How Does Thermodynamic Path Influence Work and Heat Flow?
  • Thread starter Thread starter cukitas2001
    Thermodynamics
12 replies · 12K views · last reply
cukitas2001
Hey guys, I am understanding a bit more thermodynamics but I've been stumped once again on two problems:
1) A quantity of air is taken from state a to state b along a path that is a straight line in the pV-diagram
If the volume and pressure in state a are 7.40×10−2 m^3 and 1.08×10^5Pa , and those in state b are 0.115 m^3 and 1.32×10^5 Pa , what is the work W done by the gas in this process? Assume that the gas may be treated as ideal.
Is temperature constant here? I'm thinking so because of the line increasing at a constant rate. Do i need to apply [tex]W = \int p dV[/tex] with limits of [tex]V_2[/tex] and [tex]V_1[/tex] (don't know how to insert limits into the integral symbol on latex)
Any ideas?
2) A thermodynamic system is taken from state a to state c in the figure along either path abc or path adc. Along path abc the work done by the system is 450 J. Along path adc, is 120 J. The internal energies of each of the four states shown in the figure are Ua=150 J, Ub=240 J, Uc=680 J, Ud=330J.
A) Calculate the heat flow Q for the process ab.
I don't know how to go about this - work i can deal with on the pV diagrams but Q i don't know. Any help please?
Since [tex]W = \int_{V_1}^{V_2} p dV[/tex], = area under graph, does it matter how n changes in calculating W?
If P/V = constant and V = P/nRT, then what can you say about T and n?
AM
Use the first law of thermodynamics:
[tex]\Delta Q = \Delta U + \Delta W[/tex] where [itex]\Delta W[/itex] is the work done by the gas.
Is any work done by the gas in going from a to b?
AM
AM
no since its isochoric?
so then Q = 150-240 = -90 J...Heat is leaving the system?
or is it 240-150? for change being final minus initial so Ub-Ua?
cukitas2001 said:
I don't follow :frown: :cry: the first problem thinking
Is n a factor in the integral [itex]\int PdV[/itex] ? Do we have enough information to evaluate that integral (the area under the graph) ? Work out the expression for that area in terms of Pa, Pb, Vb and Va.
AM
ok while I am tryin to digest your advice for problem one...on problem two what would the work be from b to c ? would the intergral thing come up here again?
AM
substituting p=nRT/V into the integral wouldn't the constants nRT come out and only integration on p and V be done since p and v vary?
Could you perhaps elaborate some on you method to the first problem and start me off a bit?
He's trying to get you to see that you don't need to actually do an integral to get the area under the curve. You can break the region up into basic geometric shapes whose area formulae should be well known to you.
ok so it should then be the area of the triangle right? i tried doing:
W=(0.5)*(Vb-Va)*(Pb-Pa) and I am getting 492J but its not right...what did i misinterpret?
You are omitting the rectangular portion below Pa.
AM
ooooooooh ok got it now and ifgured out the work done by the horizontal line on the second problem...thanks for the help...
Hey Andrew, you think you could walk me through the mental process you were trying to show me i want to try to understand it.
Which part?
I was trying to get you to realize that if you know P and V, you can determine the work done regardless of how n or T changes. Work is the area under the PV graph.
To your question on how temperature varies (which you do not have to know to find the work in this question), you can see that since P/V is constant and V = nRT/P, then nRT must be constant. So T must vary inversely as n (T = k/nR) where k = P/V
To your question on the heat flow, I was just trying to point out that if work is 0 (as it is from a to b, since there is no area under the PV graph from a to b) the heat flow is the difference in internal energy between b and a: Ub - Ua. In this case the change in internal energy from a to b is positive (increase) so heat flow is into the gas.
AM
