How is electric charge measured?
Electric charge is measured using instruments such as electrometers and milliammeter setups. An electrometer detects the presence of charge by observing the repulsion of leaves, while the amount of charge can be quantified by transferring it to a known capacitor and measuring the voltage across it using the formula Q = C x V. Additionally, a vibrating switch can alternately charge a capacitor from a battery and discharge it through a milliammeter to calculate the charge transferred based on the known frequency of switching.
  • Understanding of electric charge and its units (Coulombs)
  • Familiarity with electrometers and their operation
  • Knowledge of capacitors and the relationship between charge, capacitance, and voltage
  • Basic principles of current measurement using milliammeter
  • Research the operation and applications of electrometers in charge measurement
  • Learn about capacitor charging and discharging techniques
  • Study the principles of using milliammeter for current measurement
  • Explore advanced techniques for measuring electric charge, such as using oscilloscopes
Students and professionals in physics, electrical engineering, and anyone interested in understanding the measurement of electric charge and its practical applications.
jd12345
How do we measure the amount of charge body has. Can you tell me some instruments and how do they work.
Well i know how ampere is defined so one coloumb will be the current that flows in one second - but how can wemeasure that?
Its good to test if charge is present as the leaves will repel but how do you measure the amount of charge?
Perhaps i don't understand -
More charge => more force between the leaves => larger distance between them
The basic idea is that you convert the measurement of the charge to a measurement of some other property - like the distance between the leaves, or a current somewhere, or an acceleration of particles or whatever.
one technique is to transfer the charge to a known capacitor then measure the voltage across the known capacitor. Then use Q = C x V to find Q.
An instrument designed to do this is called an electrometer.
If you want to measure the charge on a capacitor then a vibrating switch can be used to alternately charge the capacitor from a battery then discharge it through a milliammeter. If the frequency of switching is known then the chatge transferred at each switching can be calculated from the current read by the milliammeter.
  • · Replies 20 ·
  • · Replies 58 ·
  • · Replies 16 ·
  • · Replies 29 ·
  • · Replies 73 ·
  • · Replies 24 ·
