How Fast Is the Skier Going Before She Lands?
23 replies · 9K views
Parzival
An extreme skier, starting from rest, coasts down a mountain that makes an angle of 25.0° with the horizontal. The coefficient of kinetic friction between her skis/snow is 0.200. She coasts for a distance of 10.4 m before coming to the edge of a cliff. Without slowing down, she skis off the cliff and lands downhill at a point whose vertical distance is 3.50 m below the edge. How fast is she going just before she lands?
W = (F cos theta)*displacement
W = KEf - KE0
Kinetic friction = coefficient of kinetic friction * normal force
Weight = mg
I tried combining all of these, but i need the mass to do something. I simply can't figure out the final velocity with the information given.
You can look at the problem in three main segments.
1) Initial Point
2) Top of Cliff
3) Landing at Bottom
Remember that energy is conserved. At rest, the person has some potential energy and no kinetic energy. This total energy is equal to the total energy at point 2, and the total energy at point 3. What type of energy does the person have at point 2?
It may help you to sketch the problem.
1) Initial Point
2) Top of Cliff
Please clarify. I've been stumped by this for days...
You'll find that the mass will simply drop out of your equations. You won't need a numerical value. Just call the mass 'm' and continue to set up your equations.
How does the total mechanical energy at the start compare to the total mechanical energy when she reaches the edge of the cliff?
I can't use any other methods except the formulae given, unfortunately.
No problem. Find the net force on the skier and compute the work done as she coasts.
But to do that, I need to find the mass of the skier. Can you show me specifically how to?
Can you show us the equations you formed?
No you don't. Don't try to find a numerical value, just express it symbolically.
What forces act on the skier?
The normal force, which is equal to mg cos 25° but is balanced out by gravity's y component;
gravity's x component, mg sin 25°;
friction: 0.200 * normal force
Excellent!
So what's the net force on the skier? Then you can use Wnet = ΔKE to find the speed at which she reaches the cliff edge.
Doc Al said:
Excellent!
So the net force is (mg sin 25°) - friction
= (mg sin 25°) - (0.200 * mg cos 25°)
Good. Now find the work done by that net force.
sin 25° is around 0.423, and cos 25° is around 0.906, so:
F = 0.423mg - 0.200*0.906mg
= 0.423mg - 0.181mg
= 0.242 mg
Using W = (F cos θ)* displacement, this is what I get:
(0.242mg cos 0°)*displacement
= 0.242mg * displacement
But what is the displacement?
That was given in the problem statement.
13.9 m?
Parzival said:
13.9 m?
No. We are only dealing (for now) with the part where she coasts down the hill.
So 10.4 m?
Doc Al said:
Yes.
So:
W = 0.242mg * 10.4
= 2.52mg
W = KEf (since KE0 is 0)
2.52mg = 1/2m v^2
5.04g = v^2
5.04 * 9.80 = v^2
49.4 = v^2
v = 7.02 which is still wrong. I think that the displacement should equal 13.9 or something.
Parzival said:
So:
W = 0.242mg * 10.4
= 2.52mg
2.52mg = 1/2m v^2
5.04g = v^2
5.04 * 9.80 = v^2
49.4 = v^2
Assuming you did your arithmetic correctly, what you have found is her speed when she leaves the edge of the cliff. That's not the final answer. You still have to include the effect of her falling from cliff to the final landing point. Keep going.
So:
v^2 = v0^2 + 2ax
v0 = 7.02
a = 9.80 m/s^2
x = 3.50 m
v = sqrt(49.2 + 68.6)
= sqrt(118)
= 10.9 which is correct!
Good, but be careful!
Parzival said:
So:
v^2 = v0^2 + 2ax
This is true, but the reasoning should be from the W = ΔKE theorem, not from kinematics. That result is usually taught as a kinematic relationship for straight line motion--which this is not. The skier leaves the cliff at an angle.
Here's how you would get the same result using the work-energy theorem. Once she leaves the slope, she's in the air. The only force on her is gravity. And the work done by gravity as she falls is mgx, thus:
W = ΔKE
mgx = 1/2mv^2 - 1/2mv0^2
v^2 = v0^2 + 2gx
