How Is Deflection Calculated for a Partially Supported Circular Lid?
3 replies · 2K views
Rajashekar
Hi
In one of my application I am using a linear actuator to lift a 30kg lid which has a diameter of 380mm.
I can only use 1/3rd portion on the lid to take support, for actuator which I used a 60*20*180 long plate mounted to the lid and lift.
How to calculate the deflection of lid when lifted to 100mm
Rajashekar said:
Hi
Welcome to the PF.
Can you post a diagram of your setup? It's a bit hard to understand your question (at least it is for me). Thanks. :smile:
Welcome to the PF.
Hello Berkeman,
Thanks for your reply. Here is the image
I have attached, the plate is mounted to lid using 4- M10 screws and the lid is lifted to 100mm length
Thanks in advance:smile:
Rajashekar said:
Hello Berkeman,
The lid weight is 30kg, the actuator load carrying capacity 1500N.
