erobz
- 1,857
jack action said:So you think that the torque input from your engine is completely transferred to acceleration, regardless of the other forces acting on the vehicle? If the front end of your vehicle is resting against a wall, do you think that having a rear wheel torque will give your vehicle an acceleration?
Now you are adding a wall. Another external force that is not present in the idealization.
jack action said:Before anything else, you must first admit you are wrong. The proof is that even you can see that your modelization gives results that don't make sense.
Yes...I've admitted this over and over. It doesn't make sense! Clearly I must be wrong, but where specifically remains to be addressed... Because it works. The formulation works either way. I'm just a little circus monkey spinning the crank on the jack in the box!
I can take any part of the system I'd like to be the system. The laws of physics don't "break". They might be uninteresting for some choices, but they don't break.jack action said:The way you are doing it - one block with two free rotating axles in a single FBD - is not good. It doesn't give results that make sense. It's not used anywhere, ever.
I've shown that a widely published author and physicist has done the very thing I have. So don't say "Its never used".
jack action said:I would tell you to do the FBD correctly and get back to us, but I already did it for you, for each method. All you have to do is accept that these are the right methods to do the work properly and try to understand them.
Your model will yield to the same conclusion as mine under the same assumptions. Yours just initially has extra stuff in it. They are fundamentally the same models.
