. Please refer to the Euclidean analogue (which you have completely ignored so far - that’s just bad form).
  • #73
Orodruin said:
No I won’t because it will just lead to you misunderstanding things as this thread has shown. You need to specify what you want to know.No, you are wrong here. Switching Tom and Mary also switches the ”according to whom”.
Say for example:
The switching is:
  • #74
it is a paradox. basically my two questions are the same question even I switched them. but you get me two different answers. mary moving towards tom is the same as tom moving towards mary
  • #75
I gave you exactly the same answer for the switched question.
Here is the Euclidean equivalent:
Basically you are confused that I could make C and C’ the same length and still have D and D’ the same length.
There is no paradox here. Just you confusing yourself with your own misconceptions about what the answer should be.
  • #76
sir what you did is "correct" after wrongfully made my two same statements stated in two different ways two different statements. the two statements are the exactly same although I switched two names. but for the same statements you answered in M is frame T is 4 lys in one answer but in the other T is 2.4ly.
  • #77
let me make it simple. basically I stated T and M are moving towards each other which is all i tell you. and you tell me T is 4 lys in M's frame and is also 2.4 lys in M's frame
  • #78
Note that your statement "when Mary is 4 lys away" from Tom has to be the result of a measurement along a distance separated by two endpoints that are constantly at rest, otherwise there is no "distance" onto which we can apply the length contraction formula, and there would be nothing to discuss about.... So there is always something equivalent to your planets, if you want it or not.
It's like the relativity of motion: If a ball is at rest in Tom's frame, it is obviously in motion in Mary's frame. Do you think this "asymmetry" violates the relativity principle?
Now let's discuss your length contraction experiment along the same lines:
a) An experimentalist defines a distance of 4 lightyears in Tom's frame S, consisting of endpoints that are both constantly at rest with respect to Tom.
b) So in all other inertial frames those endpoints have a constant speed different from zero and the distance in between them is length contracted. So Tom measures a (proper) length of 4 lightyears, while Mary measures a (contracted) length of 2.4 lightyears.
c) What is the cause of this asymmetry? Well, simply YOUR (being an experimentalist) decision to measure endpoints that are at rest in S.
d) Of course, the experimentalist can decide to choose ''another set of endpoints'' constantly at rest in Mary's frame S' that are separated by 4 lightyears. In this case everything is reversed: The S' observer measures the length of 4 lightyears, while the S observer measures 2.4 lightyears. However, since this distance is defined by a new set of endpoints, it has nothing to do with the distance measured by Tom...
  • #79
I did nothing of the sort. I switched M and T everywhere in the original statement, which is the only way you can claim symmetry. Please stop being disingenuous.
Here is the case of your actual setup in Minkowski space. Based on the inertial frame where both T and M have the same speed so you do not misconstrue either of them being assumed to be stationary.
C and C’ are both 4 ly and D and D’ are both 2.4 ly. Everything is symmetric. The ”weird” orthogonality is just how orthogonality works in Minkowski space.
  • #80
a) An experimentalist defines a distance of 4 lightyears in Tom's frame S, consisting of endpoints that are both ''constantly at rest'' with respect to Tom.
dont confuse yourself too much. again T and M are moving towards each other in whatever speed if numbers confuse you. in M's frame there should be one distance from T or two different distances? why dd you tell me in M's frame T is both 4 lys and 2.4 lys.
  • Sad
  • #81
No. As you can see from the diagram - and as I also told you previously - you change the relevant events when you change the statement. You should not be surprised that T is 4 ly away at some time and 2.4 ly away at a different time.
  • #82
this is interesting. but the sequence of events doesn't seem correct. that is weird
  • #83
a) If the experimentalist (=you) measures two endpoints at rest in Tom's frame separated by 4 light years, the only length measured by Mary is 2.4 lightyears.
b) If the experimentalist (=you) measures two endpoints at rest in Mary's frame separated by 4 light years, the only length measured by Tom is 2.4 lightyears.
You made your decision by choosing a). Is it really that hard to understand?
  • #84
4 lys away should happen before 2.4 lys away but they seem switched somehow. if it is true the universe is wrong. sorry
  • Haha
  • #85
This is completely unhelpful. You cannot just state that something seems ”weird” without specifying what it is. If you do that there is no way to correct you.
(Spoiler alert: Everything in that diagram is in accordamce with what has been specified. If something seems ”weird” to you, then that is where your understanding of special relativity is lacking.)
  • #86
Look at the diagram. In both cases the 4 ly distances occur before the 2.4 ly distances. There is nothing weird going on here.
  • #87
Sorry I was just talking with myself. the event M is 4 lys away in T's frame should happen before the event M is 2.4 lys away. if that is the case then the event T 2.4 lys away happens before T is 4 lys away in M' frame. is that not weird. this must be one of the weird reality of spacetime
  • #88
No, this is wrong and a misrepresentation of what the diagram shows.
T 2.4 ly away in M’s frame is the simultaneity D in the diagram. T 4 ly away in M’s frame is the simultaneity C’ in the diagram. C’ clearly lies below D.
  • #89
no matter which event happens first one of them is going to have 2.4 lys before 4 years why
  • #90
that tells me that depending on which inertia frame you are in the sequence of events could be reversed. the reason for something to happen could be the result.
  • · Replies 43 ·
  • · Replies 18 ·
  • · Replies 35 ·
  • · Replies 67 ·
  • · Replies 32 ·
