How does this integral become zero?
  • Context: Undergrad
  • Thread starter Thread starter Peon666
    Integral Zero
The integral I=1/2 [(integral sign) cos(n+m)wt dt + (integral sign) cos(n-m)wt dt] evaluates to zero for all n not equal to m due to the periodic nature of the cosine function. Specifically, integrating cos(wt) over an integer number of complete cycles results in a net area of zero, as the positive and negative areas cancel each other out. This conclusion is supported by both theoretical reasoning and graphical representation using tools like Wolfram Alpha, which illustrates the symmetry of the cosine function around the x-axis.
  • Understanding of integral calculus
  • Familiarity with trigonometric functions, specifically cosine
  • Knowledge of periodic functions and their properties
  • Basic skills in using mathematical software like Wolfram Alpha
  • Study the properties of periodic functions in detail
  • Learn about the application of integrals in signal processing
  • Explore advanced calculus topics, including Fourier series
  • Practice integrating trigonometric functions over various intervals
Students of mathematics, physicists, engineers, and anyone interested in the applications of integrals in analyzing periodic functions and signals.
Peon666
While reading in Signals book, here's what I read:
I=1/2 [(integral sign) cos(n+m)wt dt + (integral sing) cos (n-m)wt dt]
"Because cos wt executes one complete cycle during any interval of duration T, cos (n+m)wt executes (n+m) complete cycles during any interval of duration T. Therefore the first integral in the above equation, which represents the area under n+m complete cycles of a sinusoid, equals zero. The same argument shows that the second integral in the above equation is also zero, except when n=m. Hence I in the above equation is zero for all n is not equal to m."
My question is: How do these integrals become zero?
It's just what the book says: if you integrate sin(x) or cos(x) over an integer number of periods, the integral is zero. If you let ,+{x,+0,+2pi}]]Wolfram Alpha calculate the integral, you can graphically see why in the plot: the blue and pink areas are equal (because of the symmetry around the x-axis), and because they are on different sides of the axis, they cancel.
If you want, you can work it out explicitly: the period of cos(w x) is 2 pi / w, so if you integrate over a complete period
\int_0^{2\pi/w} \cos(wt) \, dt
you will find 0. You can even make it completely general and integrate
\int_a^{a + k \cdot 2\pi/w} \cos(wt) \, dt
with a an arbitrary number and k an integer (k = 0, 1, 2, ..., -1, -2, ...).
Got it! Thanks a lot.
  • · Replies 16 ·
  • · Replies 24 ·
