How is proper time visualized in the FLRW metric's 4D spacetime geometry?
The discussion revolves around the visualization of proper time within the context of the FLRW metric's 4D spacetime geometry. Participants explore the implications of time variance in the equations and the placement of observers and emitters in this framework, touching on concepts of cosmic time versus proper time.
  • One participant introduces the FLRW metric to discuss the homogeneity and isotropy of the Universe and questions the placement of observers in the 4D visualization.
  • Another participant seeks clarification on the concept of time variance and its implications for the coordinates of observers in a spatially homogeneous spacetime.
  • Some participants propose that cosmic time is the proper time of a comoving observer, while noting that observers moving relative to this frame will experience time dilation.
  • There is a discussion about whether the observer and emitter can be associated with specific points in the 4D geometry, with some arguing that all points are equivalent due to homogeneity.
  • Participants express differing views on the invariance of time, with one noting that proper time is invariant along a specified path, while cosmic time is defined differently.
  • Concerns are raised about the representation of signals in the 4D diagrams, with one participant asserting that no signals are depicted in the visualizations.
Participants express multiple competing views regarding the nature of time in the FLRW metric, the placement of observers, and the interpretation of cosmic versus proper time. The discussion remains unresolved with no consensus reached.
Limitations include the dependence on the definitions of cosmic and proper time, as well as the assumptions regarding the placement of observers in the 4D geometry. The discussion also highlights the ambiguity in visualizing spacetime events and the representation of signals.
Ennio
TL;DR
If we consider a time variance in FLRW metric, how can we visualize an emitter (having proper time) in the 4D spacetime geometry?
The FLRW metric has been introduced to characterize the homogeneity and isotropy of the Universe and accordingly to obtain "easy" manageable solutions in Friedmann equations.
The FLWR metric is
where the LHS can be written as
where
is the proper time (despite we know that time is invariant in the formulation).
Please refer to the image below to visualize the 4D spacetime geometry used to derive the metric.
My questions is:
Let assume that the we do want to theoretically discuss a time variance in the equation.
In the 4D visualization, where is actually the observer placed? In one of the two spacetime events P1 or P2 ? Not in the center of the geometry.
Accordingly, does the proper time
refer to an event occurring, for instance, in P2 with respect to the observer, if placed in P1?
In this case, P2 emits the signal which is received by P1.
Am I making a conceptual mistake?
Thank you for supporting me.
E.
What do you mean by
The coordinates are based on an arbitrary point in a spatially homogeneous spacetime. A comoving observer can be taken to have any coordinates.
Orodruin said:
What do you mean by
I mean that I would like to study a possible difference between cosmic and proper time. Why should time be invariant? Anyway, my question was related to the identification of the emitter in the 4D geometry. Are basically observer and emitter associated to P1 and P2 (see original picture I posted). Thank you!
Do you mean you want to consider a perturbed version of the FLRW spacetime? Making it slightly more realistic so that stars and galaxies could form over time instead of there being a perfectly uniform fluid everywhere in spacetime?
Well, the two visualisations are of 2d spatial slices embedded into a (purely invented) 3d space. Accordingly there may be observers at any location. Furthermore, the lines marked ##dl## are spatial displacements, so don't correspond to any interval of proper time at all - they are spacelike paths.
There are no signals represented in those diagrams.
Cosmic time is the proper time of a comoving observer. If an observer moves relative to the comoving frame, they will be time dilated accordingly relative to cosmological time.
All points in space are completely equivalent. This is what homogeneity means. You can therefore pick any two points as long as they have the correct comoving distance between them. Of course, some choices (such as placing emitter or observer at r=0) makes life easier than others.
Assuming that by "cosmic time" you mean the time coordinate, ##t##, this is a completely different thing from proper time, which is the time experienced by any arbitrary observer between two points.
It isn't, in general. The proper time along a specified path is an invariant, certainly, and (as Orodruin has just noted) the cosmic time is the proper time since the singularity experienced by observers at rest with respect to the matter in the universe.
Ennio said:
Summary: If we consider a time variance in FLRW metric, how can we visualize an emitter (having proper time) in the 4D spacetime geometry?
If there is a particular observer of interest (which is not necessary) then you would typically place them in the center. I am unsure why you would say “not in the center”. The center is arbitrary and any point can be selected as such.
  • · Replies 35 ·
  • · Replies 70 ·
  • · Replies 81 ·
  • · Replies 20 ·
  • · Replies 21 ·
  • · Replies 21 ·
