How does the Wronskian determine uniqueness of solution?
  • Level: Graduate
  • Thread starter Thread starter MathewsMD
    Uniqueness Wronskian
2 replies · 2K views
MathewsMD
Given an nth order DE, how (intuitively and/or mathematically) does computing the Wronskian to be nonzero for at least one point in the defined interval for the solution to the DE ensure the solution is unique and also a fundamental set of solutions?
Also, is it true that if W = 0, it is 0 for all entries, and also if W does not equal 0, it is never equal to 0? If so, is there a formal proof (and/or intuitive explanation) for this?
Also, for a non-homogeneous DE, the solution is in the form Yhomog + Ypart = y, where Ypart is a solution to the g(t). Does Ypart necessarily have to have ALL solutions or just one?
You want to look at Abel's identity. Look here: http://archive.lib.msu.edu/crcmath/math/math/a/a009.htm
Basically it shows the Wronskian is a constant times an exponential type function, so it's always zero or never zero.
Call your DE ##L(y) = f(x)##. If it is a second order DE then ##y_c = Cy_1 + Dy_2## is the general solution of the homogeneous equation. Suppose ##y_p## is a particular solution of the NH equation ##L(y_p) =f(x)##. Then if ##y_q## is any solution of the NH equation you have ##L(y_q)=f(x)## so ##L(y_q-y_p) = f(x) - f(x) = 0##. This says ##y_q-y_p## satisfies the homogeneous equation so there are values of ##C## and ##D## such that ##y_q-y_p=Cy_1+Dy_2##. This tells you that ##y_q = y_p + Cy_1+Dy_2##. Since ##y_q## could be any solution of the DE, this shows that your original ##y_p,~ y_1,~y_2## are good enough to express any solution.
Thank you so much! That's exactly what I was looking for!
