How High Must a Rocket Travel for Gravity to Halve?
The discussion revolves around determining the altitude at which the force of gravity acting on a rocket is reduced to half its value at the Earth's surface. The subject area includes gravitational physics, specifically the equations governing gravitational force and field strength.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore the use of gravitational equations, questioning whether to apply the Force of Gravity or Gravitational Field Strength equations. There is uncertainty about the correct interpretation of gravitational acceleration at the Earth's surface.
Some participants have provided guidance on the relationship between gravitational force and distance, suggesting the use of the radius of the Earth in calculations. Others are attempting to clarify their reasoning and calculations, with some expressing confusion over their results.
There is a mention of the gravitational force decreasing with distance and the need to consider the radius of the Earth in the calculations. Participants are also addressing potential errors in their mathematical approaches.
Hannahj1
A rocket ship is moving away from the Earth after having been fired from a launch pad in Florida. At what point above the Earth's surface will the force of gravity be reduced to ½ of its original value?
Prior to this question I was given the equations to calculate the Force of Gravity (Fg = GMm/R^2) and the Gravitational Field Strength (g = GM/R^2).
At first, I thought you would use the Force of Gravity equation due to what the question is asking but am I mistaken in thinking that the correct answer is gotten by using the Gravitational Field Strength equation?
I'm also not too sure about whether or not the original force of gravity would be 9.8m/s^2.
Using the given value G = (6.67 x 10^-11) and letting d = distance above the Earth's surface.. (0.5)g = GM/(R+d)^2, I just plugged the values in and ended up with a distance of (2.6 x 10^6) meters above the Earth's surface.
Please use the Homework Help Template in all of your schoolwork posts here. Thanks. :smile:
The force of gravity falls off as 1/r^2, so you only need the radius of the Earth to answer this question. Does that help?
Also, 9.8m/s^2 is the acceleration due to gravity at the surface of the Earth; it is not a force.
Thank you! So should i do Fg1 = Fg2 and when i reduce it, it gives me 1/R^2 = 1/2R^2 but the second R is radius of Earth plus the distance of the satellite? I tried to solve for the distance and got a negative number.
Try using Re and R2 for the two radii, and Fe and F2 as the two forces. Please post your full work so we can see it and correct any errors. :smile:
OH I just realized my mistake! i was doing 0.5GMm/R^2 but i had to do 2GMm/R^2. Thank you for all the help!
  • · Replies 23 ·
  • · Replies 19 ·
