How Does Time Affect Electrical Measurements in a Circuit?
15 replies · 14K views · last reply
scholio
a current of 5 ampere exists in a 10 ohm resistor for 4 minutes
a) how many coulombs pass through the resistor in this time? should be 1200 coulombs
b) how many electrons pass through the resistor in this time? should be 7.5*10^21
c) what potential drop exists across the resistor? should be 50 volts
d) how much energy is dissipated in the resistor during this time? should be 60000joules
resistance R = V/I where V is electric potential, I is current
capacitance C = Q/V where Q is charge ---> not sure about this one
current I = nAqv_d where n is number of electrons, A is area, q is charge, v_d is drift velocity
power P = IV where I is current, V is electric potential.
work W = 1/2(CV^2) where C is capacitance
somewhat started part a:
use first eq to solve for electric potential V --> V = IR = 5(10) = 50 volts
tried using second eq, C = Q/V but did not have capacitance, i don't even think you can use capacitance in this problem
i need help with an equation containing time, because t = 4mins = 240seconds. other wise i could use the fourth eq, and let P = W/t where W is work, t is time and solve for t. the work work formula requires capacitance, which i don't have
as for part b and finding the number of elections i think i use the third eq, hold A as constant but how do i figure out the drift velocity v_d, or do i hold that constant too?
i haven't tried the other parts yet, looking for some insight...
Hi Scholio,
You're right that you cannot use C=Q/V here. Instead, since you know the current, what is the definition of current?
current I is the change in Q over the change in time --> I = dQ/dt
oh i figured it out, i didn't even think of that relationship:
since V = IR = 50 volts
V = (dQ/dt)R
50 = (dQ/240)10
dQ = 12000/10
Q = 1200 coulombs
that was straightforward, thanks!
For the number of electrons per coulumb... h t t p : / / en.wikipedia.org/wiki/Electric_current
That should help.
scholio,
V = (dQ/dt)R
50 = (dQ/240)10
dQ = 12000/10
Q = 1200 coulombs
how would i got about handling part b using I = nAqv_d, do i hold A area, and drift velocity v_d constant?
That's right. Another way to think about it, is that a current of 5A means 5 coulombs per second. Since you know how many seconds the current is running and it's constant, you can just multiply current times time to get coulombs.
The way I did part A which works without needing the voltage is...
I = Q/t...
Q = I*t
= 5A * 4min*(60s/1min)
= 1200 Coul
thanks, i got part a now.
how would i got about handling part b using I = nAqv_d, do i hold A area, and drift velocity v_d constant? the q in this equation is not the 1200 i found in part a is it?
anyways i tried it and it didn't work out: i took A and v_d constant
5 = n(1200)
n = 4.16*10^-3 ---> not right, need 7.5*10^21 electrons
5 = n(1200)
I don't think you need to use that equation. What's the charge on an electron? Be sure to include the units.
(You can argue that A and v_d are constant, but they still have to be in the equation!)
Edit: Also, the n in that equation is not the number, it is the number density (particles / volume).
oh okay, the charge of an electron is 1.6*10^-19 coulombs, is that what i substitute in for q in the equation?
there is another equation involving n, q and v_d. its for current density J.
J = nqv_d where J = sigma(E) where E is electric field, and sigma is conductivity. the material is not specified though.
electric field E = F/q where F is force and q is charge
is this along the right lines now?
No, it's more like changing units. There is one electron in [itex]1.6\times 10^{-19}[/itex] coulombs. How many electrons are in 1200 coulombs?
oh, again i overanalyzed the problem. 1200coulombs/(1.6*10^-19 coulombs) = 7.5*10^21 electrons
thanks again
as for part c, finding the potential drop that exists along the resistor, did i already solve for that in part a? am i correct to say that the V in V = IR is potential difference?
then isn't V = 50 volts then?
no not yet, still need to finish up part c, any tips before i start part d?
I'll let you work on it first. You have everything you need (just don't use the equations with capacitance).
i got part c and d.
part c:
QV/t = I^2R where Q is 1200 coulombs, I is 5 amp, R is 10 ohms, t = 240 sec
V = I^2RT/Q = 50 votls
part d:
energy lost/t = I^2R where t = 240 sec, I = 5amp, R = 10 ohms
energy lost = I^2Rt = 60000 joulesdid i do it correctly? i got the answers i was looking for.
scholio said:
i got part c and d.
part c:
It looks right, but I don't think you need to do quite all that. Your original approach V=IR in the first post is exactly what's needed.
(In the equation you have above, notice that Q/t =I, when the current is constant, so:
QV/t = I^2R ----> I V = I^2 R ------> V = I R
