How Far Does the Camera Fall Before the Skydiver Catches It?
76 replies · 6K views
ok i got it!
now how do i solve for displacement?
Remember that y is your displacement. What did you do by solving your quadratic?
i solved for time, a little differently then your formula, check the link in one of my above posts.
And so, where are you now in your problem?
I need displacement given the time it took for the diver to reach the camera.
Didn't you say you had all solved for (obviously except displacement)?
y=delta-d(displacement)
yes thank you, i just realized i can now sub in my time in each of the motion equations, the camera and diver.
can you explaint this formula please? i thought y=displacement? lol
Sorry... I haven't bothered with LaTeX yet, basically what I typed was y=displacement, since the symbol for displacement is delta-d. Djeit's derivation had a mistake in it, try:
[tex] (v_{i1}-v_{i2})t+\frac{1}{2}(a_{1}-a_{2})t^{2}=0[/tex]
Hey I'm so sorry about my quadratic equation :S it was supposed to be [tex](v_{i1}-v_{i2})t+\frac{1}{2}(a_{1}-a_{2})t^{2}=0[/tex]
oh ok thank you guys very much
the original screwed me up so bad lol
Since it's for your class, you should be able to do this yourself. Make sure you get a lot of practice, test time won't let you use PF:smile:
All we did was simply group the like terms together. Make sure you're comfortable with this, because a question like this is bound to be on one of your tests. (From experience)
Regards,
Fragment
haha you're right. And yes there may be one of these, for the most part we are doing slightly less difficult ones, without the 3 second start difference.
what answer did you get with the corrected quadratic?
i think you guys are missing the fact that the camera was falling for 3 seconds already and traveled 44.1 m...and neither of those numbers appeared in the quadratic...wow I am nowhere near close to finishing this lol
I don't think I'm allowed to post an answer until you have first, that way I don't give out an easy solution. Did you manage to figure it out yourself?
Regards,
Fragment
i don't see why it would hurt, I would only gain from it.
but anyways, i got a time of 50 s from the quadratic, and need displacement still :(
im doing something wrong
Can you post your work so we can see where you went wrong? 50s is not correct. It would be very helpful:smile:
Fragment
I don't know how to do those fancy equations so, this is the best i can do
(0-10)t + 1/2 (9.8-8)t^2=0
-10t + 0.9t^2=0
if you sub that into the quadratic you get 50 or another number if you use the other root...
i also want to know where the 3 second delay of the diver comes into play in these equations...because I am not seeing it
Your numbers are wrong, that's why the quadratic gives you 50...
[tex]v_1[/tex] here is the first velocity of the camera, and you had found that yourself in your first post (29.4), so I don't know how you got 0 there. As for [tex]a1[/tex] and [tex]a2[/tex], they are your accelerations of the camera and of the diver, respectively. (9.8 and 8.0). Try again with those numbers.
Fragment
wouldnt initial velocity of the camera be 0?
if v1 is 29.4, what's v2?
10, since your diver had a velocity of 10.0m/s when he dove out of the plane...
ok i see,
v1 should still be 0, as 29.4 was its the cameras final velocity.
I got 22 s
That's not your final velocity. You are comparing velocities and accelerations of two objects in free-fall in an attempt to see where they cross. So 29.4m/s is the velocity that your camera had (at 3.0s) when the diver dove from the place. Thus it is clearly [tex]v_1[/tex]. Otherwise, let it be 0, and you will notice that [tex]v_2[/tex] also needs to be 0. This is where the 3.0s comes into play. I hope you see the logic in this.
Fragment
I think I get it, but the diver isn't in free fall...
was 22 s correct?
I don't need to add the 3s?
and to get my displacement, do i use the numbers from the simplified quadratic in the displacement formula?
For the 3s, no. You don't need to because as I said, you're comparing the times. Our 22s says it takes 22s of free-fall for the objects to cross paths. The 3s was already accounted for when we supposed that [tex]v_1[/tex] was 29.4m/s.
For the displacement, you managed to figure out time, and since you know that,
[tex] y=v_{i}t+ \frac{1}{2}at^{2}[/tex]
You have your answer really, 22s tells you everything. Go ahead and try putting 22s in both [tex]y_1[/tex] and [tex]y_2[/tex], see what you get for both displacements...
Do you clearly understand everything we have done so far? It was pretty simple; in physics you need to pay good attention to what is happening, and to what numbers to use and where. :smile:
ok but like i said, not both objects are in free fall, only the camera..right?
What is your diver doing then?
