How Does the Triangle Inequality Transform from Equality to Inequality?
3 replies · 2K views
Bashyboy
Hello all,
I am currently reading about the triangle inequality, from this article
http://people.sju.edu/~pklingsb/cs.triang.pdf
I am curious, how does the equality transform into an inequality? Does it take on this change because one takes the absolute value of 2uv? Because before the absolute value, 2uv could be a negative value, thus making all of |u|^2 + 2uv + |v|^2 smaller, is this correct?
You are correct ... that is why the first inequality appears. The second one is from the Cauchy-Schwartz inequality, as noted.
These are properties that are required for a metric space.
I have one other question. In the article, it says that since both sides of the inequality of non-negative, it is permissible to then square both sides of the inequality. Why would it not be possible to square both sides if both sides were negative?
I'm sure that they said "you can square each term since they are all positive". Try that with this inequality:
1 - 2 < 1 ... hence the requirement for all positive.
