How does thermal stress affect the length of a constrained rod?
  • Thread starter Thread starter Physicsnb
    Temperature change
Thermal stress in a constrained rod occurs when temperature changes cause the rod to expand, but constraints prevent this expansion. The change in length without constraints is given by LαΔT, while the thermal strain is derived as αΔT/(1 + LαΔT). When constraints are applied, the rod remains at length L, leading to a compressive force. The discussion highlights that for small values of αΔT, the thermal strain can be approximated as αΔT, aligning with the professor's definition. The conversation emphasizes the importance of understanding the initial length and the effects of constraints on thermal expansion.
Physicsnb
In a lecture of thermal stress my professor defined thermal strain as ' L α ΔT/ L = α ΔT ' [since strain= ΔL/L and ΔL after application of heat is L α ΔT].
He said that on a constrained body that's not allowed to expand , a force is applied on the body .
If the constraints were removed then the new length would be equal to ' L+ L α ΔT '
However while deriving the formula for thermal strain he used the length 'L' as original length .
My question is : "Shouldn't L(new) be used to derive the equation instead of length L , since the rod is compressed from this length by the walls/constraints not length L. "
ΔL= L α ΔT
ΔL = Change in length of the body
L= Original Length of the body
α= Thermal Coefficient og linear expansion
ΔT=Change in temperature
New length after change in temp, L(new) = L+L α ΔT
My attempt at deriving the equation:
Let a temperature a rod of length L constrained by walls on both ends be changed by ΔT.
So the change in lenghth of rod under no constraints = L α ΔT
Length of rod after change in temperature without walls =L+L α ΔT= L(1+L α ΔT)
However with constraints the rod is forced to length L
Then,
Thermal strain = ΔL/L(1+L α ΔT)
Thermal strain= L α ΔT/L(1+L α ΔT) = α ΔT/(1+L α ΔT)
Physicsnb said:
Homework Statement: In a lecture of thermal stress my professor defined thermal strain as ' L α ΔT/ L = α ΔT ' [since strain= ΔL/L and ΔL after application of heat is L α ΔT].
Relevant Equations: ΔL= L α ΔT
Then,
It's a first order approximation to the differential equation (1) about ## L = L_o##:
$$ \frac{dL}{dT} = \alpha L \tag{1}$$
So we say that since ##L \gg \Delta L ##
$$ L \approx L_o + \left. \frac{dL}{dT}\right|_{L_o} \Delta T $$
$$ L \approx L_o + \alpha L_o \Delta T = L_o \left( 1 + \alpha \Delta T \right) $$
At the far right of the second line above, the ##L## inside the parentheses should not be there.
Then,
OK, except for the ##L## inside the parentheses. So, your derivation gives for the thermal strain $$\text{Thermal strain} = \alpha \Delta T/(1+\alpha \Delta T)$$
Generally, ##\alpha \Delta T## is small compared to 1. In that case, the ##\alpha \Delta T## can be neglected in the denominator. So, to a good approximation $$\text{Thermal strain} = \alpha \Delta T$$ which is the same as what your professor gets. But, I think it's good to think about it the way you did.
Whats L_o? Also , my question was that why is strain =α Δ T .
Also can you please elaborate your derivation a bit more (specifically the second step)
TSny said:
At the far right of the second line above, the ##L## inside the parentheses should not be there.OK, except for the ##L## inside the parentheses. So, your derivation gives for the thermal strain $$\text{Thermal strain} = \alpha \Delta T/(1+\alpha \Delta T)$$
Thanks for your explanation .
α
Δ T .
##L_o## is the initial length of the body.
The strain is ## \epsilon = \frac{ \Delta L}{ L_o}##
$$ \epsilon = \frac{L - L_o}{L_o} = \frac{L_o( 1 + \alpha \Delta T ) - L_o}{ L_o} = \alpha \Delta T $$
So ,
What's L here? New length?
Physicsnb said:
So ,
It's the length of the freely expanded body when thermal equilibrium has been reached.
Could you please elaborate how you got to second step?
Could you please explain how you got to the send equation?
It's a first order Taylor Expansion about the fixed length ##L_o##. A Taylor Expansion is an approximation of a function about a given point over some interval.
That second step is the length function (which would be found by integrating (1) ) truncated to the linear terms of the expansion.
So the first term is what we expect with no change in temp. Its just ##L_o##. Then we extend it by saying over some change in temp## \Delta T##, that ##L## approximately changes like the ## \frac{dL}{dT}|_{L_o} \Delta T = \alpha L_o \Delta T ##
You are working with small (linearized) strain theory. At this level of approximation, ##\alpha \Delta T## is negligible compared to unity. So the thermal strain is ##\alpha \Delta T## and the superimposed compressive strain is ##\sigma /E##, where E is Young's modulus and ##\sigma## is the compressive stress..
