How Does the H Parameter Model Calculate Current and Voltage Amplification?
  • Thread starter Thread starter null void
    Model Parameter
11 replies · 4K views
null void
calculate current and voltage amplification
Conversion to h parameter model,
and this is my working step,
https://www.filesanywhere.com/fs/v.aspx?v=8b6b628b5e646faf6e9b
there are something i can't understand, in my calculation, i use equation 3 to find Ai, i get -132... But if i use equation 6 instead of 3, i get 132..., same number but different sign. I suppose there is something went wrong in my equation 6...
Your eqn(2) doesn't correctly show how hfeib divides between the two resistances.
I suggest that, in future, after you create something as a .docx file that you take a screenshot of your effort and post it as a jpeg instead of the .docx file. This will allow those who rely on a basic tablet to still follow the thread, using software add-ons no more sophisticated than a jpeg viewer.
A further suggestion: I think it's a good idea to informatively label dimensionless parameters, e.g.,
hfe = ... amps/amp
hre = ... volts/volt
It helps you to stay correctly focussed, and makes checking easier (especially by those of us who may have forgotten some of these. :wink: [/size]
Your equation 2 is Iout = hfe Ib + hoe Vout
Equation 3 is Iout = -hfe Ib () What are these parentheses?
Why is there a minus sign in front of hfe in equation 3 but not in equation 2?
Shouldn't equation 2 be Iout = hfe Ib + hoe Vout + Vout/Rc?
Also, I don't see anywhere where you have taken Rs into account. Rs has a very large effect on Av.
I would think that Av would be defined as Vout/Vs. Is your problem defining it as Vout/Vin, which is the same as Vout/Vb?
yeah sorry messed up a few thing up there, this is my second attempts
so is this the correct ways?
I think the arrow in the diagram is telling us the Vin is Vb
This is for the voltage amplification, but i can't really figure out how to include the Rs in the calculation
hfe = ... amps/amp
Do you mean by putting amps/amp behind the term like a unit?
For your Iout/Iin expression, the algebra looks right, though there's a transcription error: you show RB hie where it should be RB + hie. I haven't checked your arithmetic, and haven't checked your voltage equation.
You may need a sign change. The arrow direction for iout is indicating iout = -[/size][/color] vout / RC
If VB is correctly denoted as Vin, then as you observed earlier, Rs does not enter into your calculations.
In post #5 and #6, you have used a value of .87k for hie, but in post #1 its value was given as .86k; which is correct?
null void said:
...i can't really figure out how to include the Rs in the calculation
An easy way is to calculate the input resistance at the Vin node, and use that impedance plus the 1k Rs to form a voltage divider. The voltage division ratio from the Vs node to the Vin node can be multiplied times the Av you already calculated to get the overall voltage gain from Vs to Vout.
You may need a sign change. The arrow direction for iout is indicating iout = - vout / RC
Oh yeah, I get what u mean.
hah sorry hie it is actually 0.86k ohms
I find it is a bit tricky to find the input impedance even tough Rs is not included because of the HreVout, it causes great pain for me to kill off Ib , Iin and Vb.
In post #1, you said your problem was to "calculate current and voltage amplification", but you didn't say whether voltage amplification, Av, was defined as Vout/Vs or Vout/Vin.
Have you decided which it is?
Do you still need to calculate Vout/Vs?
from the
-hfeIb = Vout (hoe + 1/Rc)
i should change it to
then at the end, my Ai,
Ai = RB/ [ (Rchoe + 1)( RB + hie )/hfe + hreRc ]
With this change, i get positive 132.4439 amplification
