How Does the Fraunhofer Condition Affect Diffraction Patterns?
The discussion revolves around the Fraunhofer diffraction pattern produced by a square aperture with a specified size and wavelength of light. Participants explore the implications of the Fraunhofer condition on the reliability of their calculations regarding the distance at which the diffraction pattern can be observed.
  • Participants attempt to calculate the distance for observing the Fraunhofer diffraction pattern and question the validity of the equations used under certain conditions. There is discussion about the relationship between aperture size, wavelength, and distance, as well as the implications of being in the near field versus the far field.
The conversation is ongoing, with participants providing insights and questioning the assumptions made in the calculations. Some guidance has been offered regarding the limitations of the equations used, particularly in relation to the Fraunhofer condition and the implications of distance on the diffraction pattern.
Participants note that the calculated distance of 45 cm may not satisfy the conditions for the Fraunhofer approximation, suggesting that a much larger distance is necessary for the equations to be reliable. There is also mention of the need for clarity on how to apply certain equations to a square aperture as opposed to a single slit.
says
A square aperture with a side of length 0.5 mm is illuminated with light of wavelength 550 nm. At what distance from the aperture would the Fraunhofer diffraction pattern have a central maximum with a width also equal to 0.5 mm? What can you say about the Fraunhofer condition under these circumstances?
W2 / Lλ << 1
where
W : aperture or slit size
L : distance from aperture
λ : wavelength
3. The Attempt at a Solution
0.5mm = 0.0005m
550 nm = 5.5*10-7m
L = W2 / λ
= (0.0005m)2 / 5.5*10-7m
= 45 cm - distance at which Fraunhofer diffraction pattern is observed
I'm a bit lost with this question / Fraunhofer diffraction. I think I may have used the wrong equation maybe. Any help would be much appreciated.
What you did is ok. If you notice in your calculation, since ## \Delta x=L \, \Delta \theta=\frac{L \lambda}{b}=b ##, the conditions for this problem are ## \frac{b^2}{L \lambda}=1 ##. What this is saying is that although you computed ## L= 45 ## cm, this answer is unreliable, because the formula that you used for this case, that ## \Delta x=\frac{L \lambda}{b} ## only works for ## \frac{b^2}{L \lambda}<<1 ##, which means we must have ## L>>\frac{b^2}{\lambda} ##. If not, the answer is unreliable. (And we don't have ## L>> \frac{b^2}{\lambda} ##, because our calculated ## L=\frac{b^2}{\lambda} ##). ## \\ ## Clearly, the bright spot produced by this pattern must be at least as big as the aperture. (The Fraunhofer equation, ## \Delta x=\frac{L \, \lambda}{b} ##, would tell us for ## L< 45 ## cm, that the bright spot is smaller than the aperture, i.e. ## \Delta x <b ## , which is clearly wrong). The Fraunhofer formulas do not work in this case for ## L \lesssim 45 ## cm. The Fraunhofer equations work in the far-field. In this case, ## L=45 ## cm is in the near field. The far field would begin somewhere around ## L \approx 10 ## meters, or thereabouts for this problem. ##\\ ## Note: I'm using ## b ## for aperture width, in place of ## w ##.
The only other equation I have found is:
df = 2λz / W
where
df=width of central band in diffraction pattern
λ=wavelength
z=viewed at a distance of...
W=slit width
z = (0.5mm)(0.5mm)2 / 2(550nm) = 22.72 cm
This equation is for a slit of infinite depth. I'm not totally sure how to convert it to a square aperture...
df = 2λz / W
where
λ=wavelength
W=slit width
Please read my post above. The factor of 2 that you have is of little consequence. Depending how you choose to measure the width, you can get an extra factor of two. That's of little concern in what is going on in the problem that you have.
What is Δx in your working?
For a single slit diffraction pattern in the far field, ## m \lambda =b \sin{\theta} ##, with integer ## m \neq 0 ##, gives the positions of zero intensity. ## \\ ##For ## \sin{\theta} \approx \theta ##, the angular spread between ## m=-1 ## and ## m=+1 ##, which is the (approximate) width of the central maximum, is ## \Delta \theta=\frac{2 \lambda}{b} ##. This corresponds to a distance ## \Delta x=\frac{2 L \, \lambda}{b} ##. ## \\ ## When estimating this width ## \Delta x ##, sometimes the factor of 2 in the numerator is omitted. ## \\ ## If you use the formula with a factor of 2, it complicates the analysis a little bit, but the same conclusions are reached in that the formula for ## \Delta x ## is a far-field formula that doesn't work in the near field.
so Δx= Lλ / b will give us the distance between m=0 (central maximum) and m=±1
The central maximum is a bright blob that peaks in the center and falls off to zero at ## m=+1 ## and ## m=-1 ##. ## \\ ## It is somewhat arbitrary how you estimate the width of this bright blob. Picking it as half the width of the zero points should seem reasonable.
I still get an answer of 45.45cm when I solve for L...
That's ok. What your equations say though is if you let ## L=10 ## cm, that the bright blob will be smaller than the aperture, and that is impossible. ## \\ ## The purpose of the problem is to figure out why the equations are unreliable. The reason is that the equations you are using are only accurate for computing the size of he blob if the screen is far away from the source. ## \\ ## There is actually a very special case with a precisely circular aperture where I think you can create a Fresnel zone plate where the central peak might be smaller than the aperture, but that doesn't normally occur. See also: http://vanderbei.princeton.edu/images/Questar/PoissonSpot.html
So to answer the question I would say the distance would be approximately 45 cm, however, the Fraunhofer condition under these circumstances are unreliable, because if let the distance be shorter the bright blob will be smaller than the aperture, which is impossible
Yes. The Fraunhofer condition, for where these diffraction equations are accurate is ## \frac{b^2}{L \lambda} << 1 ##. This means we are required to have ## L>> 45 ## cm for the equations to be reliable. ## \\ ## ## L ## really needs to be ## L \gtrsim 10 ## meters for your equation for ## \Delta x ## to be reliable.
  • · Replies 34 ·
