How Is Rocket Speed and Height Calculated Under Varying Thrust and Mass?
The discussion revolves around the calculation of a rocket's speed and height under varying thrust and mass conditions. The original poster presents a problem involving a rocket with an initial mass and a thrust model defined by the rate of mass loss and exhaust velocity, both of which change over time.
  • Participants explore the implications of using the momentum equation dp/dt = mdv/dt + vdm/dt, questioning its validity in the context of changing mass and external forces. There are attempts to integrate the resulting equations and clarify the relationship between mass loss and thrust.
Participants are actively engaging with the mathematical framework of the problem, raising questions about the assumptions made regarding mass and velocity. Some have offered partial guidance on how to approach the integral and the implications of using specific equations, while others are seeking clarification on their interpretations and calculations.
There is an ongoing debate about the treatment of the exhaust velocity and mass as constants versus variables, as well as the implications of these assumptions on the derived equations. The discussion reflects a mix of interpretations and attempts to reconcile different approaches to the problem.
John004
A rocket with initial mass of m0. The engine that can burn gas at a rate defined by m(t)=m0-αt, and expel gas at speed (relative to the rocket) of u(t)=u0-βt. Here, m0, α, u0, and β are all constants. Assume the lift-off from ground is immediate
a) The rocket speed v(t)=?
b) The rocket height (from ground) y(t)=?
F = dp/dt
So F = dp/dt → -mg = u dm/dt + m dv/dt since dm/dt = -α → -g = (-α/m)u + dv/dt
→ ∫(-g + α(u0 - βt)/(m0 - αt) dt) = v
so I am not really too sure about how to solve the above integral
You need to be careful using dp/dt =mdv/dt+vdm/dt. That equation is as though the mass can magically change without the total momentum changing. E.g. consider a car moving at speed v, not burning fuel, just leaking it. With no external force, dp/dt =0. Since dm/dt<0, you would conclude that the car must be accelerating. In short, it is only correct in a reference frame where the gained or lost mass now has zero velocity.
haruspex said:
You need to be careful using dp/dt =mdv/dt+vdm/dt. That equation is as though the mass can magically change without the total momentum changing. E.g. consider a car moving at speed v, not burning fuel, just leaking it. With no external force, dp/dt =0. Since dm/dt<0, you would conclude that the car must be accelerating. In short, it is only correct in a reference frame where the gained or lost mass now has zero velociity.
I don't see what the problem is using dp/dt in the way i have here is?
The lost mass, the burnt fuel, does not have zero velocity in the reference frame.
Edit: Maybe your final equation is ok, though. I haven't checked that. I will now.
Edit 2: My mistake. I misread this line: u dm/dt + m dv/dt as v dm/dt + m dv/dt.
Sorry about the confusion.
To solve the integral, expand the (u0-βt)/(m0-αt) using partial fractions.
So then how can i take into account the changing mass? I thought your argument was just about when there is zero external force
Please see my later edit.
Ah
ah ok, i see. anyways, i was still using the equation without knowing why it was right. So it is valid because "u" is measured relative to the rocket?
John004 said:
Ah
On this forum, we often see dp/dt = d(mv)/dt = mdv/dt+vdm/dt, using the product rule. That's why I misread what you posted.
I'm not sure how you figured out to use mdv/dt+udm/dt, where u is the relative velocity of the exhaust. Maybe you did it using the frame of reference of the instantaneous velocity of the rocket.
I just noticed that you can do the following also
Fext dt = u dm + m dv, since dm/dt = -α
-mg dt = -uαdt + m dv
-g dt + (u/m) α dt = dv
(-g + (u/m)α)dt = dv. Then using the same relation from before
(-g + (u/m)α) (-dm/α) = dv
(g/α)(m-m0) + u ln(m0/m) = v, then using m - m0 = -αt
-gt + u ln (m0/m) = v
Isn't this contradictory to my previous result?
Doesn't that step treat u as constant?
It is a constant with respect to m isn't it?
No. Both m and u vary over time.
Not sure if you worked out the whole problem, but if you did, could you take a look at what I got and let me know if it's ok?
Unfortunately your image is sideways, making it hard to read.
I get the same expression for v, except that you can simplify it by recognising that the two ln() functions are the same, just opposite sign.
I end up with
##y=\frac 12 (\beta-g)t^2-(\beta-\frac{u_0\alpha}{m_0})((1-\frac{\alpha}{m_0}t)\ln(1-\frac{\alpha}{m_0}t)-\frac{\alpha}{m_0}t))##
I'll leave you to decide whether that matches your result. If it doesn't, try differentiating both to get back to v.
  • · Replies 42 ·
  • · Replies 27 ·
  • · Replies 23 ·
