How fast is the distance changing? (FODE, I think)
  • Thread starter Thread starter PhysicsMark
The problem involves two cars starting from the same point, with one traveling west at 50 mph and the other traveling south at 27 mph. The question seeks to determine how fast the distance between the two cars is changing after 3 hours.
  • Participants discuss the relationship between the sides of a right triangle formed by the paths of the cars, using the Pythagorean theorem. There is an exploration of taking derivatives with respect to time and how to express the distances traveled by each car as functions of time.
Some participants have provided hints and suggestions regarding the formulation of the problem, while others are exploring the implications of their equations. There is acknowledgment of differing interpretations of the problem's outcome, with some participants expressing uncertainty about the correctness of their findings.
There is mention of a previous forum discussion where a different answer was suggested, raising questions about the accuracy of the problem statement or the interpretation of the solution. Participants are cautious about drawing conclusions based on varying responses from different sources.
PhysicsMark
2 cars start from the same point. Car A travels a constant 50 mph due west. Car B travels a constant 27 mph due south. After 3 hours, how fast is the distance changing between them?
I saw this problem online have been stumped trying to solve it. To start I drew a right triangle according to the problem. I have car A traveling west and car B traveling south. I labeled the hypotenuse side C. I tried to write an equation relating the three sides and (using phythagoras) I said that:
C=\sqrt{A^2+B^2}
My thought was to take the derivative of this equation and then find it's value at 3 hours. I don't think this is correct because I would be taking the derivative with respect to time (I think) and I am not sure how to handle both A and B.
I would like a small hint in the correct direction. I am anxious to solve this one myself, if possible please hold off on presenting the solution.
Thanks for taking the time to read and help.
C=\sqrt{A^2+B^2}
Instead of using A and B, you need expressions that represent the distance each car travels, as a function of time.
dA = 50t
dB = 27t
Now, what expression gives you the distance between the two cars as a function of time t? (What you had is a step in the right direction.)
BTW, what does FODE stand for?
Sorry about the abbreviation. In my DiffEq book, they use FODE to mean First Order ordinary Differential Equation.
This problem does not come from my DiffEq book, but it did remind me of a similar problem in that book that also stumped me.
Thank you for the hint. As always your posts lend insight. I will work on this a bit more and then reply.
Hmm, ok. Using your suggestions here is what I did:
I re-wrote my equations (Thanks, organization is crucial) as:
C(t)=\sqrt{(50t)^2+(27t)^2}
I then simplified as follows:
C(t)=\sqrt{t^2(50^2+27^2)}
...then:
C(t)=\sqrt{t^2(3229)}
...and finally:
C(t)=t{\sqrt{3229}}
I stopped here, because it implies that the distance grows at a constant rate. I originally thought this makes sense, since the cars are traveling at constant velocities . I then thought that this couldn't be correct because I was under the impression this problem involved changing rates (which is why I thought it was a FODE).
I assumed it would be a DiffEq problem because it was similar to a previous DiffEq problem I have encountered.
Does this look correct?
Looks fine to me. As a sanity check, notice that C(0) = 0, C(1) = sqrt(3229), and C(2) = 2 sqrt(3229). After 2 hours, the cars are twice as far apart as they were after 1 hour.
Thanks. This makes sense to me also. I would like to point out something about this problem. I am not sure how relevant this is because the "correct" answer could have come from anywhere. I found this problem on another forum and could not solve it. The original poster came up with the same answer as I now have (about 57 mph) and they stated it was not correct. The poster said the "correct" answer is about 68mph and that they (the poster) did not understand how to get that answer.
Again, I have no idea where the "correct" answer comes from and I have no idea whether or not the original poster posted the problem correctly.
I wanted to add that bit of information to see if it struck a chord.
Thanks for the help! Unless that last bit changes anything, I am satisfied with the answer.
I can't find anything wrong with what you did, so an answer of about 57 mi/hr looks good to me. I don't see how the other person came up with an answer of 68.
  • · Replies 24 ·
