How is Force Related to Acceleration and Mass?
  • Thread starter Thread starter urbano
The discussion revolves around the relationship between force, mass, and acceleration, particularly how different equations and units relate to one another. Participants are exploring the definitions and units of acceleration, force, and mass, and how they connect through Newton's second law of motion.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to understand the differences between average speed and acceleration, questioning how acceleration can be expressed in terms of force and mass. There are discussions about unit conversions and dimensional analysis to clarify these relationships.
Some participants have provided clarifications regarding the definitions of acceleration and the units involved, while others express ongoing confusion about the connections between the concepts. There is a recognition of the need to examine units closely, and some guidance has been offered regarding the dimensional analysis of force and acceleration.
Participants are grappling with the definitions of terms and the implications of different units in both metric and English systems. There is an emphasis on understanding the foundational principles of kinematics and dynamics as they relate to the problem at hand.
urbano
If a = d/t how can it also = f/m ? I can't see a common unit between the two equations.
In the first one if I covered 50m in 20 s I'd be accelearting at a rate of 5m per 2s or would it be 5m per 2 s^2.
So how does then become force * mass ? what would force * mass become as a unit ? would it Newtons per kilo ? and how does this then become meters per second ?
whoa...totally unsure where to start in terms of a solution.
Distance covered over time is (average) speed, not acceleration. If you cover 50 m in 20 s your speed is 2.5 m/s.
Acceleration is change of velocity during unit time. If your velocity increases to 3 m/s from 2 m/s in 5 s then your acceleration is a=1/5 =0.2 m/s2.
ehild
thanks for that ...I'm still unsure though how a = change in velocity during unit time to becoming a = f/m...I can't quite understand the link here or see the common unit to convert one to the other
It may because you aren't examining the units closely enough if you are simply going off a dimensional comparison. In metric acceleration has units of m/s/s, mass is in kg, and force in Newtons. In english units acceleration is in ft/s/s,mass is in slugs and force is in lbf(pounds force). If you want to see the equivalence between both units you have to remember that force regardless of system is a derived unit meaning it comes as a compounding of basic units. One Newton is defined as one kg*m/s/s. Similarly pound-force is equivalent to one slug*ft/s/s. If you plug these units into the above equations you should find that the units work out in both cases because mass cancels on the force side. In general: acceleration=LT^-2 and force=MLT^-2.
Acceleration is defined as the amount by which the speed (velocity) changes in a unit of time. It tells you the rate of change of speed, for instance g = 9.8 m/s2 tells us that the speed of the object will change with 9.8 m/s for each elapsed second. this definition is given in the kinematics chapter of a physics handbook. Here acceleration is calculated by looking at the change in speed of the object
The second time one meets the acceleration is when the question is investigated - How do the motion of an object change (its acceleration) if a force F is applied to it and its inertia (mass) is m. Here we calculated the acceleration from its mass and the (net) applied force acting on it. So they are two different ways to get the same quantity, either from a kinematic or a dynamic viewpoint.
d/t is not equal to acceleration, that's velocity. In terms of displacement, acceleration is (d^2/dt^2)d. You could also say it's equal to v/t.
There's no need to "convert." The standard units of acceleration are m/s^2. If you work out the units for f/m, it comes out to be m/s^2. You can also work out the units for v/t or (d^2/dt^2)d and it comes out to be m/s^2.
I should mention that the d in (d^2/dt^2) is a differential, and not displacement.
Observing the motion of objects, Newton found out that the force causes acceleration, and the acceleration of an object is proportional to the force exerted on it, and inversely proportional to the mass of the object: Force is equal to mass times acceleration, F=ma. The unit of force is called "Newton", it is the same unit as kg m /s2.
ehild
  • · Replies 32 ·
  • · Replies 29 ·
  • · Replies 25 ·
  • · Replies 18 ·
