How Does the Speedometer Reading Change as an Object Falls?
  • Thread starter Thread starter missie
    Physics
The discussion revolves around the concept of free fall and how the speedometer reading of an object, such as a rock, changes as it falls under the influence of gravity. Participants explore the relationship between acceleration due to gravity and the increase in velocity over time.
  • Participants discuss the acceleration of gravity (g = 9.8 m/s²) and its implications for velocity change over time. Questions arise about how to express these changes verbally rather than mathematically, and there is exploration of kinematic equations related to free fall.
The discussion has progressed with some participants gaining clarity on how velocity increases with time during free fall. There is acknowledgment of the relationship between acceleration and velocity, with some guidance provided on interpreting the meaning of g = 9.8 m/s².
Some participants express confusion about how to articulate their understanding without resorting to mathematical solutions, indicating a focus on conceptual understanding rather than numerical calculations.
missie
Let's say a rock had a speedometer on it so that you could measure how fast it was going at any moment. By how much would the speed reading on the speedometer increase with each second that it fell?
what is your answer to this question?
can you explain?
i also learned today that g = 9.8 for most things right?
can you explain?
i also learned today that g = 9.8 [tex]m/sec^2[/color][/tex] [/color]for most things right?
g, the acceleration of gravity, applies at or near the Earth's surface, for all objects. What did you learn about the relationship between speed, acceleration, and time?
that no matter what time or how long it stays at g = 9.8 m/s
What I mean is, I know you have studied the kinematic equations of motion for free fall, you know, the ones like vf = vo + ?
vf = vo + at ? and the teacher said for free fall it's vf = gt
well, that's if vo is zero (if it starts from rest). In general, vf=vo +gt, or rearranging, vf-vo =gt, that is , [tex]\Delta v = gt[/tex]. So what's the velocity change each second? Don't forget units.
how will i know the velocity change every second when i can't solve that because it doesn't tell time. It tells me to answer with words and that its not a math problem.
Think about what is actually happening. When we say that g = 9.8 m/s^2 , what is that saying? Acceleration refers to the change in velocity over time.
An object in free fall starting from an initial speed of zero falls at a velocity of 9.8 m/s after ONE second. How fast do you think it's going after two seconds?
should it be 9.8 x 2 = 19.6m/s at 2 second?
You're one the right track yes.
What the acceleration 9.8m/s^2 means is that every second, the velocity increases by 9.8m/s. Now do you understand how that works?
yes i understand now thank you so much ;]
No problem :)
  • · Replies 20 ·
