How does water volume affect electrical resistance?
1 reply · 4K views · last reply
perfectsphere
Hi, I've had an idea for a school physics project but I'm not sure if it will work.
I want to measure the volume of water in a fixed shape container by passing an electrical current though it and monitoring how the resistance changes (with a potential divider circuit). My idea is that if I connect two electrodes at the opposite ends of the bottom of the container and then add more water to the container, the resistance would drop. I got this from how a thicker wire has less resistance than a thinner wire. However, I'm guessing that water doesn't work in the same way as metal wire so I would really value your opinions on how you think this will or won't work.
Thanks!
Pure water doesn't conduct electricity very well but otherwise it should work. It might not be very linear if your container is very tall.
Edit: I forgot to add that if you use a potential divider circuit one of the electrodes will be at a higher voltage than the other. This may result in electroplating effects (eg one electrode dissolves). This is unlikely to be a problem if you only need it to work for few days.
