How High and How Long Will the Apple Travel?
  • Thread starter Thread starter lakhani7
    Fall Free fall
An apple is thrown vertically upward from a height of 1.3 meters with an initial velocity of 2.4 m/s, and the first question addresses whether it will reach a friend in a treehouse 5.3 meters above the ground. The calculation shows that the apple will reach a maximum height of 1.6 meters, which is insufficient to meet the friend's height. For the second question regarding the time in the air, the user initially struggles with the calculations but is guided to use the equation y = (1/2)at^2 + vit. The discussion highlights the need to account for both the ascent and descent times to determine the total duration the apple is in the air, ultimately leading to a calculated time of 0.82 seconds. The conversation emphasizes the importance of using appropriate equations and considering both phases of the apple's flight.
lakhani7
maria throws an apple vertically upward from a height of 1.3 meters with an initial velocity of 2.4 m/s.
A) will the apple reach a friend in a treehouse 5.3 m above ground
B)how long will the apple be in the air before it hits the the ground
vf^2=Vi^2+2ay
A) i was able to get the answer for number one using the equation above.
0^2=2.4^2+2(-9.81*y)
-5.76=-19.62y
.3m=Y
B)i am not able to get the time however. i used vf=vi+at and i was unable to get the time.
0=2.4+9.81t
.244
the answer is .82 seconds.
if anyone can recommend me an equation to use i will be grateful.
Try y= (1/2)at^2+ vi t.
Welcome to PF.
Here are some equations that might be useful.
https://www.physicsforums.com/showpost.php?p=905663&postcount=2
There are several ways to figure the answer to part b).
You can use the equation that relates y, Vy, and t and solve the quadratic for t.
You can also figure the time and height to get to maximum and then figure the time to fall.
V = a*t the first step is easy and you already have the height from part a).
Then all you have to do is figure the time to fall from that height and add in the first part.
nope that doesn't seem to help. i used the quadratic equation with it but to no avail
Your .244 secs is really just the time to the max height. You still have to add in the downward time to fall.
x = 1.3 + .3 = 1.6 = 1/2g*t2
thanks lowly pion will try
Thread 'Collision of a bullet on a rod-string system: query'
In this question, I have a question. I am NOT trying to solve it, but it is just a conceptual question. Consider the point on the rod, which connects the string and the rod. My question: just before and after the collision, is ANGULAR momentum CONSERVED about this point? Lets call the point which connects the string and rod as P. Why am I asking this? : it is clear from the scenario that the point of concern, which connects the string and the rod, moves in a circular path due to the string...
Thread 'A cylinder connected to a hanging mass'
Let's declare that for the cylinder, mass = M = 10 kg Radius = R = 4 m For the wall and the floor, Friction coeff = ##\mu## = 0.5 For the hanging mass, mass = m = 11 kg First, we divide the force according to their respective plane (x and y thing, correct me if I'm wrong) and according to which, cylinder or the hanging mass, they're working on. Force on the hanging mass $$mg - T = ma$$ Force(Cylinder) on y $$N_f + f_w - Mg = 0$$ Force(Cylinder) on x $$T + f_f - N_w = Ma$$ There's also...
