How Is Angular Velocity Affected by Torque in a Multi-Pulley System?
3 replies · 3K views · last reply
Yapper
Q2: IF mA=2kg, mB=7kg, and mC=5kg. Starting from rest, if a torque of 5Nm is
given at t=0 to pulley A about point A for 3 seconds. Determine the angular
velocity of the 3 pulleys at t=3s.
[PLAIN]http://img98.imageshack.us/img98/8214/unled2tw.png
relationship between rotational velocity and radius of 2 linked pulleys:
wa/wb = ra/rb
moment of inertia for a pulley:
I = 1/2mr^2
torque and angular acceleration:
t = Iα
I calculated the moments of inertias for all 3 pulleys but I don't know how to apply them with the torque. Do I just add all 3 of them together and put it into t=Iα to find the acceleration and then figure out the velocity after 3 seconds? Thanks
Hi Yapper! :smile:
(have an omega: ω and a tau: τ and try using the X2 and X2 icons just above the Reply box :wink:)
nooo, don't be laaazy :wink: …
call the tensions T1 and T2, and do τ = Iα for each of the three pulleys (separately).
actually, thinking again, there is a lazy way to do this problem :rolleyes: …
(but it involves a bit of calculus at the end)
call the angle the first pulley goes through θA,
then find the work done as a function of θA, and equate that to the kinetic energy of all three pulleys, giving a differential equation relating θA and dθA/dt, from which you can find θA or dθA/dt as a function of t without finding the tensions …
try it both ways, to see :smile:​
