How Does the Twin Paradox Affect Aging?
44 replies · 8K views
Daniepie
I'm just trying to develop a general understanding of the 'twin paradox', so my description of this is will be a bit poor.
I feel like I have a sound understanding so far on the topic, but the only thing that I can't seem to find an answer for is this scenario;
Say you have the classic twin paradox situation, what I don't understand is what causes the body to 'slow down' its aging process. So I understand that to the twin on the ground say 30 years pass, but their twin traveling returns to be 2 years older.
But why is it that to the traveler it only felt like two years and so they only aged two years? What is actually happening to the body during this time?
The simplest answer is that the elapsed time you experience turns out to be the "length" (called the "interval") of the path you follow through spacetime. Having different elapsed times for two people who followed different routes through spacetime isn't much different from the familiar fact that two people who follow different routes through space may travel different distances. So nothing causes one person to age slowly. They just took a shortcut.
That time acts like a distance may seem hard to swallow, but it's a consequence of time and space being parts of the same thing, spacetime. Time is different from the three spatial directions in some important ways (for example, in spacetime a straight line between two events is the longest route, not the shortest, which is why the stay-at-home ends up older), but there are a lot of similarities.
I strongly recommend that you learn to draw Minkowski diagrams. They are very straightforward (just position-versus-time graphs), but they are the best tool for understanding special relativity. Far more so than studying paradoxes.
BvU said:
The traveling twin experiences acceleration, the grounded one does not.
While true, this doesn't explain the aging difference. It's possible to construct variants on the twin paradox where both twins undergo accelerations and ones where no-one accelerates yet the twins age differently.
Daniepie said:
...what causes the body to 'slow down' its aging process
Nothing causes it because it doesn't happen. You are confusing differential aging with time dilation. It's as though you drive a car from New York to Boston and it takes you a day and you have a friend who makes the same trip except he goes by way of Chicago and it takes him 4 days. Did either of your body rates change during the trips?
Are you referring to Special or General when you say "it's possible...". As I understand it, the "paradox" is entirely restricted to Special Relativity and is a consequence of the lack of accounting for acceleration and gravity. The paradox is resolved in GR. It is the acceleration that accounts for time dilation and length contraction.
It's not a paradox in SR either. GR is not required unless you want to swing round a black hole to do the turn around. It's only a paradox in common misunderstandings of relativity.
It is true that you can't construct a frame of reference for the traveling twin using only inertial coordinates. Some older sources may insist that non-inertial frames are outside the scope of SR, but that's not the modern meaning of the term. And the paradox can be resolved without reference to the traveling twin's reference frame anyway.
No, the paradox is completely explained in SR. There's no need to bring GR into play. Gravity has nothing to do with it. Acceleration does NOT account for the time dilation or length contraction. You get both without acceleration. The acceleration explains the lack to symmetry in their paths through space-time which is what results in differential aging.
EDIT: I see ibex beat me to it
"The acceleration explains the lack to symmetry in their paths through space-time"
Okay, like I said, it's the acceleration that is accounted for in GR and not in SR.
In fact, SR handles acceleration just fine - google for "Rindler coordinates" for an example.
However, your misunderstanding is very common. Intro courses in SR usually don't cover problems involving acceleration because the math is appreciably more complicated, so these problems are left for more advanced classes. This leaves students with the impression that it can't be done, when actually they just haven't seen it done.
The paradox is that by SR, each must "see" the other as length contracted and time dialated. But the can't both be. SR does not resolve it.
That is indeed the paradox, but it is properly and completely explained by SR. A pretty good summary of how do this can be found online here and Taylor and Wheeler's "Spacetime Physics" is a good modern textbook that covers this topic with more sophistication. And for that matter...
Have you read the 1913 paper "On the Electeodynamics of moving bodies"? If so, then you can point out the section that resolves the paradox.
1905, not 1913, and the paradox is explained and resolved in the last few paragraphs of section 2.4: https://en.wikisource.org/wiki/On_the_Electrodynamics_of_Moving_Bodies_(1920_edition)
(This link is dated 1920, but that's the date of the English-language translation from the 1905 German original)
This is a common question. The problem come from thinking about Relativity in terms of something that "causes" clocks to slow down. It is more about the very natures of "time" and "space" and how we measure them.
To explain what I mean, I'll use an analogy. Imagine time and space like a map. North and South is time and East and West are space. If you take two points on that map, they will have a set North-South and East-West relationship to each other. I can turn the map in any direction I like and this relationship doesn't change, as it is tied to the map itself.
This is how time and space were thought of prior to Relativity. What Relativity changes is the relationship time and space has to the map. Now instead of being tied to the map, it is tied to the Observer. Space is measured by the Observer's Left-Right and time by the Observer's Up-down. Now if I turn the map with those two points on it, their Up-down and Left-right relationships change. I can turn the map until the one point is right above the other, or so that neither point is above the other. The same thing happens leave the map where it is and rotate myself instead. My sense of Left-Right and Up-Down turns with me.
So let's consider how that works when dealing with the Twin paradox. This time we are going to use a really big map and put our observers on it. We'll leave Left-right as being space, but now front-back for each observer is time.
We'll have two observers (A and B) and start them off at the same pace from the same point.
Here's how things appear to A.
The red line represents progress in the direction he is walking (which in this analogy represents progress in time). As you can see, By A's reckoning, he progresses through time faster than B. (he ages faster)
If we switch to B's perspective we get this:
According to him, he is the one that makes better progress through time and thus ages the faster of the two.
Unless something changes, this will remain the case. In the Twin paradox, something does change, one of the twin changes his velocity and heads back toward the other twin. In our analogy, this is the equivalent of one of our observer's changing direction and walking back towards the path of the other observer. We'll choose B for our analogy.
Thus from A's perspective, we see this.
Even after B makes his turn he continues to make less progress in time an age slower than A does. When he crosses A's path, he is directly "behind" A in time but in the same spot in space (measured left and right). Thus in the twin paradox, according to A, B ages more slowing than he does during the whole trip and when they reunite has aged less.
What happens according to B?
If we just take our first view for B and extend it we get this
B, after changing direction starts to make slower progress than A. A catches and passes B, and B ends up being behind A. A still ends up aging more than B.
But this isn't exactly what happens according to B, But rather what would happen according to some one who continued in B's original direction after B changed directions.
For what happens according to B, we have to consider what I said above about what happens if we turn the map or turn relative to the map. When B changes direction, so does his relationship relative to A does in terms of time.
What happens is this:
B starts out heading "straight up". After he changes direction he still is heading "straight up" (by his perception he is still walking "forward", so the whole "map" has to rotate. But when this happens, A goes suddenly from being "behind" B to being "ahead" of B. B then starts to catch up, but never does before A crosses its path.
So even though at no time does A or B change the pace at which they walk, B ends up "behind" A
B took a different path in space-time, and as a result, spent less time by his clock doing so than A did.
The important thing to keep in mind is that in these animations the Up and Down directions are measurements of personal time, and the left and right directions are space(limited to one dimension in space.)
Daniepie said:
I feel like I have a sound understanding so far on the topic, but the only thing that I can't seem to find an answer for is this scenario; Say you have the classic te..
The aging process does not slow down. That is the flaw in your logic. The aging process follows the proper time of the twin who's doing the aging. One ages two years for every two years of proper time, the other ages 30 years for every 30 years of proper time.
A remaining question is why the twins find, upon their reunion, that different amounts of proper time have elapsed.
The easiest answer I know is that they take different paths through spacetime.
Thank you so much for all your responses!
I see that I lacked a lot more understanding of it than I thought and my view was fixated on the non-existent "3rd party preferred observer with an over-riding definition of what normal is for some preferred frame." as Grinkle mentioned.
I've encompassed all of the ideas that related onto a piece of paper with the diagrams given; literally grateful for all of the diagrams and explanations because they were a great help!
Now is my time to further sus out spacetime, GR, and SR :wink:
Sorcerer said:
An attempt at your “show the math” request. This is the same problem worked out in the Scientific American thread, with a different gamma.
One twin, A, stays on Earth. The other twin, B, accelerates at a very, very tiny rate (so that acceleration is irrelevant) until he reaches 0.7c. Note: we can accelerate as slowly as we want so, again, reaching the initial speed is irrelevant.
Twin B will travel to a planet that is 7 light years away according to measurements taken at rest with respect to Earth (i.e. this is the distance A measures).
Due to length contraction, as Twin B travels, to him the distance appears to be 5 light years. Thus, traveling at 0.7c, Twin B gets there in 5/.7 = 7.14 years (approximately).
Meanwhile, Twin A sees Twin B reach the planet in (7/.7 + 7) years = 17 years (7/.7 for the actual travel time of Twin B and 7 more years for light to reach Twin A after Twin B arrives). Thus, to Twin A, Twin B’s clock appesrs to be running 7.14/17 = 42% the normal rate.
Both get different times, but both see the other as ticking at the same slowed rate.Now look what happens on the way back. Since according to Earth the total distance is 14 light years, and since the spaceship traveled at 0.7c, the total trip must take 20 years. But 17 were spent on the way there according to Twin A. Thus, according to Twin A, the remaining trip must take 3 years. Thus, on the way back Twin A sees Twin B’s clock tick 7.14 years in only 3 year’s time. So now Twin B’s clock is ticking 2.38 times faster for 3 years.
Meanwhile, Twin B has a total trip time of 14.28 years, and 7.14 years remaining. But by the time Twin B gets to the planet, according to Twin B, 3 years have passed for Twin A. Since the total trip according to Twin A must be 20 years, Twin B must see 17 years tick on Twin A’s clock while only 7.14 tics on his own clock. Thus, Twin B sees Twin A’s clock tick at 17/7.14 = 2.38 times the rate of his own clock, this time for 17 years.
Thus you see the symmetry and asymmetry for each twin. The “moving” twin sees the other twin’s clock tick faster for longer. By the time the reunite, Twin B will be younger than Twin A.
No dependence upon acceleration other than to turn Twin B around so he returns home.
That’s my take on it, anyway. I’m sure someone else has something better.
It appears that you are using the Doppler shift explanation here. But it is a bit muddled. For example, when you say
When Twin B reaches the planet, he sees Twin A’s clock as it was 7 years ago, which means 10-7 = 3 years have passed for Twin A according to Twin B. So according to Twin B, Twin A’s clock is 3/7.14 = 42% the rate of Twin B’s clock.
You are talking about what B sees, but you are working in the frame of A. In B's frame, he doesn't see A as it was 7 years ago, but as it was 3 years ago by his clock. (according to B, that's how far apart A and B was when the light left A) You also say, that that 3 years have passed for A according to B. But three years is the reading on Clock A that Clock B visually sees at that moment, and not the actual time on Clock A according to B at that moment (which is 5 years).
You also claim that acceleration is not important to this scenario, but it is. As A watches B recede, he sees B's clock run slow until he sees B do his turn around and then he sees B clock run fast. But there is a 7 year lag between B actually turning around and B turning around, Thus he sees B's clock run slow for 17 years and fast for 3 years. B however sees A's clock run slow for 7.14 years and fast for 7.14 years. This is because he sees an instant shift in the Doppler shift from A when he turns around. In other words, because he was the one that underwent an acceleration, he sees that instant change in Doppler shift, while A, who doesn't accelerate, has to wait to see the effects of B changing velocity.
Why can’t both twins see the other one as speeding away and then coming back? I get how if two objects are in motion relative to each other the perspective that you are stationary and the other is moving is equally valid for both. But, Why doesn’t this hold for acceleration?
Because you can feel and measure a definite value for acceleration.
Because acceleration can be measured within a given reference frame without having to consider anything in motion relative to your frame. An accelerometer on the ship will tell you if its accelerating or not. Furthermore, a third, inertial observer will note the accelerating ship change its motion while the non-accelerating ship remains in constant relative motion.
... this also ties in with why Newton's second law of motion is ##F = ma##.
Force and acceleration are measurable and invariant across all inertial reference frames. Velocity, on the other hand, is frame dependent: Different inertial observers measure a different velocity. So you cannot assign an absolute value to your velocity.
Note that the "magnitude of relative-velocity [between two given inertial observers]" is frame-independent.
Pedant point:
That is almost a tautology. The velocity of the first observer relative to the second's rest frame is what it is. Everyone agrees on that value because the frame from which the measurement is to be taken is specified. Nobody else's frame enters in.
The one tidbit of real information is that the velocity of the second observer relative to the first's rest frame is equal and opposite. But that's already captured in the fact that one can even say "relative velocity between two inertial observers". If the two relative velocities could be different than that phrase could not properly be used.
Edit: If by "relative velocity" one means "closing velocity according to a third-party frame" then that is not a relativistic invariant.
The geometric analogy is that the angular measure of a line is not invariant under rotations, but the angle measure between two lines is.
I guess I didn't finish writing out the thought.
I don't think that lack-of-invariance of velocity argument is strong enough.
The argument must focus on the fact that the traveler is non-inertial [as PeroK and others did earlier].
What I meant by acceleration isn’t important is that it is only the cause of the asymmetry, but it the asymmetry that ultimately causes the difference. Is that a fair statement?
I think David Morin does a nice job covering the relativity of simultaneity. In particular, I like that he names the "rear clock ahead" phenomenon (see p. 11 of this PDF).
Here's a seemingly bizarre consequence of the "rear clock ahead" effect that Don Koks points out:
Two chapters back, in (5.11), we saw that when two clocks synchronised in their shared rest frame move past us with constant velocity v, the spatially trailing clock leads its partner by a time vL0/c2, where their proper separation is L0.
But on some reflection this leads to a difficulty. Suppose that one of the synchronised clocks sits by our side, while the other lies in a distant galaxy, one thousand million light-years away. Leaving aside questions as to the meaning of distance on a cosmological scale, set their proper separation to be L0 = 109 light-years. Now suppose that we on Earth pace slowly to and fro, moving with speed v = 10−9c in each direction.
In that case, the clock next to us alternately leads and trails its partner by one year. But because it’s right next to us, we can see that its time is not changing at all by any more than the few seconds we spend pacing. That implies that the clock in the distant galaxy is alternately jumping ahead of us by one year and then suddenly dropping behind by the same amount; and this see-sawing continues for as long as we pace to and fro. Can this apparently nonsensical state of affairs really be happening?
Yes, the time we measure on the distant clock really is swinging back and forth wildly, as we accelerate periodically to switch our walking direction. This is a symptom of the fact that as we pace to and fro, we no longer inhabit a single inertial frame; in fact, we no longer inhabit even a single accelerated frame.
Source: https://books.google.com/books?id=ytTFazXPy6oC&pg=PA233
That's what happens in the twin paradox when the rocket-twin changes directions: Earth-twin's clock switches from being the "front clock" to the "rear clock" (in relation to a synchronized clock at the turnaround point). For the rocket-twin, it's like the Earth-twin has suddenly "jumped ahead" very far into the future, but really it's the rocket-twin who's made a sudden change.
Why would the clock run slower when it is moving away and faster when it is coming back?
If it does what happens to a long object as it passes the return point and it has one clock running fast and the other more slowly as it passes?
There is no actual change in the behavior of the clock itself, we're talking about how it LOOKS to the observers.
Does this claim of "wild" play on an emotion? This wild swinging is nothing but a notion of simultaneity swinging, there's nothing physical in that, so in that sense it's not wild.
When you say LOOKS do you mean it's not real?
It's completely real to the looker, it's just not real in the frame of reference of the clocks.
SR deals with inertial frames. Inertial frames are, by definition homogeneous and isotropic in space, and homogeneous in time, meaning all points, directions and times are equivalent. One twin remains in an inertial frame. Another twin accelerates - breaking the defining conditions of an inertial frame - during accelerations particles will all by themselves move in some direction - directions are no longer equivalent. Now how does SR handle that - simple - it considers the non-inertial system as consisting of a large number of inertial systems of very short duration (the typical intuitive calculus thing often used in physics) - in those systems, for a very short period of time SR holds and the analysis proceeds that way. Its done by what is called world lines - you can look up the technicalities eg:
http://math.ucr.edu/home/baez/physics/Relativity/SR/TwinParadox/twin_spacetime.html
That it, that's all.
Now regarding a mechanical explanation/basis of SR - we have one - it's called LET. It's a backwater these days but some people have worked on it - I seem to recall John Bell, of Bells Theorem fame, was one, but don't hold me to it. However the question itself is quite deep and requires a thread of its own. But just a short comment here - Poincare asked Einstein what is the mechanical basis of SR in 1911 - Einstein replied - none - to which Poincare - yes the great Poincare - stood there in shock. He knew it was a penetrating question that Einstein simply dismissed. We now know its even more penetrating than could have been known at the time - but that requires its own thread.
Thanks
Bill
