I How feasible is home radio astronomy?
  • I
  • Thread starter Thread starter Vanadium 50
Homemade radio astronomy is technically feasible but not practical for most individuals due to the complexity and resources required. Technologies like software-defined radio (SDR) and satellite dishes can aid in building a radio telescope, but significant expertise in electronics and data processing is necessary. Observing sources like the Sun, Venus, and pulsars is possible, but achieving the sensitivity needed to detect faint signals is challenging. The discussion highlights that successful amateur radio astronomy often requires collaboration and a well-planned approach to target selection and equipment design. Overall, while DIY radio astronomy projects can be educational, they may not yield significant scientific results without substantial investment and expertise.
  • #51
Vanadium 50 said:
will make my neighbors sad.
Or mad. Do they already have their own Tiki Torches...?
Astronomy news on Phys.org
  • #52
Baluncore said:
Why collect and combine a year, when it can all be done in 12 hours?
Vanadium 50 said:
Because a 15m disk is awkward, expensive and will make my neighbors sad.
It will certainly be more interesting, Doppler adjusting the pulse rate, then accumulating the time shifted pulses through the different seasons.
  • #53
Vanadium 50 said:
TL;DR Summary: Is a homemade radio telescope realistic?
There seems to be a confluence of multiple technologies that makes the situation better than when I was a wee lad: software-defined radio (SDR), the easy availability of satellite dishes, surveillance drives, and fast CPUs.
Let's take a step back - it is trivial to see the sun in radio. An old analog TV, a set of "rabbit ears" antenna, and you're good to go. Point the antenna at the sun (i.e. the ears are perpendicular to it) and there is noticeably more snow and static than when pointing it away from the sun (i.e. lines up with it). But I am looking to see what else can be done.
I imagine getting a couple of DishTV dishes, and mounting them in the corners of my house or yard,. This gives the directionality of a house or yard sized dish, but of course not the sensitivity. Ballpark a few degree resolution for the array (more like 30 for one dish) It is likely easier to point with phase than with motors. Use SDR as receivers, record every night to disk and "stack" days or weeks of exposure together. Because its SDR you can look, e.g. on and off the 21 cm peak and map out hydrogen.
FWIW, the EDGES 21cm radio-telescope, which has gotten very serious academic and scientific attention, was very basic and could have been done as a home astronomy project. A picture of it is at their website:
Of course, part of this boils down to where your home is. A critical feature of this radio-telescope is that it is located in "a radio-quiet zone in western Australia". The EDGES group is building a sister radio-telescope in "radio-quiet—Devon Island in Nunavut, Canada".
So, if you live in the middle of nowhere, this can work. If you live in the East Village of Manhattan, on the other hand, don't bother. The local radio background noise will dwarf anything interesting you can pick up from space aside from the Sun.
  • #54
That is one experimental antenna element being evaluated. I believe there will be two in the array, separated by 150 metres. That makes it an interferometer for low-band VHF. While the elements are low-profile, the array is ten times larger than a 15-metre dish.
  • #55
I found this forum and clicked on the item.
I was sad to see that some people were so negative about receiving radio astronomy signals.
See below picture of a minimal bucket antenna in the backyard of a house in a city in the Netherlands.
Also a result plot is given.
This can also be a setup for a school project.
I do not know if it is allowed to post links, so I wait and see
  • #57
the admin just posted a link to me
https://public.nrao.edu/ask/galacti...s-with-a-software-defined-radio-sdr-receiver/
In this link there is again the denying of the possibility to receive neutral hydrogen 21cm signals when not using big parabolic dishes.
This is false.
The consequence is that interested persons are blown away by the "experts" like Jeff Mangum and people give up any experiment.
On that site comments are not possible so this lie is there forever.
This is contradicting the principle of science; idea, test, adjust, etc.
Here is a (short) list of maser frequencies which can be persued to probe the forming and death of stars (and the forging of the elements we are made of).
You can see that the lower frequencies are also possible to capture with a standard low cost SDR.
more info on
www.parac.eu
Ps; Hi Marcus, how are your projects going.
  • #58
This is false.
more info on
www.parac.eu
In your link, they use a "9.3 meter solid surface satellite dish"...
  • #59
Ha, another one,
this is what I said:
"In this link there is again the denying of the possibility to receive neutral hydrogen 21cm signals when not using parabolic dishes.
This is simply false."
  • #60
parac-EU said:
Ha, another one,
No, what you actually said was:
(Emphasis added.)
So please clarify: how big must must a parabolic dish be to receive astronomical 21cm signals?
  • #61
We used no dish and no low noise amplifier; just a bucket as shown in the picture.
The project description can be found on
http://parac.eu/projectmk9.htm
  • #62
Was the antenna followed by three satellite TV amplifiers in series ?
What was the RTL dongle plugged into, and controlled by ?
Where was your mobile phone at the time ?
  • #63
So, the plot shown in post #55 shows a peak. How many dB above the background is it? I ask because RTL dongles have pretty high noise figures. In this link
https://www.idc-online.com/technica...se_Figure_Measurements_of_RTL_SDR_Dongles.pdf
The author measures a noise figure of 17dB at 700 MHz for a garden variety SDR. This means the radios noise temperature is 17dB hotter than room temperature. That’s pretty hot. Is the peak you’re seeing consistent with the noise temperature of the hydrogen you’re looking at?
Did some digging. This paper
https://web.mit.edu/lululiu/Public/8.14/21cm/21cm.pdf
Is an interesting read and quite basic. If I understand Figure 8, the gas you’re observing is only 45 or 50 K which is colder than 300K room temperature by a good amount. Makes me question the results in #55.
  • #64
That estimate for galactic source temperature is about right. When the Sun is quiet, it has lower flux than the galactic centre.
The observations from the SDR only cover 13 hours. If it was an astronomical emission, galactic or solar, then we would expect to observe a daily cycle with sidereal or solar periodicity. That is not evident in the short record presented. Even with a 13-hour observation of astronomical signals, I would expect to see some artefact of the antenna pattern, swept across the source by the rotating Earth. A two element interferometer, arranged E-W, with only a couple of hours of observation, would be conclusive. Maybe they use one broad-beam bucket, rather than two, to avoid disappointment.
Until we see a longer record, something that shows a repeating daily periodicity over at least two days, we have to assume the signal being presented is local RF interference, thermal noise in the TV amplifier chain, or in the front-end of the SDR.
At this stage, all the evidence says the project is not radio astronomy.
  • #65
There are much simpler tests I would definitely recommend first. Trying 0 buckets would top my list. These SDRs have a wealth of artifacts, noise sources, gain drift and other limitations that need to be understood first. They could well find this peak shows up anyway. It's quite typical that not all signals detected come in through the SDR RF input.
Long term averaging wouldn't be done this way even with the best of receivers. In the simplest cases people use RF switches to continually cycle the receiver input between very stable known source and the antenna feed. I've actually attempted this using resistive loads and mechanical coaxial switches. I'm not convinced I ever got this working.
  • #66
You said that you were not successful with your method.
So, just try our method.
If still sceptical, read att paper written by Jon Wallace (SARA).
  • #67
Thanks. This will get a good read. Nice antenna design. I've dusted off my coaxial switch box which allows me to pragmatically switch between antenna and a 50ohm load. This should make differencing quite a bit easier. This should help reduce the effects of receiver drift. I also have boatloads of RF amplifiers laying about.
  • #68
You do not need an RF switch.
The plot indicates that frequency shifting is used. You compare "on" the bump with "off" the bump.
For stability; just enable the Automatic Gain Control on the SDR# gui.
Later you can experiment with all other settings.
  • #69
Ps; That horn is not my design.
I am not the author of that paper.
I am the person who is mentioned (about) 10 times.
  • #70
I'd prefer to have some assurances that any bumps measured actually came in through the antenna feed and not some random interference or drift introduced by moving things like antennas and cables about.
This paper definitely used 2 LNAs and a bandpass filter. LNAs can significantly reduce the effects of system noise temperature, which are considerable with RTL-SDR dongles. Given that any out of band saturation of the amplifiers will add considerable noise in band, the bandpass would be better placed before and not after the LNAs.
  • #72
In the paper written by Jon Wallace (SARA), it appears, from the 24-hour records, that radio astronomy is being done. That system employs LNAs, based on ultra-low-noise HEMT FETs. Each stage has a gain of about 19.5 dB at 1420 MHz, at a cost of US$150 each. Those LNAs lift the RA signal to just above the thermal noise of the SDR mixer front-end. The low-cost signal amplifiers available for TV, do not have that expensive ultra-low-noise advantage.
The SDR software will also have a transform gain from the use of an FFT, which is then followed by noise reduction through Power Spectrum Accumulation, PSA. At some point in the software process, the narrowband local interference is being removed, the resulting holes in the spectrum are then being smoothed over.
Likes marcusl, berkeman, AlexB23 and 1 other person
  • #73
Here’s a reference to some SDR evaluations.
https://www.klofas.com/blog/2020/sa...odifications/Evaluation_of_SDR_Boards-1.0.pdf
They look at noise figures. I post this because the SDRs evaluated preform much better than I was expecting at 21cm. I also happen to own several of these devices. The Sdrplay radios come with internal LNAs which typically provide 4.4dB ish NF at 21 cm. This isn’t anywhere near as bad as I was expecting. I spend most of my radio time in the HF and VHF bands where the NF is quite a bit worse. Some of the newer RTL-SDR dongles are also not so bad.
