How Far Does a Box Slide Before Stopping If Pushing Force Is Removed?
  • Thread starter Thread starter Chandasouk
    Box Friction
1 reply · 7K views
Chandasouk
A stockroom worker pushes a box with mass 11.1 kg on a horizontal surface with a constant speed of 3.80 m/s. The coefficient of kinetic friction between the box and the surface is 0.170.
F=ma
w=mg
What horizontal force must be applied by the worker to maintain the motion?
I found that the Fapplied is 18.5N
If the force calculated in part A is removed, how far does the box slide before coming to rest?
This question I'm having problems on. Here is what I did
18.5N = 11.1kga
a=1.66666667 m/s^2
Then I used the equation of
Vfinal^2=Vinitial^2+2a[tex]\Delta[/tex]x
[tex]\Delta[/tex]x = 0 - 14.44m/s
2(1.66666667)
[tex]\Delta[/tex]x=4.3m ?
Yes that is correct.
Also you could have used conservation of energy.
Note that your a=1.66666667 m/s2 should really be a=-1.66666667 m/s2
But I believe you put it as negative while working it out, so just remember to write the - sign else your teacher might give you it wrong.
